Monitor7b crossover new caps and resistors
RandyCroissant
Myself and my 18 yr old Son did a project together today on his new to him Monitor7bs, they are near perfect and deserve some love. I have to say we listened to them for several months prior to the upgrades and they sound really good for 37 years young, a testament to good design. The parts I chose for this upgrade kind of buck the norm here on the forum because I like to experiment and let my ears do the talking. I chose Jantzen 12uf cross caps and Jantzen standard Z 33uf we also replaced the resistors with mills mra12 4.5 and Jantzen 2.7 10 we also replaced the binding posts with Parts Express. The whole objective here was to keep the costs down. The thing that we did that was unusual was to add bypass caps to both main capacitors they both are 0.01uf Cornell Dubilier 3000v film simply a test to see how bypass caps will effect the voicing if any (we can always remove them) we plan to give them some time to burn in and get back to the forum with our impression.
Thank You,
Randy and Tom
Thank You,
Randy and Tom
Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub
Bypass caps suck!Political Correctness'.........defined
President of Club Polk -
To add you can't see the resistors and other bypass in the pictures those items were moved to the underside of the board to save space, worked out great.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Good work Randy. Do you think the 7's could benefit from a strip of Sonic Barrier/BH5 right behind the MW? I haven't seen any threads of such.Don't take experimental gene therapies from known eugenicists.
Nice speaks
Nice Randy!. I'm not a fan of bypass caps, however Jeff Glowacki of Sonic Craft is, so let her rip, and see if you like them.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Thank,s gents! I read on line an article on this topic and thought I would give it a shot with these less expensive caps. I see no benefit with bypassing my sonicaps.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub
