SDA 1C & Parasound A23 running in mono?????????????????
Just a quick question for the forum; Can i use two A23 amps in mono to power my 1C's?? One for each speaker that is. Does running this in mono make it non common ground? I am in on the dreadnought purchase and waiting for delivery. So with the dreadnought should i be OK? Please some thoughts.
Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh"
  • gyosa
    gyosa Posts: 699
    I’m using an A21 on my 1c’s...
    Just curious , does a single A23 in stereo provide you enough current and power for your 1c’s?
    BK
    Dayens Ampino , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
    PS Audio S300 - sitting in the closet for now …
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
  • Emlyn
    Emlyn Posts: 4,373
    The A23 is only compatible with minimum 8 ohm loads when used bridged mono, so not a good idea even with the transformer. The transformer is necessary with mono amps if they do not share a common ground. A single A23 run in stereo mode would be sufficient for 1C speakers unless really pushing them hard.
  • Manticore
    @Emlyn thanks for pointing that out. I just read that at the bottom of page 18 in the manual. I think 1C's are 6ohm or less. I just wanted to replace my 1500a amp. Since the A23 has 15 amperes less per channel & less watts per channel 125 to 205 i was thinking of going the mono route so there would be no noticeable loss in current & power. I guess it was a decent thought. :|
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    pitdogg2 Posts: 24,583
    You will also be raising the noise floor running them bridged.
    I'd pass on that idea.
  • Emlyn
    Emlyn Posts: 4,373
    I'd use the 1500a on SDAs unless going bigger like with an A21. The 1500a is a very good sounding amp itself with SDAs, and plenty powerful for most speakers. I keep one around for occasional use myself.
  • motorhead43026
    I dumped my brand new A23 for a HCA-1500 to drive my SDA2B's. The difference was quite obvious.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • Manticore
    So you noticed that big a difference. If i may ask what was missing?
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • Manticore
    Emlyn wrote: »
    I'm starting to have minor problems with the 1500. Right side channel is cutting out. If i put my hand on the ic cable and try to move it a bit the sound comes back on. Right channel problem only.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
