SDA SRS 3.1TL
Good stuff, the RD0 series tweets are a nice improvement (and more durable).
Mortal Engines has killer sound, glad I picked it up off the bay on Blu Ray!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Don’t forget to break in the new tweeters. Run them continuously for a few days to work out the mechanical manufacturing stresses and they will sound even better.
I am glad you noticed the difference as well. It is amazing how big of a difference it is.
Yes theres a huge difference...they sound so much better. More natural, smooth and controlled.
Yes Mortal Engines is incredible. I have it on 4k, one of the best looking and the Atmos is one of the best sounding movies I have seen to date.
Plus it was shot in 8k and down scaled to 4k. Exallent shadow detail and the HDR is top notch.
I'm still sorting out how I want to go about the crossover upgrade.
But I'm thinking I'll be getting in touch with you soon. -
honestaquarian wrote: »Don’t forget to break in the new tweeters. Run them continuously for a few days to work out the mechanical manufacturing stresses and they will sound even better.
Yes definitely...I ran them for 4 to 5 hours last night and another 4 or 5 so far today.
I have the Anthem amv 60 so I'm thinking tomorrow I'll take some run at them with ARC and take a look at what they're doing in my room.
They are definitely a step up. -
Hey I have a question...
I have a set of monitor 10 series II with what I believe are the 2500 tweeters.
I'm not sure but it's my understanding that I can swap them out for the 3000's.
If so is this a worth while upgrade or should I even bother with it..?
Thanks in advance. -
Thanks in advance.
RD-0198 -
I understand that the 198's are the absolute best choice for tweeters but I have a set of 3000 that are now unused.
Wonder if they would be a significant upgrade over the 2500.
These speakers are in a non critical listening area. -
@ddog, these are the rankings from the “tale of five tweeters” sticky thread. I’d pop the 3000's in and see if you like them better...
Build Quality
1. RD0198
2. RD0194
3. SL3000
4. SL2500
5. SL1000
6. SL2000
Frequency Response
1. RD0198
2. RD0194
3. SL3000
4. SL2500
5. SL1000
6. SL2000
Harmonic Distortion
1. RD0198
2. RD0194
3. SL3000
4. SL1000
5. SL2500
6. SL2000
Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩 -
Hey thanks for the chart... I think I'll give it a try.
I'm thinking I should use the best that I have on had.
Hey how'd you make out with you DIY wave-guides?
Here's one that I made...
Hey @ddog loving this thread! Looking good! Hey one thing I noticed on the pic's of the tweeters installed, looks like a bit of deflection on the plastic around each of the screws. Did you put a spacer in between the backside of the tweeter at each screw hole location?
Not sure if the 198's are the same, but the 194's that I used was did not have the molded in spacer. Result is you have a gap between the backside of the mounting plate and the enclosure. Easy fix with a small washer.
May want to check it out.
Check out my thread, page 4, about 1/2 way down.
https://forum.polkaudio.com/discussion/183597/the-sda-srss-have-landed-at-verbs-house/p4Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Hey that looks perfect! I am slow, currently refinishing a Klipsch rig for my brother's HT. My 3.1's are next. Glad you got a head start and have given me some good inspiration! 👍🏻Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩 -
That's some great advice..
But no I didn't put the washers on but man I need to.
I hate it when I overlook things and have to back at it....
That will help eliminate the crush look from the screws.
I used thin rope style foam as a gasket. It works great and is air tight.
Also I used a paste pipe dope...comes in a tube... in all of the screw holes when installing the drivers.
Makes them air tight and locked them into their holes.
Will the loctite prove problematic in the event that the drivers need to be removed for some unforeseen reason? -
Believe blue is preferred when you may need to remove in future- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'd think not since it is made for metal to metal gluing not metal to mdf. -
Get them off those risers and forget the caster idea. You want spikes.Political Correctness'.........defined
President of Club Polk -
Love this thread too, and ddog is a very pleasant man. He knows how to listen to the lessons learned by others. Few and far between these days.
ddog, your speakers will look great."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
I wouldn't use thread locker with Hurricane nuts. If you do the H-nut might turn in the MDF before the screw turns in the the nut. That would cause lots of headaches of you need to remove a driver in the future.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
There's no reason to use thread locker, period.Political Correctness'.........defined
The pipe dope isn't so much a thread lock as it is a sealant to make sure theres no air escaping from the hole/s. Theres a lot of pressure inside these cabinets.
Plus the putty is very moist and creamy. I'm thinking as old and as dried out (i live in the Mojave desert) as these speakers are, I figured the would will soak it up like lotion to your skin.
I've used this on all my speakers that I've been inside of and have never had a problem with disassembly at a later date -
Would you mind pointing me in the right direction to check out this Hurricane nuts you guys keep talking. I really think I need to get some.
BlueBirdMusic wrote: »Love this thread too, and ddog is a very pleasant man. He knows how to listen to the lessons learned by others. Few and far between these days.
Thank you sir...
You guys are a really great bunch of people. One of if not the best forum I've been on.
These speakers are fantastic. Never know they could be so hot rod'd... really learning a lot here.
Thanks guys -
Ok so heres the scoop....
My theater has two rows of three seats.
1st row on the ground and 2nd row on a 12" riser.
Ear hight is 43 in 1st row and 53 2nd row.
So I set up the room so all tweeters in the bed speakers are at 47".
This is just about halfway between the two rows.
Tweeters in the 3.1TL's are at 17"....
So long story short, I've ditched the the feet and the casters.
Since I love the mid bass slam of these speakers I've decided to set them on top of HSU mk15hp's running in stereo. This has proven to be a wicked setup!! Also moves my speakers to my 47" tweeter hight as well.
The theater it 7.4.2 , 2mono subs and 2 l&r stereo subs. -
There's multiple formulations of the Loctite/Permatex/Henkle thread sealer just as there's different varieties of the infamous "Power Grab" construction adhesive.
565, 567, and 592 are the most common. Each has their place, although I tend to use the 592 in automotive work. These sealers have an "anaerobic hardening" characteristic somewhat like thread lockers, but on a much more mild scale. They do an EXCELLENT job of sealing pipe thread, and head bolts threads that go into the water jacket of an engine.
They used to advertise these sealers as "PST"--Pipe Sealer with Teflon. I suspect they aren't using genuine Teflon any more, which is why the PST label kinda went away.
Any one of those items will be fine for sealing the screws that go into the Hurricane nuts (if a person thinks it's needed in that application. I don't.) Directly into wood...I have my doubts that you're gaining anything. Since wood is porous, the anaerobic hardening is never going to happen. -
Oops, thought you had 2.3TL'S. Anyway, putting anything on top of a sub is not a good idea.Political Correctness'.........defined
The sub I quit a bit larger then the speakers and being as how the 3.1's are 100lbs...
I'm purty sure I'm gtg... -
I once placed @lightman1 on top of a sub... Didn't work out to well
We need pics of this beastly setup- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Most definitely... depending on how long they keep me for overtime tonight i'll get some tonight...
