Which drives do you trust in your NAS?
I am running out of space ( I don't know why, there aint so much I put on it. No movies or big stuff like that ) on my WD 4TB so I may need to get larger drives. What brand and size do you use and why?
  • afterburntafterburnt Posts: 5,502
    Maybe I should try cleaning it out, any suggestions on what to use?
    "WARNING:
    CHOKING HAZARD -- Toy contains a small ball. Not for children under 3 yrs."
    This was on the Amazon NAS page. I figured I would pass it along for those that plan on getting their three year old a NAS.
  • EndersShadowEndersShadow Posts: 16,680
    HGST.... because Ryan @ZLTFUL told me the gov uses em.....
    WD because IIRC they bought HGST and now use their manufacturing methods.
  • ZLTFULZLTFUL Posts: 4,993
    edited January 26
    I have 22 Hitachi/HGST drives, 4 WD Reds, 2 WD Blues, 4 Seagate Ironwolf and a handful of Toshiba drives.
    The most reliable by far have been the HGST Ultrastar NAS drives.
    I have 2 HGST HE6 drives on the way...they use helium in the drives to increase bearing life and help tame turbulence from the rotating platters. Not sure of their durability yet as they are the first 2 I will be using.
    BackBlaze does a quarterly reliability report as they use mostly consumer grade drives in their storage arrays. The Hitachi/HGST drives have historically been the most reliable with WD Reds and Blacks coming in second. Seagate and Toshiba tend to be the worst reliable for them.
  • msgmsg Posts: 4,909
    edited January 26
    I use WD Red as well.
    Run from Seagate unless you're interested in building a collection of paperweights, or harvesting really strong magnets for pinching your fingers and other uses. Like hanging dish towels from the oven door handle.
    edited January 26
    In all fairness, I'm basing my recommendation against Seagate on experiences from quite some time ago, and nothing recent within the past 3-5 years. They may have gotten better. I imagine one of those reports Ryan's linked will provide some data on them.
    But I know a guy using Seagate disks, and am sure he's facing imminent failure across all drives. I'm also pretty sure they're gonna fail with 10-15 seconds of each other. Even the ones that aren't plugged in, and stored in a real fire safe.
    Any good ideas on how to clean up my NAS? There can't be 3.5 terra of important stuff on it.
  • DarqueKnightDarqueKnight Posts: 6,513
    Do you frequently delete files from the NAS and does it have a trash bin or recovery bin that stores deleted files? If so, you may have a lot of deleted files taking up space.
    I use WD Red in my video NAS and WD Black for music storage.
    "So hot it burns Mice!"~DK
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    "Knowledge, without understanding, is a path to failure."~DK
    "Those who irrationally rail against something or someone that is no threat to them, actually desire (or desire to be like) the thing or person they are railing against."~DK
    edited January 27
    I see nothing in the app that lets me delete or clean up anything. It does not show on the network like a regular drive so there is no access to it under windows.
    Seagate really has turned their image around since the days of their "likely to fail" 3TB and smaller drives.
    In all fairness, I am giving the Ironwolf drives a shot as a friend has been using them since their inception with no failure issues to speak of in their data center (he is the senior engineer/architect for the county north of us and handles the data center for their law enforcement, county attorney and county auditor offices).
    Bruce, what NAS are you using? It may help to identify the "garbage" retention and removal of that particular device.
    edited January 27
    @ZLTFUL a QNAP, I have not gotten into any advanced stuff that it's supposed to do, just my music and my photos and that does change a lot. It's a 2 bay, I am thinking of a 4 bay so I can use 1 of the 2 extra bays for an SD drive that is supposed act as a high speed cache???
    https://docs.qnap.com/nas/4.1/SMB/en/index.html?network_recycle_bin.htm
    That was a quick search...not by any means a definitive guide but if the default retention is 180 days, I could see a bunch of space getting allocated to recycle bin contents if you are adding/deleting files regularly.
    @ZLTFUL I found that I didn't know it was there thanks it made some room. Anything good for looking for duplicates?
  • mrbironmrbiron Posts: 5,067
    I use WD Reds with a spread of 8's, 6's, 4's.
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Crack w/Speedball, Senn's MD HD600
  • reverbreverb Posts: 68
    I have been using WD Reds for several years now. No issues yet (fingers-crossed)
  • DaveHoDaveHo Posts: 2,333
    WD Reds here. Have had no failures. My oldest drive is about 4 yrs old.
  • tophatjohnnytophatjohnny Posts: 2,413
    ZLTFUL wrote: »
    4 10TB Iron Wolf drives in my NAS and no issues. Hope they last until I can get my hands on 4- 10TB SSD's!!
  • GospelTruthGospelTruth Posts: 359
    I started out with 2TB WD green drives in my NAS before the reds ever came out. 10 years going and no issues. I don’t keep important stuff on them at this point and they are in a RAID configuration for failure. Point is, they keep going.
    I moved to WD red and gold for my important files (photos, music). The gold drives are faster and have a 5 year warranty. The red drives are slower and have a 3 year warranty.
    I have both 8TB and 4TB drives of the above. Never had a failure yet with them. They sit in Synology NAS enclosures. I make sure they have enough ventilation to keep cool for longevity. I’m sold on their drives.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
    I sent for these, they should be pretty good judging by the lifetime throughput and warranty. Pretty good bang for the buck?
    https://www.amazon.com/gp/product/B07GT8WYSR/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Howdy, Stranger!
