Balanced XLRs - 1m
Clipdat
I'm giving these a try, haha: https://www.monoprice.com/product?p_id=33837
Nooooooooo!
How bad can they be? I've used their lower end XLRs with great results: https://www.monoprice.com/product?p_id=4754
Nooooo chip. Noooo
Don't knock it till you try it!
I'm using the cheap Monoprice ones with good results. An upgrade is on my to do list but pretty happy with what I have for now.Gustard X26 Pro DAC
@zingo
In typical Monoprice fashion, these turned out to be a fail on quality control. They should stick to their cheaper lines, because these $30/meter cables have issues.
I initially ordered two cables (via Amazon, so in case I needed to, I wouldn't have to deal directly with Monoprice for returns - this proved to be useful) and when they arrived one of them was fine and the other had a loose barrel on the male pin side. It looked like the barrel's set screw had been slightly cross-threaded during assembly. As a result, there was a very slight rotation of the barrel possible when you attempted to twist/turn it. Probably a non-issue for most, but if I'm paying $30 plus tax for a "premium Monolith" cable, I'd like for it to not have any defects.
I returned that cable, and ordered another - hoping that the new arrival would match the first one that didn't have any issues. It arrived today and visually it looked like the male pins were not aligned correctly inside the barrel. I confirmed this by doing a test plug and because the pin angle/placement is off from their tolerances, the cable has to be held at an angle to get it to plug into something. Another unacceptable quality control issue.
So at this point I threw in the towel and decided to return all of them.
That concludes my failed experiment with Monoprice Monolith XLR cables. -
If you want excellent XLR’s for great prices, go to Douglasconnection...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I went with Audioquest.
Red river?
If you want cheap price but not cheap product, Signal Cable. I own their XLR cables. The quality is very good.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
joecoulson wrote: »Red river?
No, King Cobra. -
Wireworld also has a budget line of which is good quality.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Mikey081057 wrote: »Wireworld also has a budget line of which is good quality.
I have a physical aversion to the materials that Wireworld uses in the construction of their cables. I cannot tolerate the persistent/constant smell that their PVC jackets off-gas. -
I told you before to stop sniffing cables.Political Correctness'.........defined
President of Club Polk -
At least it is somewhat safer than his old habit of huffing paint fumes...
Isn't smelling things that aren't there a sign of a brain tumor?Gustard X26 Pro DAC
burning feathers.
Can't find the clip I want, so this one'll have to do...
https://youtu.be/A34ZBDE3AhE
I wasn't sniffing them.
Their repugnant odor was easily filling my 13x10' bedroom and I could smell them from my listening position 9 feet away from the rack. -
Must be that skunk fur they use as insulation material...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Must be that skunk fur they use as insulation material...
https://en.wikipedia.org/wiki/Polyvinyl_chloride
https://en.wikipedia.org/wiki/Phthalate -
Could you imagine busting wind thru some pvc tubing?My New Year's resolution is 3840 × 2160
@zingo
Ya, I am not going back to monoprice, even with a history of some great product experiences. -
I can attest to the smell that comes with Wireworld cables. Certainly is at least evident when I walk into my listening room but it doesn’t bother me2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
I think I paid a bill for 2 pairs of BJC's. I have never been disapointed with their products.
Wireworld has always been my upgrade path but I smoke fine stinky cigars -
/end rant"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
https://www.youtube.com/watch?v=7WAwuSK36Gw
