Change out that outlet to the pangea 20 Amp outlet, built like a tank and affordable
Yep. The generic outlet doesn’t have enough retention to withstand the weight of the cable. Another rabbit hole!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Took everything apart just waiting for FedEx to drop some stuff off.
Continuing to seal the cabinets on my 3.1 project. These things were completely open to the outside through he top and bottoms! Glue leaked straight through and dripped out onto the carpet. No wonder the push test failed before I tore them down.
Brought home some 3/8" MDF to make new side panels, my son wants all black side panels minus the oak trim so need to rip these to size this week.
Tuned the 1.0 and 1.25 inductors and soldered into place. Decided to dump the Jantzen 0.3mH 20awg due to the measured DCR when I finished tuning it. At 0.36 ohms is was way off from the stock version's 0.581 ohms. Placed an order with HiFi Collective for the proper 0.3mH/22awg versions and ate the FedEx shipping.
Placed a Mouser order for new internal connectors. Going with gold plated terminals on this rebuild so will need to swap out the 28 year-old originals.
Listened to Nina Simone all evening....
Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB -
RobbyKY, You're a busy guy! When I rehabbed my 3.1TL's the exterior was pretty much shot. I removed the top/bottom caps (which was a challenge) and soon realized the caps were a part of the cabinet. Polk certainly took a short cut here.
I made new caps and attached them to the cabinet in the same manor as the larger SDA's, via Lag Bolts. I made a new "permanent" top and bottom for the cabinets first, and secured them into the cabinet walls.
I plained down the side trim pieces to match the thickness of the cloth side panels, this elevated the "overlap" of the top/bottom caps, which I never cared for.
I of course performed all the normal mods as well, the 3.1TL's are a fine example of the SDA Series. Your son will be thrilled!
You should be thinking about other things in Vegas, my friend...Thinking about my rigs while in Vegas on vacation!
I did consider that for sure but maybe I'm just getting lazy in my old age. In all honesty, both sets of the 3.1's I've acquired have been in really good cosmetic shape so didn't feel the need to go down that path. Polk seems to be a little inconsistent in manufacturing as the first 3.1 rebuild had the side trim pieces glued on and the crossovers both had the oddball 18mH inductor with the associated resistor whereas this set has the "normal" dimensional inductor and the side trim is attached with screws. When I opened them up for the first time I found 5 of these screws in the bottom of the cabinet so there were five little vents adding to the lack of sealing.
The polyfiber had also slipped down on one of them.
On a big plus note, it appears the previous owner had already upgraded the tweeters. Any idea how I can confirm these are 198's vs an incorrect 194 short of measuring frequency response curves? I've only handled the 198's with my previous builds and even upgraded our 2b's with the 4.1tl mod so I've never physically seen a 194. All the original tweeters I've pulled have had labels attached while there's never been anything on the back of a 198.
Ha! Someone just bumped this old thread up today. Looks like I've got the new 198's for sure, What to do with my extra $100......
https://forum.polkaudio.com/discussion/177892/neew-rd0198-1-tweeters-direct-from-polk-no-markings-or-identifiers-on-tweeter-ro-box-how-to-verify#latestMedia Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
Swapped Lsi9's in for 705's & kitten proofed the area. Also removed the SVS SB12NSD that was used for two channel listening. The 9's while not bad, are a definite downgrade. Yeah, it looks terrible & those boards aren't helping the sound any. It's temporary until they get out of the "climbing in/on everything phase".
Here are the troublemakers...
Played some frequency sweeps and measured results with my Radio Shack analog sound level meter. I've got some dips and peaks at the listening position. Contemplating the purchase of a Nady CM-100 Reference Measurement Electret Condenser Wired Microphone to run REW calibration software. How do I power the mic? Can I purchase an XLR to USB adapter and connect it to my computer?
sooo many words and pictures since the post quoted above!
Did anyone answer your questions, @halo? Most such mics run on phantom power, DC riding on the XLR mic cable (usually on the order of 15 volts or so, but depends on the mic). Most mic preamps would have the option of phantom power; some of the standalone analyzers/EQs do (the ancient Behringers here being an example, if not a very s-e-xy one)
HTH
... oh, and my apologies if you got the answer (and/or if I'm wrong!) and I just missed it!
Hello Mark,
No sir, no one answered my question so thank you for the reply! I was wondering if an XLR to USB cable would provide enough juice and I think it should do the trick.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Ordered this.
joecoulson wrote: »Ordered this.
Nice joe! I’ve got one coming on my new table. Not the planar 8 unfortunately but close enough in my opinion2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
I think you get most of the performance out of this cart with a 2 or 3 IMO
We’ll see I guess. -
Half the reason I didn’t get the 8 as I didn’t want to have to get the Apheta to do it justice. I got the 6 which is still a very highly regarded table. Along with the Ania/Fono MC2 Channel in my home attic/bar/man cave
Got this little guy yesterday for the spare room rig. Audioengine B1. Bluetooth receiver with AptX codec and built in DAC. Testing over the weekend.
You know, back in my day, an antenna was an antenna.
(borrowed image)
None of this subminiature rubber ducky... umm... stuff.
Another Pangea AC-9 cable arrived today!
Man...did you win the lottery recently? Congrats on all the new toys -
I wish brother! Just gotta be patient and wait for the bargains!
Fired up the 2 channel rig before work this morning its warmed up and ready for this evenings listening session.Home Theater
Received confirmation the Pass X0.2 is back at the Lab...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I'm thinking you're going to like that unit. I found mine has a decent onboard dac and it can also be improved by running the optical into a better dac. -
Stopped off at the Warehouse. Put this gem in the spinner.
Swapped in new Kimber Hero XLR's for the signal cable models. Like the change. Also repositioned the T2's with far less toe-in. Still considering selling the DAC2 for the PS Audio Stellar Gain Pre/dac.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
DO IT!! I love mine. Great piece.
Well the Marantz CD-1 is having some issues (drawer won't open fully) so I'm shipping it back for replacement. In the meantime, got the back up (Marantz CD6006) that I got from @stangman67 a while back in it's place. Nice to have spares!
motorstereo wrote: »Got this little guy yesterday for the spare room rig. Audioengine B1. Bluetooth receiver with AptX codec and built in DAC. Testing over the weekend.
Yep. Works great. I also have a Pro-Ject Bluetooth Box E, which is also a nice unit. Either one will eventually be paired with the Peachtree Nova.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Fear I melted a voice coil in one of my MW's.
Pro tip: Don't decide to change components well after midnight; you may not follow the safety procedures you're perfectly aware of when sleepy. Haven't fully investigated yet to determine extent of my eff-up. Just unplugged the rig and went to bed crabby.
Jay
[emphasis added]
I grieve with you for your loss
As the late, great Bawlmer O-rioles skipper, Earl Weaver used to say, it's important to have deep depth.
It's as true in hifi as it is in baseball.
012 by Mark Hardy, on Flickr
https://www.thedailybeast.com/earl-weaver-baseballs-brilliant-antagonist-dies -
Doc your listening room is awesome! Lots of depth!
