If I had a pair of SDA 2A or 2B, I wouldn't waste time or money on the original CRS with the two tweeters per cabinet. Money's better spent on the better SDA speaker design or on a pair of Monitor 7s.
1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables 2. JM Labs Electra 920.1; Sonic Frontiers Line 3 Preamp; Classe Model 25 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio Power Director; MIT S1 Cables 3. Polk LSiM703; Parasound JC2BP and A21; Sony 48" 4K TV; Wyred4Sound DAC 2; Oppo 203; Squeezebox Touch; MIT S3 cables
There are three versions of the CRS. The original '84 CRSs were 2nd generation, two tweeters, either SL1000 or SL2000. No sub-bass drive circuit.
'86 CRS+ were 3rd generation, single tweeter, with sub bass drive circuit. Same crossover as the SDA-2A.
'87-'89 CRS+ were 4th generation, single tweeter, sub bass drive circuit. Same crossover as the SDA-2B.
Most desirable '87-'89, least desirable '84.
There would have been a 5th generation called the SRS-4.1, but Polk ceased production. The TL or SL3000 modification is the SRS-4.1 however.
It's not the new tweeters that make the polyswitch unnecessary. It's when the crossovers get upgraded with film caps.
So, I can safely just swap out the SL1000/2000 with the RD-0194's and do nothing else to the x/o's ? Edited
Been reading the SDA Handbook and believe the answer to my question is 'yes'.
yes you can use the RD-0194 for replacement to both of those tweeters BUT the SL1000 has a differrent cut out and modifications to the holes will be needed. Although less desirable they are close and if price is right worth it as they do have a very good soundstage.
I said the new tweeters make the bypass cap unnecessary; not the polyswitch.
You're still wrong.
The purpose of a bypass is to improve the performance of another capacitor usually an electrolytic. When upgrading to a film cap the bypass is no longer needed as it creates unwanted artifacts.
I'm still wrong too. I meant bypass cap, not polyswitch. However, Dr. Wu is still wrong about the tweeter and the bypass cap.
Ok. Picked up the CRS's and they were in pretty good shape. Been listening to the stock SL2000's in them & they are bright. My older ears don't find them necessarily obnoxious but I'm use to the smooth sounding RD-0198's in my TL'd 7c's. Definitely not bass heavy, but with my 12' Klipsch sub they sound surprising musical and have good separation. I've been trying to order a pair of RD-0194's for the CRS's & a pair of RD-0198 for my 2a's that are being upgraded by @westmassguy. Have read about the issues with 'Polk' CS. Hoping my experience would be different because it's just an order for parts, no warranty or equipment issues and it has to be a phone call since these parts can't be ordered online. But alas, 3 days of getting a looping voicemail prompt that keeps taking me back to the same menu, talking to an actual warm body that continually transfers me to the 'Sorry, we are experiencing a higher than normal......please call back later', and leaving my phone # multiple times for a return call which never comes. I realize it's now Saturday and don't expect any response through the weekend but if nothing materializes next week is there any other avenue to pursue? May have to advertise in the classified's for a couple pairs.
That's funny, I have heard similar issues but the few times I've called I was greeted by a live person right away. Are you calling after hours? Give me you credit card number Thomas. I'll order you a couple...
Home System:
SDA 1C's - Full mod with the help by Dave...
1000 Va Dreadnought- w/ WireWorld Mini-Eclipse cables
WireWorld Mini-Eclipse 7 speaker cables
WireWorld Silver Eclipse IC's
Cambridge Audio Azur 851N - DAC/Streamer
Parasound Halo C-2 Pre/pro
B&K M200 Sonata Monoblocks
BLE-Design 16mm Power Cables
Denon DVD 2900
Barn system:
SDA SRS 2.3's Full mod done by myself
Carver C-1 pre
Carver M1.5t
BluDenso - Bluetooth receiver/DAC
Heading back out to Denali Park tomorrow and will be out of cell/internet service for a while. Will try once more when I can and then may have to take Robert up on his offer.
Update
Tried again today. A little different this time. Completely different voice mail that I hadn't gotten before, asked me to leave a call back # and that I had a definite position in the queue for that return call. Hmmmm..... Low and behold 20 minutes later I got a call from the tech line. Briefly explained my frustration, stated what I needed and had all the tweets ordered in 5 minutes. Also, asked about the elusive MW6510 & 6503's just for grins & giggles. Apparently, Midwest Speaker Repair ( I believe that's who he said as our connection was in and out) is tooling up to manufacture accurate replacements for these and a couple other MW's. Is this information already on the forum here somewhere and I've just missed it?
Update
It has been brought up and doubt cast upon their ability to correctly deliver. We shall see...
Some fool at Sound United decided they are no longer going to support vintage products.
But they have a 'mission statement' and they are 'diversifying' their interests. May 28, 2018
Sound United Introduces ‘Sound Start,’ An Initiative to Donate 10,000 Instruments to Children Worldwide in Partnership with VH1 Save The Music Foundation
Just received this email response from MidWest Speaker Repair: Hi Thomas,
Yes, we are in the works for MW6502 and MW6503 replacements. Should be available this Sept.
Not to speak for @DarqueKnight but I believe he tested the MW6510 v. RD6519 and found them to perform nearly identically. So, you might feel comfortable using them interchangeably if you can find one or the other, here and there. Good luck!
He said by July......
This is not my experience but a seasoned member was doubtful that they would reproduce them correctly. Only time and some money to test will tell.
We all knew this day would eventually come. That's why some of us have boxes of spare drivers and tweeters stashed.
"So hot it burnsMice!"~DK
"Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
"Knowledge, without understanding, is a path to failure."~DK
"Those who irrationally rail against something or someone that is no threat to them, actually desire (or desire to be like) the thing or person they are railing against."~DK
Alright, had a couple days home and have been pushing the CRS’s with some 200 watts of Carver power. They do seem to soak up more watts than the 2A’s but for 30+ year old, untouched SDA’s they are great. Have them set up fairly high to really listen to the SL2000,s before I disconnect the SDA tweeter & replace the stereo tweet with the RD-0194’s. Seemingly pretty good sound stage with just a little less separation than my stock 2A’s. Bass is definitely a little lacking by themselves but with a 12” sub to make it up they slam pretty well. Granted my hearing after 40+ some years of construction is not what it use to be but what is the ‘SDA wonkiness’ that many describe with the SDA tweet connected in these CRS’s? I’m not really hearing any difference with the SDA tweet connected or disconnected. Any suggested sound track that might make it more discernible?
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
"And keep her under 70, would you, huh? Betty likes a slow ride"
Yes yes yes yes yes I answered that already.
You're still wrong.
Denon DVD 2900
Barn system:
Carver C-1 pre
Carver M1.5t
Glad to hear you are on track with the tweeters!
The gentleman I spoke to said that the 6510 replacement was discontinued recently. He didn't get any more specific than that.
May 28, 2018
Hi Thomas,
O Hecho en Mexico....
