HRT Headstreamer
zingo
in Electronics
I currently use an HRT Headstreamer as I like the sound through USB and my computer, but the only output is for headphones. It doesn't have enough juice to drive many headphones, so I plugged it's out into my headphone amp in and it sounded good. I know that headphone out and line in are different requirements, but has anyone else tried this? I assume I won't fry anything do to the low output voltage of the headphone out? Thanks!
Just because the output is a 3.5mm jack I don't think that necessarily means it's only for headphones.
Agree:
https://worldwidestereo.com/products/audioquest-tower-3-5mm-to-rca-cable-black-1-9ft-tower0-6mr?sku=162594&gclid=Cj0KCQiAkMDiBRDNARIsACKP1FFEje1EI_7U_-q-Piib4aI2t0crLJWKPXhYc8lR06nvwdGG8rd4aQ8aAiaDEALw_wcB
https://worldwidestereo.com/products/audioquest-evergreen-3-5mm-to-rca-cable-2-feet-everg0-6mr?sku=163183&gclid=Cj0KCQiAkMDiBRDNARIsACKP1FHWow5xrZ9-xj2yac8Sxu1yOQ1BTaNZKIF841Sg1NBgVBHmZ8kmEM0aAr3SEALw_wcB
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
HRT description says “Compact, Powerful, 24/96 Capable, and Designed to Drive Headphones”.
https://www.musicdirect.com/headphone-amp/hrt-headstreamer-usb-dacheadphone-amp -
If it can drive headphones it can drive a line level input.
I decided to pirate my NuForce WDC200 wireless DAC from my stereo rig to try with my headphone amp. It doesn’t have USB which I would have preferred, but it does lossless high bit rate audio over wifi. Maybe I can actually put my headphone amp in my living room and stream to it wirelessly...
I like the HRT stuff. The MSHD is one of my favorite DACs.
I just had a look on their site, looking for specs on the 1/8 output, but didn't see anything. You can email them with questions, though.I disabled signatures. -
If your wireless DAC works as well as a Squeezebox Touch over wifi, it should make for a pleasing listening experience. In fact, you've just given me an idea!I disabled signatures.
Exactly! This replaced my Touch and I felt like a genius when I realized I could listen with it anyway I had a plug!
Seriously though, fire off a message to HRT support. You'll probably get an email back in a day or two from Kevin.I disabled signatures.
I will try; thanks! -
Kevin says "Yes, that is perfectly acceptable. The HeadStreamer has only a headphone output whereas the microStreamer has both. The difference is that there is a headphone amplifier and an attenuator in the headphone path whereas a line output lacks those additional stages."
