Looking for Misc Audio Deals of the Day? Updated info here!
That second one is a GREAT DEAL!! I'd get it.
That first one added to the second one, I agree with you Arty, that would be a GREAT set!!
for 140.00...WOW! Most people just listen to music and watch movies. I EXPERIENCE them.
It's too bad the trip for me is not possible at the moment... Otherwise...
PS Audio Noise Harvester (used)
6 available, $50 each Buy It Now plus shipping
no affil.
https://www.ebay.com/itm/PS-Audio-Noise-Harvester/202587972097?hash=item2f2b2f2201:g:CBAAAOSw7cZcWIiP:rk:1:pf:0 -
@Hermitism Do you use one (or more) of these? I've got a 60hz hum in my system and wonder if this would be a good thing to try. Does is just plug into the outlet to which the amp is plugged? Thanks.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
http://Vimeo.com/channels/stretchphoto -
I have not tried them. DK wrote a review of these and another product called an AudioPrism Quietline, which I believe he liked better. I'll try to find the thread for you.
Here you go:
https://forum.polkaudio.com/discussion/147134/studies-on-residential-power-line-noise-part-11-noise-harvester-and-quietline/p1
edit: Also, I think Joey used these as well. One or the other, I can't remember which. -
Thanks so much.
- Isaac Asimov
Hi-Fi
Visuals
Sometimes these can be useful for breaking ground loops. If you'd like to try it out, I have one that I'm not using that I can ship to you.
https://www.amazon.com/Ebtech-Hum-Ground-Voltage-Filter/dp/B0002E4YI8/ -
I use two of them and they are on the same circuit. They will not remove that hum you're referring to. That could be ground loop or power supply cap problem in your gear somewhere. Have you unplugged things one at a time to see what gets unplugged and the noise stops? Do you have cable TV going to any audio stuff? Does the hum go away if you disconnect the cable? If so the easiest way to get rid of it is re-terminate that coax cable at that location and NOT use the ground shield on the connection at that location.
the instructions from PS audio do say two on the same circuit will work much better. -
2 buck cheater plug.HT SYSTEM-
lsi 9's -
@clipdat i use a humX often when i dj. I always keep 2 of them in my wire bag. They have come in handy often at venues. You would be suprised how many places have bad grounding or dirty power. I also run a furman.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
https://chicago.craigslist.org/nch/ele/d/glenview-focal-jm-labs-home-theater/6810554850.html?lang=en&cc=gb
Someone needs to go grab these pronto.HT SYSTEM-
lsi 9's -
https://chicago.craigslist.org/chc/ele/d/chicago-infinity-kappa-61-speakers/6811995223.html
Good deal here for not a lot of scratch.
lsi 9's -
lsi 9's -
Two Pair in Atlanta. Each pair $200. Claims "Great condition." No affliation.
DCM TIMEFRAME TF400Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Used Dayens Menuetto with original box & remote control
Condition: 9/10 Excellent/Like New
This was originally posted last month for $699, and just price dropped to $650, so I thought I'd share it. The only used ones I've ever found that sold in the past went between $475 and $550. I missed the one for $475 by one month, it sold right before I bought my LSiM speakers, which I purchased in November 2017. This is the first used one I've seen come up since then.
http://www.audioasylumtrader.com/ca/listing/Integrated-Amplifier-SS/Dayens/Menuetto/-Reduced/197350 -
What I think are Pioneer HPM 40's. Four of them for $100.
https://greensboro.craigslist.org/ele/d/oak-ridge-speakers-sonic-bass-reflector/6811181217.html -
Picked up this nice B&K AVR-307 today off Craigslist! Should be a nice upgrade for my crappy aging Sony AVR.
I think so. $200 and it came with the remote, a nice power cable and owners manual.Gustard X26 Pro DAC
Lowest price I have ever seen by far on a PS Audio Directstream.
https://www.usaudiomart.com/details/649498554-ps-audio-directstream-dac-in-silver-finish/2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
BNIB - AudioQuest Rocket 44 PSC Bi-wire speaker cables (pair) bananas/bananas $225
https://ebay.com/itm/323675086203?ul_noapp=true
No affiliationHT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
No affiliation
Wonder how these would be vs Audioquest Bedrock.
Also I wonder if they are legit/authentic. They appear to simply be NOS that has been sitting for some time, as evidenced by the old box design.
Is it just me or does the copper look somewhat oxidized?
You can use de-oxit to clean up the connectors if you like. I notice a lot of "older" cables from AQ look like this. It's still the PSC design.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
Polk LSiM703, 706c, TransDeco TD24B Speaker Stands
Mount Vernon Cherry finish
$800 for all
https://louisville.craigslist.org/ele/d/lanesville-polk-lsim703-and-706-center/6815837854.html -
@adb3da up for a road trip?
ADS L1290 - these things look minty and sweet. $550 brand new listing. No affil.
https://charlotte.craigslist.org/ele/d/charlotte-ads-l1290-vintage-stereo/6815824482.html
No affiliation.
https://www.upscaleaudio.com/collections/sweet-deals/products/musical-fidelity-m2si-integrated-amplifier
Upscale Audio just purchased every M2si available
Musical Fidelity M2si Integrated Amplifier
Sale
$599.00 Regular price $999.00"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Anyone interested in a Linn Kairn Preamp? No affiliation.
You know...I wanted a LSiM 706 pretty bad for a while, but after just living with the stereo setup with the 703s in my office/gaming rig I have kinda decided that it isn't necessary. If I found a super low price on one locally I might be tempted, but not enough to road trip for it. Nice deal in the link though. -
Anyone familiar with these? JBL L25ti bookies plus stands for $200. (Correction, the back of the speaker shows L20t)
https://charlotte.craigslist.org/ele/d/winston-salem-jbl-l25ti-loudspeakers/6816238214.htmlPost edited by Jimbo18 on
