Thoughts on using Integrated amps as Preamps?
imsjryimsjry Posts: 120
edited January 2019 in 2 Channel Audio
So...I recently picked up a B&K 3030 power amp to drive my new Polk LSiM705's. I've always used a great old Kenwood KA-8004 to drive my other Polk speakers (RTi12's), but i wanted to get in on the power amp world.
The Kenwood KA-8004 has a preout as well as the old Pioneer SA-9100 I own.
What are the thoughts on using Intigrateds as your Pre's? These amps are both wonderful on their own, but I assume that does not necessarily mean they make for good Preamps.
Any thoughts and experience are most welcome! Thanks.
Post edited by KennethSwauger on
  • gudnoyezgudnoyez Posts: 7,167
    edited January 2019
    Yes you can, but not sure why one would want to, unless your trying to avoid purchasing a pre because of spending money.
  • mhardy6647mhardy6647 Posts: 24,152
    It'll vary from amplifier to amplifier, but the preamp sections in the vintage Japanese massmarket integrated amplifiers were generally nothing special.
    Certainly worth a try, given that you have it already.
    Has the KA-8004 been rehabbed or is it original? If the latter, it will, at the least, be chockablock with tired electrolytic capacitors (which will almost certainly have sonic consequences).
  • imsjryimsjry Posts: 120
    gudnoyez wrote: »
    It’s more just because I already own them and they have the capability and they seem to be great intigrateds in their own right.
    I'm sure they are since you already own them you might as well try it. I wouldn't start a new system that way though.
    gudnoyez wrote: »
    So I guess I’m looking for reasons why a decent intigrated wouldn’t make a good Pre. And what makes a “good” vs “bad” preamp? I’m new to all of this.
    If the sound is powerful and clean when using it as an intigrated, what would it make it not so as the Preamp to my B&K?
    Integrated serviceable as a pre yes, as good as a standalone pre no, hope that helps.
    The preamps in most integrated amplifiers of that era almost always have compromises in design and components used -- compromises driven by economics and practical considerations (space!).
    Some of the integrated amplfiers had notoriously mediocre preamps -- harman/kardon's A-402, and the earlier, vacuum tube Dynaco SCA-35 are well known examples.
  • delkaldelkal Posts: 637
    Assuming the B&K amp is better than the internal amp of your Kenwood integrated................
    Using your "decent" integrated as a pre can only sound better. You can do a lot better with separates but stand alone preamps can get expensive and you will have to decide if it is worth it to you.
    Until then crank your new system up and enjoy.
  • skrolskrol Posts: 2,849
    Sometimes it is good, sometimes not. I like the way my Denon DRA-835R sounds through its built in amp. However, I tried using the pre-outs going into my Parasound HCA-1000A and it didn't sound so good. I guess they are just a bad match.
    Stan
    Main 2ch:
    Polk LSi15 (DB840 upgrade), Parasound: P/LD-1100, HCA-1000A; Denon: DVD-2910, DRM-800A; Monster HTS3600-MKII, Grado SR-225i; Technics SL-J2, Parasound PPH-100.
    HT:
    Marantz SR7010, Polk: RTA11TL (RDO198-1, XO and Damping Upgrades), S4, CS250, PSW10 (DXi104 upgrade), Marantz UD5005, Pioneer PL-530, Panasonic TC-P42S60
    Other stuff:
    Denon: DRA-835R, AVR-888, DCD-660, DRM-700A, DRR-780; Polk: S8, Monitor 5A, 5B, TSi100, RM7; Pioneer: CT-6R; Onkyo CP-1046F; Ortofon OM5E, Marantz: PM5004, CD5004, CDR-615; Parasound C/PT-600, HCA-800ii, Sony CDP-650ESD, Technics SA 5070, B&W DM601
  • joecoulsonjoecoulson Posts: 4,048
    A little outside the lines of this but I had the Marantz AVR acting as a pre for my two from channels running Linn amps. When I stuck the PS Audio Stellar Gain pre in the middle of it (to isolate the 2ch source material) things basically woke up. We don’t know what we don’t know and until I did that, I thought my system sounded great. Trial and error (and a little bit of coin sometimes) all participate.
    Auralic Vega G1/Rega TT/Denon SACD - Parasound P6 - PS Audio M700x2 - Elac Adante AF-61 - AQ Niagara 5000 - SVS SB16u
  • hochpt21hochpt21 Posts: 5,222
    I used a more modern 2-channel receiver HK 3490. Used the preout to a Parasound and loved it.
