SDA 1C & Parasound A23 running in mono?????????????????
Just a quick question for the forum; Can i use two A23 amps in mono to power my 1C's?? One for each speaker that is. Does running this in mono make it non common ground? I am in on the dreadnought purchase and waiting for delivery. So with the dreadnought should i be OK? Please some thoughts.
Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh"
  • gyosa
    gyosa Posts: 770
    I’m using an A21 on my 1c’s...
    Just curious , does a single A23 in stereo provide you enough current and power for your 1c’s?
    BK
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • Emlyn
    Emlyn Posts: 4,885
    The A23 is only compatible with minimum 8 ohm loads when used bridged mono, so not a good idea even with the transformer. The transformer is necessary with mono amps if they do not share a common ground. A single A23 run in stereo mode would be sufficient for 1C speakers unless really pushing them hard.
  • Manticore
    @Emlyn thanks for pointing that out. I just read that at the bottom of page 18 in the manual. I think 1C's are 6ohm or less. I just wanted to replace my 1500a amp. Since the A23 has 15 amperes less per channel & less watts per channel 125 to 205 i was thinking of going the mono route so there would be no noticeable loss in current & power. I guess it was a decent thought. :|
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    pitdogg2 Posts: 27,642
    You will also be raising the noise floor running them bridged.
    I'd pass on that idea.
  • Emlyn
    Emlyn Posts: 4,885
    I'd use the 1500a on SDAs unless going bigger like with an A21. The 1500a is a very good sounding amp itself with SDAs, and plenty powerful for most speakers. I keep one around for occasional use myself.
  • motorhead43026
    I dumped my brand new A23 for a HCA-1500 to drive my SDA2B's. The difference was quite obvious.
  • Manticore
    So you noticed that big a difference. If i may ask what was missing?
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • Manticore
    Emlyn wrote: »
    I'm starting to have minor problems with the 1500. Right side channel is cutting out. If i put my hand on the ic cable and try to move it a bit the sound comes back on. Right channel problem only.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
