Thinking about an Integrated
My pre may be on the fritz, so I am contemplating going back to an integrated to simplify....McIntosh, Vincent, and yes....Musical Fidelity. I may even sell over my vinyl gear to help fund this. So....any ideas? Budget is 2K max, SS or tubed is fine, and used from the right seller is fine. Thanks....
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited January 2019
  • kevhed72
    kevhed72 Posts: 4,959
    That would work....nicely.
  • rburgess714
    There’s a Parasound Halo Integrated for $1500 on the forum flea market.
    https://forum.polkaudio.com/discussion/184894/lots-of-gear-for-sale#latest
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • rooftop59
    rooftop59 Posts: 7,981
    That’s long gone...cause I was seriously contemplating it. Skip needs to update that thread!
    Game Room 5.1.4:
    Bedroom 2.1
  • rburgess714
    Oh well. If I didn’t have the P5/A23 combo I would have jumped all over that.
    Living Room
    Office
  • halo
    halo Posts: 5,616
    edited January 2019
    kevhed72 wrote: »
    I was/am contemplating the same thing. I tried a Musical Fidelity M2si and I was not impressed. Despite its feature set (can be used as a dedicated pre if you decide to add an amplifier later - no phono stage or built-in DAC to muck up the signals) and class AB amplification, it just didn't "move" me.
    I got a chance to try out the Dayens Ampino with the Mundorf cap upgrade and it is a very good sounding unit. The only downsides to the Ampino, for me, are no remote control and the lack of additional inputs - it on has 2.
    Lastly, I have a NAD C316 BEE and it is a very well rounded and great sounding piece of equipment. A little more analytical than the Ampino but not sterile or lifeless by any means. Tons of inputs, especially this and even more on the newer v2 model. The NAD & the Ampino both feature a toroidal transformer. The only downside to the NAD is the volume control using the remote; it goes from quiet to loud pretty abruptly.
    After extended listening at moderate volume levels, neither the AMpino or the NAD got even remotely warm. The MF is avail for $599 from Upscale Audio (sale price and less expensive than anywhere else). The Ampino was ~ $500 with the upgraded caps IIRC. The NAD is the least expensive at under $400 but it is not the worst performer. Cost doesn't - quality or performance in this example.
    If you're into tube gear, the $2750 Bob Carver Corp Crimson 275 stereo tube power amplifier is getting some great press but there's a waiting period.
  • kevhed72
    If I go the MF route, I may look to their older integrateds with the built in tubes. I know these may be pricey buy always lusted over one...maybe lusted is the wrong word. McIntosh is another brand I have never owned but which I would like some day.
  • dromunds
    dromunds Posts: 9,984
    I heard a Luxman L-505UX the other day which sounded real nice and sure like the meters. He said he paid used about what your budget is.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Most importantly, what speakers?!?
  • kevhed72
    ZLTFUL wrote: »
    Totem Rainmakers
  • kevhed72
    How happy are you with this combo, because I already have the amp but no pre
  • rburgess714
    kevhed72 wrote: »
    It’s worked out well for me, I wanted a pre with ht bypass and had the A23 already so it made sense. It does everything I need. I primarily stream through my Auralic mini.
    Some say the sound is analytical/sterile but to my ears there is good synergy with my 60s and it sounds great, wide sound stage, detailed and not forward at all. Do keep in mind I jumped in the rabbit hole a little over 2 years ago and have been through some gear but certainly haven’t heard as much gear as most of the forum members.
    Living Room
    Office
    VR3 Posts: 28,052
    I have a nice Odyssey setup available 😜
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
  • kevhed72
    Alright....I spent all weekend at a swim meet looking at integrateds online...and here is a short list:
    1. Marantz PM 14 s1
    2. Dayens Ecstasy 2 or 3
    3. Vincent SV700 but this really pushes the budget
    4. Rogue Audio but the Pharaoh pushes the budget.
    5. Cambridge Audio 840
    Any other contenders out there?
  • halo
    halo Posts: 5,616
    kevhed72 wrote: »
    1. Marantz PM 14 s1
    I wouldn't go with the Dayens. Their CS and support of their products are a little off.
    Is there a certain sound signature you are after?
  • kevhed72
    Detailed and 3D....without being too foward. Everything I have read on the Dayens tells me its right in the middle, sweet spot. The Vincent appeals because of the tubed pre to play with the sound and the MK 236 was a past favorite of mine.
  • Upstatemax
    Upstatemax Posts: 2,623
    If you can find a good deal on one, I’ve been really happy with the Rotel RA1592 that’s currently in my 2ch system.
    If you can find an amazing deal on one, the McIntosh MA252 is awesome.
    The McIntosh seems to pair really nicely with Totem speakers. My Father has one hooked up to his Totem Signature One speakers.
  • joecoulson
    joecoulson Posts: 4,943
    Tubes and totems are fantastic. I only had a Jolida with my RM’s but I miss that combo. Great for classical and jazz. Not so much for full heavy rock and electronica. If I had the opportunity to have a secondary rig, I would get some tubes again.
    tonyb Posts: 32,906
    Primaluna….That new Carver 275, Mac, you should have grabbed that MF A5 in the FM for a g note.
  • joecoulson
    Primaluna’s are fantastic, good rec tony.
  • joecoulson
    tonyb Posts: 32,906
    Amen Joe, lol
  • kevhed72
    tonyb wrote: »
    I know right....thats what I get for driving my kids to swim practice! :p
  • kevhed72
    mhardy6647 Posts: 33,049
    Funny, I don't seem to notice many "Mac guys" on the forums braggin' much on their McAires. :|
    https://www.mcintoshlabs.com/products/lifestyle/McAire
  • displayname
    displayname Posts: 1,133
    edited January 2019
    They list it as a "lifestyle" product, but it should be called a "High WAF" product.
    My girlfriend has a JBL Authentics L16 for this exact reason. She loves the look, it fits on one shelf, and it does sound better than most 1 box products. She's fully aware she could have easily gotten an integrated and speakers, including some with style. That was not of interest though. Once she saw this it was a must have product.
    Assuming the day comes where we live together and have some more square footage to work with, I expect the L16 and her turntable to live in the living room, and my system to live deeper in the house out of the main areas.
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
    Discogs
    Tony M Posts: 11,017
    edited January 2019
    This NAD is around 1600.00 now. ;)B)
    I haven't heard one yet but they're on the used market now. I think the reviews were OK.
    https://www.ebay.com/itm/NAD-M3-Dual-Mono-Integrated-Amplifier-
    Remote/332969850249?epid=117462224&hash=item4d868cb589:g:SJYAAOSw8LZcHXso:rk:2:pf:1&frcectupt=true
  • joecoulson
    I really like the way those look
    Holy cow, that's a beefy looking NAD amplifier!
