LSi7's on the chopping block
This is just a note - not gospel. The woofer looks a lot like the MCM Audio 55-1862 or something in that series. MCM is now Newark and obviously things have changed since 2011.
That the label on the woofer starts with 55 (5534-2). Maybe...Aaron
Enabler Extraordinaire -
The tweeter is the XT32...
Woofer is made for Polk with their super aerated poly cones. To my knowledge this cant be sourced anywhere else and Polk no longer makes it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well, then I can quit looking!
I like to figure out the crossover logic and without the cone specs it's not easy. The crossover is really very basic. The 16.5 uf and .5 ohm in the woofer crossover are a Zobel network so the basic woofer crossover is just an inductor. I'm guessing the 2.5 ohm is just to knock the tweeter down a notch or two (padding) and then it's a simple second order setup.
that 1.3mH inductor is what's weirding me out. It just seems too big but those dual ports are also messing with simple calculations.
I'll stop with the "figuring it out" aspect and tonight, with a little luck, may get these done.Aaron
Yeah my understanding (redundant) is that the small port (ARC) which is intended to minimize the effect of an internal standing-wave resonance by vibrating at the same frequency as the standing wave, but out of phase with it.
Done.
Time for breakin. The odyssey amp, Schiit saga have been off for weeks so they need a warmup. I’ll let them run all night on low volume.
But so far so good!Aaron
Opus D art....
Nice Aaron -
Yeah, nice
Input cup is working well and no sign of tarnish in the first 12 hours of use.
Looks like I need a spot or two of black paint in the old holes. Anyone know...nah, that’s too easy.
Aaron
lookin good!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Very nic Aaron!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Tweeter is the Vifa XT-25TG30-04
https://www.parts-express.com/peerless-by-tymphany-xt25tg30-04-1-dual-ring-radiator-tweeter--264-1016
Woofer is a Peerless unit (From several years back now) that is very similar to one in production still.
(minus magnetic shielding etc.)
https://www.parts-express.com/peerless-by-tymphany-830860-5-1-4-ppb-cone-hds-woofer--264-1080 -
Nice work, Aaron. Curious to hear your thoughts as you get more time on them.I disabled signatures.
Would be curious to see if Polk would recommend that woofer as a replacement. It looks similar but different- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Some time ago, I bought what Polk told me were the last two LSi woofers in Polk’s inventory and I was told there would never be anymore. They told me there were no replacements and once their inventory was gone a person would have to scab one out of another speaker or elsewhere find a used one. That’s all I know.
Shielding isn’t really needed.
Find another pair of these and I’ll hack up another. Also update the tweeter...?Aaron
24 hours of continuous play have gone by. I don't expect to call these broken in yet but its' a start. I'm streaming from a dedicated Roon server through a wired Roon bridge thin client PC to a Schiit Bifrost Multibit DAC. From DAC to the Odyssey Tempest and down to the Stratos dual mono amp. IC's are the Groneberg with WBT ends and speaker cables are newly minted Furez 2x10g wire with Furez silver ends. Speaker cables are new enough that more break in is probably required also. I have approximately 150 to 180 watts available per channel.
One of my "got to haves" is sound stage. I want the speakers to disappear. I'm not fussy about hearing things outside of the speaker physical plain but if that happens it's nice. Mid and Treble are what I'm watching on these as I don't expect bass to come booming out. They just aren't designed for that. My concern is that with the slight variance in component value and the much lower DCR in the inductors I might have affected the freq response, crossover point or caused overall oddness.
I haven't had these long. Didn't listen for hours to get a baseline so there will be no comparison to what they were before the operation.
Sound stage is where I want it. The speakers are gone. Even with lights on and eyes open they are just gone. Normally I listen with the lights down and with these it matters not. I do have some soundstage outside of the speakers. These are not in an optimal listening position so I wonder what would happen should they go front and center.
I'm not hearing any "holes" in the frequency spectrum. I don't have an analyzer but so far I've not heard anything deficient. The only slight complaint might be a very slight mid-range hump, a bit of bloat, but that could be because the components aren't broken in yet (had the same issue with the Yggy DAC and it did eventually even out). Also see above about listening position.
