Bi-Wire LSiM 705?
  • imsjry
    imsjry Posts: 120
    I guess I’ll have to stay blissfully ignorant with my Monoprice copper 12 gadge unless someone wants to loan me their $400 cables for a while 😉.
    Meanwhile, I’m loving the 705s with less then 50 hours in so far. Still curious about bi-wirering but doesn’t sound like a resounding call from the group to do it. It’s interesting the manual has a whole section about it.
  • Inspector 24
    Inspector 24 Posts: 1,308
    There's a number of good write-ups on the subject that delve into the science of it. Here's a couple that I found worth the read.
    https://www.qacoustics.co.uk/blog/2016/06/08/bi-wiring-speakers-exploration-benefits/
    https://www.st-andrews.ac.uk/~www_pa/Scots_Guide/audio/biwire/Page1.html
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • imsjry
    imsjry Posts: 120
    Ok so dumb newbie question here. Can I just run an additional set of my bare Monoprice wire from the left and right outs of my B&K amp to test the bi-wire or do I need specific bi-wire cables?
  • rooftop59
    rooftop59 Posts: 7,973
    imsjry wrote: »
    Why would you do that rather than just run a little of the same wire between the binding posts???
    Game Room 5.1.4:
    Bedroom 2.1
  • imsjry
    imsjry Posts: 120
    rooftop59 wrote: »
    imsjry wrote: »
    Because I'm dumb?! I though for bi-wire you run two sets of Left and right outputs from your amp, one going to the top speaker posts and the other set going to the bottom posts. Apparently I have that all wrong?
  • Inspector 24
    imsjry wrote: »
    rooftop59 wrote: »
    imsjry wrote: »
    You have it correct. See my links I posted above, there may be some benefit to bi-wiring, whether you can hear it or not is up to you.
    Up
    Down
  • rooftop59
    imsjry wrote: »
    rooftop59 wrote: »
    imsjry wrote: »
    If you are running two sets of cable from the same binding posts on the amp to the two sets of binding posts on the speakers, I cannot conciever of there being any difference between that and just putting the same wire between the binding posts on the speakers imho...
    Game Room 5.1.4:
    Bedroom 2.1
  • delkal
    delkal Posts: 764
    edited January 2019
    I have a question.............Why would you need an expensive and exotic jumper cable?
    Expanding on Rooftop59's question. Seems to me you can use the exact same wire the speaker uses internally (AKA common copper hookup wire). Would 2-3 inches of extra hookup wire really make a difference?
    Where was that post of the $14,000 jumper cable?
  • Hermitism
    Hermitism Posts: 4,204
    delkal wrote: »
    I think that wire carries a much smaller voltage because it comes after the crossover and might be insufficient gauge.
  • rpf65
    rpf65 Posts: 2,127
    Many like to use the same wire for jumpers as they use for speaker wire. Some will size and terminate it themselves, others buy pre-terminated directly from the manufacturer.
    Stock jumpers, bare wire, manufactured terminated, its the individuals preference. Many of us believe that upgrading the stock jumpers is one of the least expensive and noticeable improvements one can make. Others think it’s a waste of time/money.
    Some reasonably priced as well as expensive wire on The Cable Company website.
  • delkal
    delkal Posts: 764
    Hermitism wrote: »
    delkal wrote: »
    I guess that brings up another question.......
    The leads on an expensive film cap are well under 22 ga and might be smaller that 26.
    By the time you solder everything on the board you have at least 6 inches if 22 ga or smaller tinned copper solid wire in the signal path. And last time i looked at the main inductor coming into the speaker it has many many yards of a very small gauge wire wrapped up.
    If I told you you can use a few inches of 22 ga solid wire as a jumper you would think I was crazy. But that is what is happening internally just a few inches after the binding posts.
    I guess people only think about parts that they can see.
  • imsjry
    imsjry Posts: 120
    rooftop59 wrote: »
    imsjry wrote: »
    rooftop59 wrote: »
    imsjry wrote: »
    Sorry, but what do you mean by “putting the same wire between the binding posts on the speakers”? Are you saying to connect wire connecting the top and bottom posts instead of how the jumpers are now? Not following you....
    VR3 Posts: 28,020
    edited January 2019
    Imo, biwiring is not the benefit. The way 4 wires are twisted are the benefit. Case in point, take a shotgun pair (using jumpers) with the same twist as a biwire pair and I would challenge you cant hear a difference.
    When we ate lunch with Al Ballard of Polk Audio some 10 years ago, he openly claimed the main driver to biwire was marketing.
    When I do crossovers, it would be easy to make something tri wire, Bi Wire, quad wire if applicable at the end of the day the wire goes all to the same places, you are effectively making one big jumper. Now biamping with a crossover at the signal level, that's a different discussion.
