HDMI Passthrough not working
Boatsbeatwork
in Electronics
New Magnifi Max SR is hooked up to new Sony 55 inch A1 Oled
When I turn the magnifi Power off no picture or sount comes through
I am hooked up to ARC on both Mgnifi and TV using High Quality High speed HDMI cables .
Works perfectly when powered up . Is this a faulty unit ??
@KennethSwauger
Calling the 1-800 number tomorrow is probably your best bet at getting help. Ken will tell you to have the receipt and serial number ready when you call...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Should the source be hooked up to the pass thru on the soundbar and to an hdmi only on the tv in this application?
That way when the sound bar is off it passes thru the soundbar to the tv.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I am having the same issue, does anyone have a fix or is the device bad?
It doesn’t do standby pass through. This is an option on some devices but usually the user has the option to turn it on or off. I don’t believe the Polk bar has thus standby pass through feature. Sound bar must be powered on to send HDMI through to TV
