Bi-Wire LSiM 705?
imsjry
imsjry Posts: 120
I don't mean to start yet another conversation about the merits of bi-wiring in general. My question is specific to the LSiM 705's. Has anyone bi-wired them and found a huge sonic improvement. The manual specifically mentions the benefits of doing it so I'm now of course curious what others have experienced in their setups.
Thanks!
Preamp-Kenwood KA8004
Power Amp-B&K3030
    F1nut Posts: 52,027
    Replace the stock jumpers with high quality speaker cable and be happy.
  • imsjry
    imsjry Posts: 120
    No one has bi-wired their LSiM’s that has an opinion on sonic improvements? I find that hard to believe on this forum. Rise up bi-wirers!
  • Hermitism
    Hermitism Posts: 4,338
    I bi-wired my RTi8's. When I was going to order custom cables for them, it was recommended by everyone to replace the plated brass jumpers with matching cable. It ended up being cheaper to buy bi-wire cables, rather than having jumpers made with the same wire and terminations. I haven't upgraded my cables yet on my LSiM, but those speakers come with copper wire jumpers. So I'm guessing any improvements on replacing the jumpers on those would be negligible, except for systems with high end equipment, but I can't really say. Small changes are more noticeable the higher up the chain you go. I think most of the people here that use bi-wire cables did so for the purpose of eliminating the jumpers. If I'm wrong about that, I'm sure some members will jump into the conversation.
  • Go to eBay and bid on these jumpers from Zu. I won a set @ like $26.00. Problem solved, no junk brass straps, and no extra set of cables. Biwiring to me is a huge waste of money.
    https://www.ebay.com/itm/Zu-Audio-IBIS-8in-20cm-Loudspeaker-Jumper-Sets-Junk-Those-Brass-Straps/113580847575?epid=741215548&hash=item1a71f231d7:g:0NoAAOSwvt1WQ8EC:rk:1:pf:0
  • imsjry
    imsjry Posts: 120
    Thanks for the recommendation. So what are the benifits of these compared to the LSiM stock jumpers?
  • joecoulson
    joecoulson Posts: 4,943
    I believe the stock LSIM jumpers are just fine, now bi-wiring cables (if you get them included - ie the Audioquest rocket 44's) are a jump over those IMO but only worth doing if you plan on getting an upgraded cable (not necessarily AQ) to begin with.
    Now bi-amping with two sep cables/sep amps brings a whole-nother debate to the table, and my take on that has been said in multiple threads in this forum AAA++++
  • motorhead43026
    motorhead43026 Posts: 4,031
    edited January 2019
    ^^agree, in this case the stock jumpers are sufficient. There is still no advantage to bi-wiring, IMHO.
  • imsjry
    imsjry Posts: 120
    joecoulson wrote: »
    Whoa....$300 for speaker cables? I mean I'm all for the best sound possible but geez! And here I thought my Monoprice spool of 12AWG was expensive. :-(
  • WLDock
    WLDock Posts: 3,073
    Well, the Monoprice cable is $0.43 a foot. Make up some bi-wire and see if YOU can hear a difference.
    The same would hold true for $300 speaker cable. Only YOUR ears matter as to whether a difference can be heard.
  • cfrizz
    cfrizz Posts: 13,415
    imsjry wrote: »
    joecoulson wrote: »
    Don't worry about it, your Monoprice will get the job done. If you feel like experimenting later on down the line with wire, IC's, power cords, etc. and have the money for it, and are interested in doing so, it will be there when and if you are ready.
    Right now just focus on putting your system together.
  • joecoulson
    I agree with that^ and I did say that IF you planned on getting an upgrade, that one wasn’t necessary.
  • rpf65
    rpf65 Posts: 2,127
    Fair warning.
    The first upgrade you try, that seems to make little if any sense, and find that you heard an improvement, you will be forced to embrace the insanity. First it’s speaker cables, then more better speaker, then the rest, including power, and you keep hearing improvements. All of a sudden you install a $100 plug, that’s right, the part in the wall, and it’s over.
    Run away before it’s too late.
    audioluvr Posts: 5,992
    imsjry wrote: »
    joecoulson wrote: »
    Huge skeptic here on speaker cables making much difference... Until I got some Wireworld mini- eclipse' (OCC copper).
    B I G improvement like I went from Pioneer receiver to Macintosh amp (no offense to you Pioneer and Macintosh owners)
    F1nut Posts: 52,027
    imsjry wrote: »
    joecoulson wrote: »
    Drop in the bucket, son.
  • joecoulson
    What the heck,,
  • Hermitism
    He can post comments but they won't be visible to us until he returns from his vacation.
  • joecoulson
    Huh. I bet he said something to the effect of:
    “ I love bi-wiring but I LOVE bi-amping even more”
  • Inspector 24
    Inspector 24 Posts: 1,308
    My experience with the A9's suggests there's a little something to it, though A9's not being as musical or refined a speaker it was very subtle. The bass/midbass tightened up slightly, vocals slightly less smeared, treble smoother etc etc. Worth doing as the 3500 has dual outputs anyway. Worth it otherwise? Try it with cheap cable, if you hear a difference probably worth with more expensive cable.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • skrol
    skrol Posts: 3,466
    To bi-wire or not to buy-wire, that is the question.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • imsjry
    imsjry Posts: 120
    audioluvr wrote: »
    imsjry wrote: »
    joecoulson wrote: »
    Whoa. For what those wires cost I would certainly hope you heard a night and day improvement! I had no idea $400 speaker wires existed. Kind of wish I didn’t know!
    F1nut Posts: 52,027
    $60,000.00 speaker cables exist.
  • afterburnt
    afterburnt Posts: 7,892
    Did Jesse comment???
  • afterburnt
    Can Jesse comment?
    F1nut Posts: 52,027
    Hi Bruce B)
  • Inspector 24
    Does it matter if Jesse comments?
    Up
    Down
    F1nut Posts: 52,027
    edited January 2019
    Only if you don't want to learn from the Master.
    imsjry wrote: »
    audioluvr wrote: »
    imsjry wrote: »
    joecoulson wrote: »
    Not a lot really, depending on what speakers your hooking them up to. Cables can run over 10g's, but you'd only be running those on speakers that cost well over 20g's.
    Everything is relative, just like you wouldn't put a 40 buck fiberglass tire on a Corvette.
  • imsjry
    imsjry Posts: 120
    edited January 2019
    I always just read about the gadge and to use copper when I googled “does speaker wire matter?” but had no idea there was audiophile market wire out there. Damn, now I’m more curious in that then bi-wiring.
  • rooftop59
    rooftop59 Posts: 8,120
    imsjry wrote: »
    You’ll definitely get more benefit from good wire and jumpers Than bi-wiring.....
    Game Room 5.1.4:
    Bedroom 2.1
  • WLDock
    WLDock Posts: 3,073
    edited January 2019
    imsjry wrote: »
    Well, there are millionaire and billionaire audiophiles out there. However, most audiophiles types are not rich. I bet there are some that make $250K-$300K with just under a million dollar net worth that own some of these cables.
    Make sure you are sitting down...
    https://mitcables.com/acc-series-articulation-control-console/
    https://successstory.com/spendit/most-expensive-audio-cables
