T50 tower speakers cutting out
Both speakers independently cut out. Lightly tapping on the speaker cone fixes the problem for a while, then it starts cutting out again.
All connections are tight, and it doesn’t cut out when the speaker wires or terminals are jiggled.
What could be wrong?
Answers
  • mantis
    mantis Posts: 17,557
    Sounds like the internal wiring is loose. Take them apart and check the connections.
    Dan
    nooshinjohn Posts: 25,976
    I would start by cleaning the speaker terminals and your connectors first. How are your wires terminated?
  • stangman67
    stangman67 Posts: 2,328
    ^that was my initial thought. If the VC's of the drivers are damaged (ie the coil is broken/open), pressing the cone of the driver temporarily re completes the VC circuit and allows the speaker to play while the cone is being pressed in