These are very pleasant to listen to. I think the word that comes to mind is "smooth". No harsh edges. The treble is wonderful. Crips, clear and precise. Mid range and voices are also very good. Possibly a bit forward...(see the "hump" comment from above)? Just a thought - it's possible these are a bit over engineered for bookshelves with the dual porting going on and the bi-amp feature from pre-mod.
So...is the forwardness of the mid...upper mid from the room, not being broken in, new speaker cables, something in the chain? It's not offensive and my thought is that I'm overloading the room acoustics in the position they are in as bringing the volume down tames it considerably.
Bass is unchanged - there were no miracles. If you want the bottom basement boom these will need a sub. Again, I'm not looking for these to do that so no complaints.
Ultimately my goal was to provide a speaker that I can use to compare the changing of components with. This rig is open and far enough from the wall that I can get to all the cables without becoming a contortionist.
As time goes on I'll voice in here again.
Aaron
Yes it fits exactly the cone is "different", but not all "that different".
Have not tried them personally, but what we heard from a friend, he said he thought they were extremely close, but was not "Sure" if identical, but live too far to hear what he made.
He bought them for a DIY project, and said they were excellent, and maybe a bit better than the LSI specific woofer, for whatever that is worth, so doubt they are a downgrade anyways.
Yeah we thought about parting out one of our Lsi15's pairs so that would make 4 available, but have a nostalgic liking to them, so still have not done it. -
That is what I have heard also, but not really sure of its effectiveness.
Stereophile measured oddities in the response that are at the same frequencies, that the ARC port has oddities..... -
In my experience, the shape and depth of a cone can alter just about everything from a speaker- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
It would be unfortunate to part out a good pair of 15’s. Enough things happen so that speakers get parted out from time to time anyway -
48 hours in:
Bass is beginning to fill in. Not the lower 48 type of bass but a nice warm bottom (oh good grief - that's gonna get some remarks!), so again, no miracles.
That mid range flair has settled down. I still think it's got a lot to do with overloading this room/position at volume.
No listening fatigue at all. I've been buried in the basement (my option) all day trying to figure out a DAC that won't DAC and putting some nifty cables together for Victor. No desire to put the main rig on.
The treble is mesmerizing and almost holographic. Bullseye on that.
Midrange is no slouch at all.
So what I have here is a nice smooth but detailed top, good mid presence and a nice warm bottom.
Aaron
Niiiice, Aaron. Stuff like this inspires me to try crossover mods. I'm not brave enough to invert binding posts though. That's just sheer lunacy!I disabled signatures.
You should step out of that comfort zone Scott -
LSi 7's stock have a very non-fatiguing and listen all day type presentation, but it sounds like you upped the ante on these. I always preferred the 7's to the 9's stock. Keep us posted.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Excellent! Glad to hear they are meeting/exceeding expectations! Im sure in 200 hours they will sound a little more of everything you are already hearing!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Over 200 hours one 'em (last notes unless something changes).
Better bass presence and just an overall smoother listen. Things appear to be settled in. The holographic, 3 dimensional effect is more pronounced.
The room overload still occurs. Volume at about 9 - 9:30 is good. Anything past 10 makes listening uncomfortable (then again I'm getting over some disease that I've had since Thursday so my head might still be on crooked.) I don't think padding the tweeter down further would help, it's not that far into the upper ranges. Upper mid maybe... The last 2 notes in the 3 note piano lead in on Norah Jones, "Don't know why" is overload. Bring the volume down to 9ish and it's fine.
As an experiment I covered the front ports with some high density foam held down by packing tape. Just gets screechy so unless you like screechy don't do that!
OH! and no corrosion on the binding posts.
Aaron
A little corrosion on the binding post will help pad the tweeter..... just sayin
Many little rubber baby buggy bumpers underneath the speakers
Listening right to left. Note the cabinet behind the chair hence my suspicion of room overload.
Aaron
