Help with speakers for Dolby Atmos setup in a 5.1.2
Hello guys, im new on the forum, am only a novice in speakers and proper calibration. My setup is:
Polk Monitor 65T fronts (2)
Polk Signature S35 center (an upgrade from TSx150c, which i still got)
Polk TSi100 bookshelf surrounds (2)
BIC America F12 12-inch subwoofer
Onkyo TX-NR787 receiver (just upgraded from Yamaha RX-V475)
TCL 55R617 4k hdr tv
The chain of events is as follows, I had a Vizio 1080p tv with the yamaha and listed speakers, which worked magnificently. Then I upgraded to the TCL 55R617 tv, which i found out is not compatible with the yamaha receiver i had. A thorough look through forums informed me that the TCL and Yamaha have a "handshake" issue in which it would not pass through the propet audio formats and also make the tv screen flicker consistently after an hour of use. So i then sold the yamaha and got the Onkyo TX-NR787 two days ago. A significant upgrade over the yamaha. My yamaha being a 5.1 limited my options, but with this Onkyo 9.2 (9.1 really since the other sub input transfers the same signal to both) I'm able to do much more. My plan is to Bi-wire the front monitors and then with the remaining two channels purchase two add-on Dolby Atmos speakers, making it into a Bi-wired 5.1.2 system. Yet right now im at a loss as to which add-on speakers to get that would timbre match my current setup. There are the Onkyo SKH-410 being the cheapest option at $90, followed by the sonys SSCSE addons at $160, then the NHT Atmos addons at $200 ($100 each). Which is where my budget stops.
If anyone may give me some insight as to what are my best options for this? Or what speakers may i add that are in my $200 budget, i would highly appreciate it. Thanks.
I'd say save the coin for another upgrade.
Yes, you are right, i meant to say bi-amp. But i do not understand what do you mean by that an AVR cannot do it? In the attached screenshot of the NR787 it clearly shows how one may do so, as well as right there on the amp itself.
Ahh i see, thats good to know. Then if not atmos, what kind of upgrade may i do where i may utilize the remaining two channels? Or perhaps something i may unaware of
Right now it looks like you have a good 5.1 system. Yes you can add ATMOS speakers and make it 5.1.2. Just remember every time you add more speakers that drains more power from your ONE power supply.
In HT systems it is best to try and match all your speakers to the same manufacture and product line. For surrounds and effect speakers it does not matter that much. Most AVR come with good calibration programs that will EQ them in the system.
Family Room:
Samsung UN75RU710DFXZA,
Denon AVR-X4400H, Emotiva XPA3 GEN3
Oppo BDP-93,Sony UBP-X800BM, WD Live HUB.
Main: Polk LsiM 705
Center: Polk LSiM 704C
Front High/Rear High In-Ceiling Polk 80F/X RT
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Marantz SR5010, BDP-S270
Main: Polk Signature S20
Center: Polk Signature S35
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Sony 2100ES AVR, Sony DVP-NS3100ES for disc
Cerwin Vega AT-12 (blasters) Advent Prodigy (listening)
Old sony 12" Sub
Mini tower PC with 400GB of music
Like @mrloren said, it’s marketing, no more. You are of course free to do as you please, but there will be not sonic benefits, perhaps even sonic deficits.
Game Room HT: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology SM450; Definitive Technology LCR2000; Definitive Technology StudioMonitor350; Mirage Nanasats; Sub - HSU VTF-2 MK5
Master Bedroom
Cambridge Azur 551r; Definitive Technology promonitor 800; ACI Titan Subwoofer
Which is a great idea actually, which ones would be good to go with?
That Media Bidge wire is not that great @ 16AWG. I find the starter wire to be Monoprice/Amazon Basic 12awg. You can go up from there. Doug's Furez is darn good wire https://douglasconnection.com/Raw-Speaker-Cable_c33.htm Doug's a forum member and gives discounts to fellow members. I went from the Furez to Audioquest Type 4.
Audio Advisor has "No frills" AQ wire for a good price https://www.audioadvisor.com/products.asp?dept=26#/filter:brand:AudioQuest$25C2$25AE
I'm currently using AQ Type 4 for my front 3 speakers and have Monoprice 14awg going to my surrounds and Belden 16awg to the ceiling speakers. In my bedroom HT I have Furez for the front 3 and 14awg Monoprice to the surrounds. Both systems sound great.
One thing is on this forum. We will help you spend all your money. Once done you will have an empty bank account and an awesome HT.
Family Room:
Main: Polk LsiM 705
Surrounds: Polk S15
Sub: HSU VTF3-MK5
Bed Room;
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Old sony 12" Sub
Ditto on that haha. I was unaware that good wiring can get so darn expensive. Yet some necessary changes must be done. Thanks for the eye opener on that one. Think ill go with these spades I found on ebay they seem to be from a reputable enough seller. As for the wires I'm gonna replace the fronts + center, and the sorrounds will leave be, as they are too much of a hassle to even touch lol. A question, if I leave the 16awg on the sorrounds and put 12/14awg on the rest, that would be alright? and also, i ran across so called terminal caps for the receiver, is that a thing or just a gimmick?
