Balanced XLRs - 1m
Looking for balanced XLRs, two pairs, 1m.
    Clipdat Posts: 13,100
    How bad can they be? I've used their lower end XLRs with great results: https://www.monoprice.com/product?p_id=4754
  • joecoulson
    joecoulson Posts: 4,943
    Nooooo chip. Noooo
    Don't knock it till you try it! :)
    audioluvr Posts: 6,011
    I'm using the cheap Monoprice ones with good results. An upgrade is on my to do list but pretty happy with what I have for now.
    edited March 2019
    Clipdat wrote: »
    I'm giving these a try, haha: https://www.monoprice.com/product?p_id=33837
    @zingo
    In typical Monoprice fashion, these turned out to be a fail on quality control. They should stick to their cheaper lines, because these $30/meter cables have issues.
    I initially ordered two cables (via Amazon, so in case I needed to, I wouldn't have to deal directly with Monoprice for returns - this proved to be useful) and when they arrived one of them was fine and the other had a loose barrel on the male pin side. It looked like the barrel's set screw had been slightly cross-threaded during assembly. As a result, there was a very slight rotation of the barrel possible when you attempted to twist/turn it. Probably a non-issue for most, but if I'm paying $30 plus tax for a "premium Monolith" cable, I'd like for it to not have any defects.
    I returned that cable, and ordered another - hoping that the new arrival would match the first one that didn't have any issues. It arrived today and visually it looked like the male pins were not aligned correctly inside the barrel. I confirmed this by doing a test plug and because the pin angle/placement is off from their tolerances, the cable has to be held at an angle to get it to plug into something. Another unacceptable quality control issue.
    So at this point I threw in the towel and decided to return all of them.
    That concludes my failed experiment with Monoprice Monolith XLR cables.
    nooshinjohn Posts: 26,063
    If you want excellent XLR’s for great prices, go to Douglasconnection...
    I went with Audioquest.
  • motorhead43026
    motorhead43026 Posts: 4,051
    edited March 2019
    If you want cheap price but not cheap product, Signal Cable. I own their XLR cables. The quality is very good.
    joecoulson wrote: »
    Red river?
    No, King Cobra.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Wireworld also has a budget line of which is good quality.
    Garage | Polk Monitor 5B's
    I have a physical aversion to the materials that Wireworld uses in the construction of their cables. I cannot tolerate the persistent/constant smell that their PVC jackets off-gas.
    F1nut Posts: 52,151
    I told you before to stop sniffing cables.
    At least it is somewhat safer than his old habit of huffing paint fumes... ;)
  • Mikey081057
    Clipdat wrote: »
    Isn't smelling things that aren't there a sign of a brain tumor?
  • Mikey081057
    mhardy6647 Posts: 35,375
    audioluvr wrote: »
    Clipdat wrote: »
    burning feathers.
    Can't find the clip I want, so this one'll have to do...
    https://youtu.be/A34ZBDE3AhE
    I wasn't sniffing them.
    Their repugnant odor was easily filling my 13x10' bedroom and I could smell them from my listening position 9 feet away from the rack.
    Clipdat wrote: »
    Must be that skunk fur they use as insulation material...
  • Mikey081057
    Clipdat wrote: »
    https://en.wikipedia.org/wiki/Polyvinyl_chloride
    https://en.wikipedia.org/wiki/Phthalate
    Could you imagine busting wind thru some pvc tubing?
  • zingo
    zingo Posts: 11,258
    Clipdat wrote: »
    Clipdat wrote: »
    @zingo
    Ya, I am not going back to monoprice, even with a history of some great product experiences.
  • stangman67
    stangman67 Posts: 2,330
    I can attest to the smell that comes with Wireworld cables. Certainly is at least evident when I walk into my listening room but it doesn’t bother me
  • Mikey081057
  • afterburnt
    afterburnt Posts: 7,892
    I think I paid a bill for 2 pairs of BJC's. I have never been disapointed with their products.
  • afterburnt
    Clipdat wrote: »
    Wireworld has always been my upgrade path but I smoke fine stinky cigars
    heiney9 Posts: 25,580
    edited March 2019
    /end rant
