Ferrofluid replacment
So I have an older SF center channel that I picked up a while back. My AVR has started to go into protect mode at high levels and although I will be ready to upgrade that soon (receiver ) I wanted to try something that I read might help the situation.
The Sonus Faber center has a fabric tweeter that’s ferrofluid cooled. Obviously this being an older tweeter, the fluid might have been bunked up and not doing its job properly.
I ordered the fluid and started work.
Removed the tweeter from the enclosure and separated the magnet from the face/coil
I then took some of the soaking strips included with my ferrofluid purchase. Curled them to fit into the gap between magnets and soaked up as much as I could with that.
For the final part of the prep, I took some alcohol swabs and cleaned in the gap and also the voice coil (very carefully) and alll was clean as a whistle.
I then took the Ferrofluid and cut off the tip of the applicator and proceeded to fill the cavity. I’m sorry I didn’t get any shots of that as I was focused on getting it filled correctly and didn’t think about it until done. This part was tricky as the fluid wants to hang at the surface and not drain down into the cavity. I felt like this part was a little guesswork and put what I thought was the right amount. Here is a shot of the fluid
After all was done I put it all back together is this part was the most surprising. The tweeter has come alive. At least 3-5db increase in output. Wow. That was worth $7
Very happy and now have the confidence to tackle again should the need arise.
  • skrol
    skrol Posts: 3,497
    Cool
    Stan
    Main 2ch:
    HT:
    Other stuff:
    Clipdat Posts: 13,105
    Nice job Joe, I admire your DIY skills.
  • joecoulson
    joecoulson Posts: 4,983
    Thank You señor
  • Faustin
    Faustin Posts: 1,151
    Nicely done. I wonder if anyone has tried this with the older Peerless tweets that were widely used back in the day.
  • mlistens03
    mlistens03 Posts: 2,767
    Looks great! Where did you get your ferrofluid? Everything I can find is like $20 for a small amount online.
  • joecoulson
    I got it on Am***n and when I purchased I used prime to avoid shipping. Not sure why it says $6.95 now for shipping,
    Ferrofluid 300uL General Purpose for 1.5" Diameter V.C. https://www.amazon.com/dp/B003Y5420W/ref=cm_sw_r_cp_api_i_FrgsCbAZ9SDGJ
    F1nut Posts: 52,406
    Faustin wrote: »
    They do not have ferrofluid.
  • steveinaz
    steveinaz Posts: 19,547
    Pretty cool, I had no idea it could be replenished.
  • Inspector 24
    Inspector 24 Posts: 1,308
    And then the phrase ‘changing your speaker fluid’ was no longer a joke.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • steveinaz
    Are those like "voltage drops?"
  • joecoulson
    The cohesiveness of this speaker is so much better now. Very glad I did this. I even think just some time for it to settle made a slight improvement
  • reverb
    reverb Posts: 67
    Wow. Always wondered how to do this.... thanks to the Polk forum and Joe, I now know how :)
  • joecoulson
    My pleasure
  • andrewdrouin
    If any of you, my fellow Polk fans, are in need of Ferrofluid, and live in Canada, hit me up, I'm the first and currently only authorized Ferrotec ferrofluid distro; in Canada! I can set you up wayyy more affordably than ordering ferro' from America or Euro' ~ due to the absurd shipping that they seek to charge...
