Polk SDS CRS+
    F1nut Posts: 52,150
    It's a bypass cap. Remove it and do not replace.
  • Okay, thanks!
    Polk SDA 1C and CRS+, Klipsch Forte II, Focal Chorus 706, Sansui: 9090DB, Eight Deluxe, AU-9900; Pioneer SX-1010, Marantz: 300DC, 3200B, 2325, 2275, Thorens TD-145, Technics SL-1650, Pioneer PL-707, Pioneer RT-707
    F1nut Posts: 52,150
    Replace the polyswitch with a .5 ohm resistor. The tweeter is too bright otherwise.
    pitdogg2 Posts: 27,553
    The 750 pF silver mica goes away with better film caps. Yes it should be bypassing the mylar caps.
    Replace the polyswitch with a 10-12 watt .5ohm resistor. Vishay-Mills are favored.
  • Thank you for the suggestion and I will follow the suggestions!
  • Is it okay to use Ceramic Cement Resistor for replacement of poly switch?
  • I am going to upgrade the tweeter with RD0198-1. Will it be also too bright with jumper wires replacement of poly switch?
    F1nut Posts: 52,150
    Yes. The circuit was designed with the resistance of the polyswitch figured in, which is roughly .5 ohms, so if you don't compensate for that the result will be a hotter top end.
    Mills resistors are far better than the blocks.
  • Thanks!
  • Should I replace the bypass capacitor or just take it out without any replacement?
  • Dr_Wu
    Dr_Wu Posts: 356
    edited February 2019
    No need to replace it given the performance of today's caps (I've been advised).
  • Thanks!
  • From where can I buy the inductors on the crossover? I searched but it is very difficult to get the replacement with exact value and wire gauge.
    Any help will be appreciated.
  • FestYboy
    FestYboy Posts: 3,861
    Not required unless they are damaged. Inductors don't wear out or change spec as they get older (unlike capacitors).
  • Finished the crossover and 4.1 TL. Huge difference in sound! Put sonicaps in tweeter circuit and clarity caps in woofer circuit. I am now really impressed with the sound!
  • Thank you very much to everyone for the help!
    I am geeting a Pioneer SX 1010 this weekend. Anyone has any experience of Polk SDA with this receiver?
    F1nut Posts: 52,150
    Why a receiver? Get a nice integrated or separates.
  • F1nut wrote: »
    Don't you like 70's Marantz , Sansui or Pioneer receivers? Just curious why you like integrated over those biggies?
    F1nut Posts: 52,150
    It's not that I don't appreciate vintage receivers, but you are not going to get the best sound out of them and therefore not the best out of the SDA's.
  • F1nut wrote: »
    F1nut:
    Now I am running these with fully restored Marantz 2270 and it sounds awesome. I bought SX 1010 to have little bit more power and it will be eventually restored. I have another pair connected to quite expensive new Denon receiver but I think my Marantz driving these speakers better than Denon though Denon is a receiver not integrated two channel stereo amp. What new integrated you suggest?
    F1nut Posts: 52,150
  • Thanks!
  • It is in my wishlist!
  • How is its little brother?
    F1nut Posts: 52,150
    That'll work perfectly.