    __________________________________________________
    Turntable - VPI Scout 1.1/Ortofon 2M Blue
    Amplification - Parks Audio Budgie, Dared SL2000a, McCormack DNA 0.5 Deluxe
    Speakers - GoldenEar Triton 2
    7.1 Home Theater
    Denon AVR-X3300W; Rotel RMB-1066; Polk CS350ls, LS90's, FXi3's, RC60i; SVS PC Ultra; BenQ HT2050; Elite Screens 120"
    Man Cave
    Turntable - Pro-Ject 2.9 Wood/Grado Gold
    Integrated Amplifier - Rogue Audio Cronus Magnum II
    CD: Cambridge Audio
    Speakers - SDA 2A; Epos Epic 2
  • tonybtonyb Posts: 31,715
    joecoulson wrote: »
    Ya do the Hokey Pokey and you turn yourself around....that's what it's all about.
    Got that right Joe.
    B&k 1430
    Tad 803 speakers
    edited January 2019
    So any recommendations for standalone Preamps? I see some people using new ones that cost $100 and some using ones over $1000 so it’s very confusing. Can a Pre vary THAT much in sound since it’s really just supposed be a non-colored signal pass through to the power amp, right?
    You get what you pay for.
    Ask yourself the same question in regards to speakers. $100 vs $1000 vs $10000 etc.
    Definitely some good options for you in the $500-$1000 range. And even more so used.
  • verbverb Posts: 8,894
    edited January 2019
    I used an integrated for the longest time as a preamp. When I finally switched to a dedicated pre, the world came alive! If you have the room, separates are the way to go. And that way you can switch em out, upgrade, as you move along your journey. Just my experience.
    Post edited by verb on
    Basement: Polk SDA SRS,Cary SLP-05 Pre,Enlightened Audio Designs CD Transport,Northstar Designs Excelsio DAC,Cambridge 851N streamer,Marantz SA-14 SACD,McIntosh MC300 Amp,Silnote Morpheus Ref2 Digital Cable,Furman 15PFi Power Conditioner,Pangea Power Cables,Wireworld Oasis 8 RCA IC's,MIT Shotgun S3 IC's,MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC,EAR Acute CD Player,EAR 834L Pre,Northstar Designs Intenso DAC,PASS ACA Monoblocks,Denon UDR-F10 Cassette,Acoustic Technologies Classic FR Speakers,SVS SB12 Plus sub,MIT AVt2 speaker cables,IFI Purifier2,AQ Cinnamon USB cable,Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks,Tisbury Mini Passive Pre,Tjoeb 99 tube CD player (modified Marantz CD-38),Analysis Plus Oval 9's,Zu Jumpers,AudioEngine B1 Streamer,Klipsch RB-61 v2,SVS PB1000 sub,Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated,Cambridge CXN v2 Streamer,Rotel RCD-1072 CD player,Furman 15PFi Power Conditioner,Polk RT265 In Wall Speakers,Polk DSW Pro 660wi sub
    edited January 2019
    I mean, you can get one for $31.
    http://audiokarma.org/forums/index.php?threads/fx-audio-6j1-tube-preamp-a-31-wonder.848535/
    Not sayin' you should (i.e., I wouldn't -- and I am nothing if not cheap), but you can...
    See that’s a case in point. Some people are driving their high end systems with $75 little preamps so back to my original question, why would something like that possibly be better then the preout on my nice old integrated? I mean hell for $75, it would be worth the experiment I suppose. Then there are $2000 preamps so it’s all confusing to me.
    imsjry wrote: »
    Why would it be confusing ? Pre amps, like any other piece in your system vary in sound quality, and price. You could pay north of 15k for certain pre amps....or 75 bucks, but you certainly aren't going to get the same sound quality.
    B&k 1430
    Tad 803 speakers
    imsjry wrote: »
    [emphasis added]
    Some people collect AMC Gremlins.
    I am pretty much guarantee that one gets what one pays for -- the folks that run these $31 Asian wonders have probably not compared them to anything that wasn't mediocre.
    Preamps are important. I don't use an active preamp, because I've yet to find one that I really like -- that doesn't take me a notch away from the performance. Some of that is financial (i.e., I am not keen to spend big $ on an active preamp); some of it opportunistic (what I own and what I've had a chance to audition with my own equipment). I am NOT SAYING that there aren't good preamps, vintage or new; storebought or DIY -- I AM SAYING that they aren't necessary easy to find, especially on a (tight) budget).
