8' Bi-Wire speaker cables w/ bananas
Clipdat
Looking for a pair of 8' bi-wire speaker cables with bananas on all ends. Thanks.
Anyone tried these ELAC Sensible Speaker Cables? https://www.elac.com/series/sensible-speaker-wire/
@AndrewJones
Edit: Nevermind, looks like they don't come in bi-wire. -
SVS' SoundPath cables get great reviews, and are fairly cheap ($90ish for a 12 foot pair). I think you can get biwire cables, and you can choose your ends (pin, banana, or spade, or a mix of all the above).
I'm planning on getting a pair in the nearish future, so when I do I can tell you what I think.
8ft banana biwire.... sounds so familiar.... This sounds like exactly what I have.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
This was recommended to me earlier today, but I'm not big on spades: https://www.usedcable.com/audioquest-aspen-biwire-spades-10ft-3m-pair-speaker-cables.html -
mlistens03 wrote: »SVS' SoundPath cables get great reviews, and are fairly cheap ($90ish for a 12 foot pair). I think you can get biwire cables, and you can choose your ends (pin, banana, or spade, or a mix of all the above).
They do not appear to be available in bi-wire, unfortunately. -
Darn. Sorry!
You may want to try calling SVS, as they will do all kinds of custom lengths and such and may do a biwire for you as well. -
I also have the aspens but I have not used them as I was waiting for my tube monoblocks to utilize them in conjunction w my main system as a secondary
Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
The Aspens definitely sound interesting, and I probably would have been willing to deal with the spades if they were 8ft instead of 10.
Edit: Oops, posted too soon. I see the Audiogon listing now, interesting. I searched and saw the thread of yours where you were trying to run them and how ridiculously stiff they were. Not sure I want to go down that route with speaker cables. It looked like you had even more room to work with them than I do and they were still a chore. -
What’s your rack situation look like?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Pretty close quarters, not a lot of room for bends. I'll take some photos tomorrow of how the Bedrock cables are currently. -
what's your budget?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Ideally 1k or under.
Nordost. Purple. Two sets.
The banana jacks are crap.Anyone tried these ELAC Sensible Speaker Cables? https://www.elac.com/series/sensible-speaker-wire/
@AndrewJones
Dan
i would go the best quality single wire i could afford with jumpers.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
^^thisPatriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
Hey Drew,
I can make you a 8 ft. pair of our Alpha Bi-Wire speaker cables with Furutech FT-212R banana plugs on both ends for well under your 1K budget. (You'll also get your 10% Club Polk discount) I'll give you a guarantee that if they don't like them I'll give you a full refund too. I'll break them in on our Audiodharma cable cooker so when you get them it'll only take about 10 hours to settle into your system. About 2 weeks before I can ship.
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
helipilotdoug wrote: »Hey Drew,
Could you explain more about how the Furutech "locking" plugs work?
Gotta love a money back guarantee. -
I’ve said it before I and I’ll say it again...
Thanks Drew. The Furutech 212 banana plugs have a black barrel that you twist clockwise to lock. What happens is a pin inside the plug pushes forward inside the split plug, expanding it tight against the inside of the binding post. When you want to remove them, just twist the black barrel counterclockwise allowing the pin to come back and release the pressure. Hope this helps. Please let me know if you have any other questions.helipilotdoug wrote: »Hey Drew,
Gotta love a money back guarantee.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Still looking. Hard to find that perfect speaker cable that ticks all the boxes for me.
Kimber Kable 8VS or 8TC....
It go big w the 12VS/12TC.
Can be biwired"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Kimber Kable 8VS or 8TC....
Can be biwired
Why the heck does the cable look so nice, but those bananas that they use look so cheap and dinky?
Supra Quadrax or dh labs q10
Best connection is bare wire, go for it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
https://silversonic.com/products/speaker-cables/q-10-signature/
Looks cool. -
From PMC's FAQ page:
What speaker cable should I use?
PMC recommend using a high quality thick multi-strand Oxygen Free Copper (OFC) cable between the amplifier and speakers. The use of ‘exotic” cables has limited improvement on sound quality, so we would not advocate spending great quantities of money. However, if you are prepared to spend a great deal of money in this area, we would strongly advice you listen first to determine whether the outlay is worth the improvement.
PMC primarily designs studio monitors so it could be the stereophonic qualities higher end cables can bring are of no concern to them.
Perhaps, but clearly there is some synergy to be found here, as evidenced by how poor the low listening level bass was with the MITs, but how excellent the locked in center image and ultra detailed treble and palpable midrange was.
Conversely, how the low volume level bass returned with the Audioquest cables, but the imaging dispersed and the treble and mids became much more localized to the speakers themselves.
Interestingly, PMC also has a statement about amplification in their FAQ:
"What amplifiers do we recommend?
At PMC we use Bryston amplifiers for who we are the UK supplier. As our speakers have been developed using their amplifiers and visa-versa, the combinations offers good synergy and excellent results, and we would recommend you audition Bryston amplifiers with our speakers if possible.
The ideal amplifier should have enough power in reserve to reproduce powerful transients present in many forms of music. It is easier to damage a loudspeaker with a low powered amplifier driven too hard and producing a distorted signal than with a high power amplifier with plenty of power in reserve. Please consult your dealer if in doubt."