    You can also install jumpers with Bi Wire cables to see what I mean about shotgun versus bi wire
  • joecoulson
    joecoulson Posts: 4,943
    And I’m hoping to a/b test with you here Trey on Bi-amping passively and showing the difference.
    VR3 Posts: 28,020
    I'm not saying biwire cables are not better, I'm saying shotgun and biwire cables are equal. It's all in the twist 😜
  • joecoulson
    Let me clarify. I am hoping to show everyone there is a benefit to bi-amping without an active crossover in front of the amps. Will be nice to have more ears here and their opinions.
    Looking forward to it.
    VR3 Posts: 28,020
    I think that would vary speaker to speaker, but I think you would still hear an improvement by removing the bass frequencies from the upper Amp at a minimum.
  • joecoulson
    I want to talk to you about that when you come because it might be something minimal in the signal path that I could have you build.
    VR3 Posts: 28,020
    edited January 2019
    I don't know the crossover point of your speakers, but most 3way around 100hz or higher. This should work without double filtering
    FMOD Crossover Pair 70 Hz High Pass https://www.amazon.com/dp/B0006N41JW/ref=cm_sw_r_cp_apa_i_3rtsCbCR4GJ5E
    But this would be experimental more so than permanent
  • joecoulson
    The mid comes in at 200hz
    VR3 Posts: 28,020
    edited January 2019
    Yep, id pick up those 70hz too see if it works in your system...can always return if not
    For me, I am a purist 2 channel guy. My current setup is streamer, dac, Amp, speakers.
    audioluvr Posts: 5,432
    edited January 2019
    delkal wrote: »
    Hermitism wrote: »
    delkal wrote: »
    Ok. Let me put this in the " male" perspective. Audiophile speaker wire is like comparing a Chrysler 300 with the big block 440 ( large gauge low grade copper wire) to an Italian Indy car with only a 1.8L 4 cyl engine that produces 1200 hp. One attracts one drunk fat toothless chick where the other attracts thousands of gorgeous supermodels. Both do generally the same thing but which makes the experience more pleasurable?
    F1nut Posts: 49,795
    delkal wrote: »
    Hermitism wrote: »
    delkal wrote: »
    The signal also goes through the pre amp internals, the interconnects and the amplifier internals first. That does not mean getting the signal to the crossover as best as possible is not paramount. Try using some 26 gauge speaker cable, then some well known high quality speaker cable. That will answer your question rather quickly.
    tonyb Posts: 32,906
    imsjry wrote: »
    I always just read about the gadge and to use copper when I googled “does speaker wire matter?” but had no idea there was audiophile market wire out there. Damn, now I’m more curious in that then bi-wiring.
    More to it than just gauge and copper has many different variations as well. Like anything you google, you'll get the pro's and cons, but what's the truth ?
    Truth is....you have to experiment some for yourself as best your own wallet allows. Just like everything in audio.
  • pawelmwo
    pawelmwo Posts: 137
    Go to eBay and bid on these jumpers from Zu. I won a set @ like $26.00. Problem solved, no junk brass straps, and no extra set of cables. Biwiring to me is a huge waste of money.
    https://www.ebay.com/itm/Zu-Audio-IBIS-8in-20cm-Loudspeaker-Jumper-Sets-Junk-Those-Brass-Straps/113580847575?epid=741215548&hash=item1a71f231d7:g:0NoAAOSwvt1WQ8EC:rk:1:pf:0
    Aren't those a little on the long side? I'm finding the stock ones about 4 inches give or take. I thought about picking up a set to see if it makes any difference.
  • motorhead43026
    motorhead43026 Posts: 3,892
    edited January 2019
    pawelmwo wrote: »
    Fit and look just fine on my S60 Signatures. I had them terminated with bananas. You really need the extra length to not put strain on the teminations. YMMV not knowing what your speakers are. Anyway, I noticed a difference from the brass straps. Plus they give you a 60 day trial period.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • pawelmwo
    pawelmwo Posts: 137
    pawelmwo wrote: »
    Picked up a set of 4 spade 5/16 jumpers for $25 shipped. Will see if they will make any difference from the stock 705 jumpers.
  • imsjry
    imsjry Posts: 120
    pawelmwo wrote: »
    pawelmwo wrote: »
    I'll be curious to read your results. I thought I read the LSiM series used very good quality jumpers.
  • pawelmwo
    pawelmwo Posts: 137
    imsjry wrote: »
    pawelmwo wrote: »
    pawelmwo wrote: »
    So far seems a bit cleaner. But they do recommend 400 hours to burn in. Might be placebo but they are well made. The spade doesn’t go all the way around like the Polk jumper and were a little longer. This is how I connected the wires so they don’t stick out the sides. Spade heart lol njygve8d3ucy.jpeg