    Here's the thing: The preamp in your old Kenwood is probably perfectly OK. Dollar for dollar, then or now, it wouldn't match a dedicated preamp -- because those dollars were invested in the power amp, too! In other words, if the MSRP on that KA8004 (probably ca. 1974? I'm guessing here) was $350, probably $100 to150 of that value was in the preamp section. Even in 1974, $150 bought one an entry-level preamp.
    As I mentioned earlier, though, the bigger problem with the KA8004, unless you have rehabb'ed or had it rehabb'ed, is that the passive components in it are
    tired. Especially the electrolytic capacitors. The amp will not sound as new nor as good as it can with forty-plus year old electrolytics in it.
    Until or unless that's been addressed, the preamp may sound perfectly OK, but it will not be performing at its own potential.
    Add that to the fact that its own potential was probably middling when new, and you're not likely to be getting great sound out of the KA8004.
    ALL THAT SAID, it costs you nothing to try, and it is more than worthy of trial. If you like what you hear, you're all set.
    HTH, as they say!
    Re: Kenwood KA-8004.
    Stereo Review's redoubtable :) Julian Hirsch tested it in November, 1973.
    You can read the review in this PDF from www.americanradiohistory.com (an amazing site, if you're not familiar with it!).
    https://www.americanradiohistory.com/Archive-HiFI-Stereo/70s/HiFi-Stereo-Review-1973-11.pdf
    the review starts on pg. 38 of the magazine :)
  • BlueFoxBlueFox Posts: 12,551
    You will need decent cables to connect the pre to the amp.
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    BlueFox wrote: »
    Oh boy. This audiophile hobby is expensive! Recommendations on cables? Thanks everyone already.
    Shunyata cables are available at various price points. From entry to TOTL they are worth it. The Cable Company has good prices.
    https://www.thecableco.com/
    Lumin X1
    Sony XA-5400ES SACD
    How cool was that??!! Thanks for posting. Amazing to read an original review my amp from when I was four years old.
  • JayMXJayMX Posts: 253
    edited January 2019
    Not to thread-jack, but I am using the pre-outs from my Kenwood KA-8150 y'd out to my GFA555->SRS2’s and feeding the power amp section of the 8150 so I can use it to drive my KG4’s or RTA12c's (mood dependent I turn off 555/SDA's and turn on either A or B outputs on 8150). I have been very pleased with this configuration vs using my Marantz AVR pre-outs with L/R bypass enabled for 2ch listening. How detrimental to the signal is y'ing the output like that?
    Current Collection:
    Monitor 4a (Peerless), Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5b (SL2000), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s, Dynamat, Sonicaps, Mills, H-nuts), SDA CRS+ (SL2000), RTA12c (194's), SDA SRS 2 (SL2000)
    Repair pile: SRS 3.1TL (198’s), RTA 11T's, (1) lonely RTA 11TL to become a center channel... someday...
    Pairs that have passed through:
    Monitor 5b (SL1000), Monitor 10a (Peerless), Monitor 10c (3x pair), RTA8, RTA8TL, SDA2, SDA2a, SDA1b, SDA SRS2
    ...and more to come, it’s a sickness.
    JayMX wrote: »
    If you like what your hearing....does it matter ?
    B&k 1430
    Tad 803 speakers
    edited January 2019
    "Y-ing out" (I like that nomenclature!) is, as we say in my line of work, GRAS (Generally Regarded As Safe) :)
    Using a "Y" cable to mix signals is not (as we also say in my line of work) a best practice. :|
    Here's the Scripture (IMO) on "Y-ing" :)
    https://www.rane.com/note109.html
    It's a little abstruse, since it is primarily directed at the "pro" industry, using balanced interconnects -- but it's good info. Rane has a whole library of similar white papers on such deceptively-simple-but-not-really considerations as grounding.
    edited January 2019
    @mhardy6647 - yes combining or mixing two line level signals using a y cable is never a good idea lol. I don’t ever run the amp in the 8150 and the 555 concurrently, so I figured I was safe. It works well and gives me options! 👍🏻
    Current Collection:
    BlueFox wrote: »
    $350 for the least expensive pair. That's more then my B&K 3030 power amp cost me. I'm all in on this audiophile game, but boutique expensive RCA cables? Can they possibly make that much of an audible difference that warrant the prices I'm seeing? I'm kinda stunned. Maybe I'll start with some Blue Jeans which seem to be a reasonable choice over the $3.00 Monoprice ones I've always used.
  • ClipdatClipdat Posts: 7,484
    imsjry wrote: »
    Blue Jeans or Signal Cable always a great starting point at which you should hear a difference vs. Monoprice.
    "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
Howdy, Stranger!
