Power Cables
audioluvr
So my next venture in this crazy world of audio is power cables. Currently running the flagship B&K M200 Sonata monoblocks. In my living room I have two outlets, one behind each speaker and they are on different circuits (different phases also) so each amp has it's own fairly dedicated circuit (one is shared with the pre and CD player). Where should I go from here? Power conditioners needed? Will any of it matter? I've been told differing information about whether their would be any improvement.
Thoughts?
Old pic...
Thoughts?
Old pic...
Thanks! There seems to be a ton of stuff out there but not sure what's truly good or sugar coated dog po op. My cable runs are maybe 2 meters at the most to each outlet. My amps have a 1KVA torroidal tranny each so they are capable of sucking up the juice if needed.Gustard X26 Pro DAC
Personally, after a few years of power and IC cable upgrades, I feel that cables are the foundation of a stereo. Get the foundation good and solid and then you can spend your time upgrading gear. With a weak foundation then you are constantly upgrading gear and cables.
Three 20 amp circuits. -
I bet we agree on a lot.
The rack is also important, as you said. Mine weighs 500 pounds empty so it is pretty solid.Lumin X1 file player, Westminster Labs interconnect cable
I have to put in a little plug (see what I did there) for PS Audio power cables. The first truly audibly different cable I have had the pleasure of trying.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Amps should be left off of power conditioners...a lot of them are current limiting. And unless you know for a fact they aren't, the amps themselves should have some power filtering themselves and it could create a negative cumulative effect.
What do you guys do if you plug right in the wall? In terms of power outages, surges, brown outs?
Whole home surge protection, cheap and easySince we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
motorhead43026 wrote: »Whole home surge protection, cheap and easy
^This"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Figured, when we have electrical work done in the basement I will be adding this. -
I unplug it. Most amps have the ability to withstand such problems. -
Yup...whole home surge protection. Of course, you could go extreme and install a whole home isolation transformer...but that's a LOT of scratch as I have discovered.
Just have Russ "acquire" one for you
I'd recommend getting a decent rack situated first. Pangea has a four shelf unit for $100 via Amazon that you should consider if for nothing more than to better stabilize the gear.
Thanks Skip. I currently have my components in a solid oak cabinet. Would this be okay if I put spikes under it? I really like the looks of it.
My B&K runs pretty hot, I imagine the monos are similar. I hope you have some kind of ventilation fan that's not visible, otherwise you're cooking those amps.
The cooling ribs stick out the back and when I play music I usually have the window behind it cracked open in the winter (wide open in the summer) and my ceiling fan on.Gustard X26 Pro DAC
Are there vents in the top of those? if there is you are just feeding that heat into the top amp as well. Excuse me if I'm wrong but if they are convection cooled anything on top will inhibit that. -
This is how my top looks. On the bottom they are in the same location. I have 1"x1"x15" spacers between the two just inboard of the top vent so the heat goes out and up the sides. I do try to keep a close eye on it and they don't seem to be getting what I'd call hot but if you guys think I should replace it...
maybe look into the solution @steveinaz used on top his Parasound amp (computer fans in a sturdy housing).
I've used AC Infinity units on top my B&K 200.5, Denon X4100 (which are in a rack with all sides but back enclosed) and they are nice, but cant take more than 30lbs on top, betting your monos are more than that.
Steve's solution can handle a lot more weight...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Personally I'd give them more room on the side and tops to breathe. Side vent and top vent need room for the convection cooling to take place. it is really hard to tell from the pictures 1. If that is a bottom vent on the side in the pictures you provided or just a shadow 2. How much room in the cabinet you have under and on the side to allow air to move or if it is solid wood sided.
Once again they're yours and if you keep a close eye on the heat build up and feel comfortable then rock on brother.
Only you know for sure. It's always easier to cast stones than to catch them with your teeth
After having the speaker cable epiphany, and the same for IC's, I've been dipping my toes in the power cord area. The Pangea's for me is a nice step, not too expensive, but boy they are beefy!
I'm running AC14 SE Mk2's to all my components. Want to get the AC 9's to feed the amp and power conditioner.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Much better choices than the 9's. Ridiculous to work with, to stiff.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Yep. Have to leave lots of space behind the components, for a proper bend radius.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
motorhead43026 wrote: »Much better choices than the 9's. Ridiculous to work with, to stiff.
Yes those 9's sure are ridiculous to work with and I could not imagine snaking them through a rack full of gear. I use the first generation 9's on my mc1201's and what a pita it was wrangling those 7 gauge wires into place. The arcs have to be huge as there's no give to them. But the end result was well worth the effort and hopefully I'll never have to move them again -
Forget Pangea. I started with them on my previous amps, but once I added the entry level Shunyata Venom cable I haven't looked back.
At that time, they only offered the Venom 14, but now you can get a version for amps.
https://shunyata.com/products/power-cables/venom-14/
https://shunyata.com/products/power-cables/venom-hc/Lumin X1 file player, Westminster Labs interconnect cable
Yep @BlueFox I've read good things about em. Drew @Clipdat had a good review that he posted recently, IIRC.
Hey you can always flip me your Pangea hand me downs!
That's what I keep telling my wife. -
I would, but I gave my extra cables away a couple of years ago.Lumin X1 file player, Westminster Labs interconnect cable
I know there’s not a lot of love for AQ but I love my Thunder /Niagara combo. Audible difference as much as any component when added
Not cheap however -
PS Audio PC's work for me. They were such a huge leap over stock, I never found it necessary to try any other. The quality is outstanding as the cost.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
