Polk SDS CRS+
Hi all
I just picked up a pair of Polk SDA CRS + early model with twin blade IC. I ordered the twin blade connector from ebay yet not received it. I hooked up these speakers with my Sansui 5000X without the IC and it sounds really very good and waiting to listen with IC. I have one question should I replace the original SL2000 tweeter with RD0-194?
Polk SDA 1C and CRS+, Klipsch Forte II, Focal Chorus 706, Sansui: 9090DB, Eight Deluxe, AU-9900; Pioneer SX-1010, Marantz: 300DC, 3200B, 2325, 2275, Thorens TD-145, Technics SL-1650, Pioneer PL-707, Pioneer RT-707
  • FestYboy
    FestYboy Posts: 3,861
    edited February 2019
    get the IC and start shopping for new caps/resistors.
    Edit for not remembering early CRS+ were blade-blade.
  • Dr_Wu
    Dr_Wu Posts: 356
    Yes on the tweeters, and the other upgrades/updates listed in the SDA Handbook. You won't regret it.
    Tony M Posts: 11,676
    Remember the equal sided triangle for your listening spot. They'll sound great anyway but when the speakers are ..say 9 ft. apart to their centers, you should be 9' from their centers away also. You'll not believe how expansive the sound-field will be. Sounds will come from the sides of your room sometimes. :DB)
    There is a thread of songs that highlight what SDA's can do. Search SDA playlist. Here it is. I found it quickly!
    https://forum.polkaudio.com/discussion/22736/sda-playlist/p1
    Congrats on getting some very special speakers from Polk audio's early years. B)
    F1nut Posts: 51,889
    Sanjib_a wrote: »
    Hi all
    You have the original SDA CRS two tweeter version, they are not the + version. You cannot use them with a non-common ground amplifier.
    Toolfan66 Posts: 18,127
    Sanjib_a wrote: »
    Hi all
    https://us.v-cdn.net/5021930/uploads/attachments/1/8/5/1/1/26707.pdf
    Nope there is a B/B version... Mine was the same way, I modded mine to be the later version so I could TL them...
  • westmassguy
    westmassguy Posts: 6,850
    The 84' CRS was 2nd generation, had two tweeters, blade/blade IC. The 86' CRS+ was 3rd generation, blade/blade, single tweeter, same as SDA-2A. 87' & 89' CRS+ were 4th generation, pin/blade, single tweeter.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    F1nut Posts: 51,889
    My reading comprehension in this thread was lacking. I thought I read twin tweeters when it was twin blade. DOH!
    xschop Posts: 5,286
    You get a pass. A stint in solitary confinement takes a mental toll.
  • westmassguy
    No worries Jesse. I'm O -, JIC
    F1nut Posts: 51,889
    xschop wrote: »
    As I've stated previously, when I'm wrong I admit it unlike some on this board who think they are never wrong even while getting told from multiple people that they are wrong. That is the difference between an honorable person and piece of scum.
    pitdogg2 Posts: 27,170
    Shoot I'm always wrong....
    I play fast and loose with the facts... B)B)
    SCompRacer Posts: 9,121
    Not true, or you would be a, gasp, politician . :D
    xschop Posts: 5,286
    xschop wrote: »
    Snowflake logic is difficult to decipher. Some may be perfectly content being in err, whilst others are bonafide ignorant.
    Post edited by xschop on
  • Thank you all!
    My speaker is one tweeter version with blade/blade IC. I will get the IC cable on 02/13.
    Meanwhile I like the sound so much even without IC, I picked up another pair with pin/blade connection. But I discovered a problem with this pair. Left channel speaker playing much louder than right channel. Then I figured out that the normal driver in the right channel is not working (SDA driver is fine). I took out the woofer and checked it is in good condition. I took out the crossover board from the cabinet found the L1 solenoid 2.5 mH 20GA is no good. Now I need help to replace this solenoid. First can anyone tell me how to separate the crossover circuit board from base big solenoid? There are 4 little white clips and how you open that? Anyone has any video then it will be of great help. Lastly how can I get that replacement solenoid?
    May be too many questions I asked!!!!
    xschop Posts: 5,286
    Your "solenoid" terminology you use is what we call an inductor. Check the specs on the wiring diagrams somewhere here and order accordingly.
  • Dr_Wu
    Dr_Wu Posts: 356
    You can squeeze the 4 segments of the tips of those stand-offs with a needle-nosed pliers. The plastic disc can then be slipped over the compressed post.
  • xschop and Dr_Wu: Thank you very much! I guess this is "air core inductor crossover coil". Am I right?
    Is it burnt or what? They don't just go bad.
  • pitdogg2: On end just broken near the board!
  • If I solder it will it be ok?
  • monepolk
    monepolk Posts: 1,154
    Personally I'd clean off the "new" end of all lacquer to clean copper and resolder into the old hole after removing "old" end if still soldered in the hole....
    But that's just me...
  • I just soldered the broken end and it is working!! Just trying to minimize the time!! Your suggestion is the best and correct one.
  • Since my second pair is pin/blade IC I am running it with with speaker wires as IC and what a sound! Why I didn't buy it before??? I will replace tweeters to get more out of it (it now sounds little harsh!). It is a great match with my Sansui 5000X! Still waiting for blade/blade IC of my first pair.
  • What is the replacement inductor for SDA driver 1.5 mH 20 AWG? I could not find any 1.25 mH 20 AWG to buy online. Any help will be appreciated.
    Thanks!
  • FestYboy
    Get the 1.5 and unwind it till you reach spec.
  • Festyboy: thanks!
  • I am planning to do the recapping of my CRS+ (pin/blade IC). I have noticed that there is a 750 pF mica capacitor in parallel to 12 microF cap in tweeter circuit. Should leave it alone or I should replace it? If I need to replace it what will be the best replacement. Thanks in advance for any help.
  • FestYboy
    Sure that's not the poly switch?
  • Yes, I am sure it is not the poly switch. I have a blue poly switch which I am going to replace with a wire jumper.
