Power Cables
audioluvr
audioluvr Posts: 5,973
edited January 2019 in 2 Channel Audio
So my next venture in this crazy world of audio is power cables. Currently running the flagship B&K M200 Sonata monoblocks. In my living room I have two outlets, one behind each speaker and they are on different circuits (different phases also) so each amp has it's own fairly dedicated circuit (one is shared with the pre and CD player). Where should I go from here? Power conditioners needed? Will any of it matter? I've been told differing information about whether their would be any improvement.
Thoughts?
Old pic...
    edited January 2019
    Thanks! There seems to be a ton of stuff out there but not sure what's truly good or sugar coated dog po op. My cable runs are maybe 2 meters at the most to each outlet. My amps have a 1KVA torroidal tranny each so they are capable of sucking up the juice if needed.
  • BlueFox
    BlueFox Posts: 15,250
    Personally, after a few years of power and IC cable upgrades, I feel that cables are the foundation of a stereo. Get the foundation good and solid and then you can spend your time upgrading gear. With a weak foundation then you are constantly upgrading gear and cables.
  • BlueFox
    I bet we agree on a lot. :)
    The rack is also important, as you said. Mine weighs 500 pounds empty so it is pretty solid.
  • MrBuhl
    MrBuhl Posts: 2,419
    I have to put in a little plug (see what I did there) for PS Audio power cables. The first truly audibly different cable I have had the pleasure of trying.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Willow
    Willow Posts: 11,242
    ZLTFUL wrote: »
    Amps should be left off of power conditioners...a lot of them are current limiting. And unless you know for a fact they aren't, the amps themselves should have some power filtering themselves and it could create a negative cumulative effect.
    What do you guys do if you plug right in the wall? In terms of power outages, surges, brown outs?
  • Whole home surge protection, cheap and easy
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
    EndersShadow Posts: 17,713
    ^This
  • Willow
    Figured, when we have electrical work done in the basement I will be adding this.
    pitdogg2 Posts: 27,163
    Willow wrote: »
    ZLTFUL wrote: »
    I unplug it. Most amps have the ability to withstand such problems.
    ZLTFUL wrote: »
    Yup...whole home surge protection. Of course, you could go extreme and install a whole home isolation transformer...but that's a LOT of scratch as I have discovered. :o
    Just have Russ "acquire" one for you :smile:
    edited January 2019
    DSkip wrote: »
    I'd recommend getting a decent rack situated first. Pangea has a four shelf unit for $100 via Amazon that you should consider if for nothing more than to better stabilize the gear.
    Thanks Skip. I currently have my components in a solid oak cabinet. Would this be okay if I put spikes under it? I really like the looks of it.
  • DaveHo
    DaveHo Posts: 3,582
    My B&K runs pretty hot, I imagine the monos are similar. I hope you have some kind of ventilation fan that's not visible, otherwise you're cooking those amps.
    edited January 2019
    The cooling ribs stick out the back and when I play music I usually have the window behind it cracked open in the winter (wide open in the summer) and my ceiling fan on.
    audioluvr wrote: »
    Are there vents in the top of those? if there is you are just feeding that heat into the top amp as well. Excuse me if I'm wrong but if they are convection cooled anything on top will inhibit that.
    edited January 2019
    This is how my top looks. On the bottom they are in the same location. I have 1"x1"x15" spacers between the two just inboard of the top vent so the heat goes out and up the sides. I do try to keep a close eye on it and they don't seem to be getting what I'd call hot but if you guys think I should replace it...
    maybe look into the solution @steveinaz used on top his Parasound amp (computer fans in a sturdy housing).
    I've used AC Infinity units on top my B&K 200.5, Denon X4100 (which are in a rack with all sides but back enclosed) and they are nice, but cant take more than 30lbs on top, betting your monos are more than that.
    Steve's solution can handle a lot more weight....
    Personally I'd give them more room on the side and tops to breathe. Side vent and top vent need room for the convection cooling to take place. it is really hard to tell from the pictures 1. If that is a bottom vent on the side in the pictures you provided or just a shadow 2. How much room in the cabinet you have under and on the side to allow air to move or if it is solid wood sided.
    Once again they're yours and if you keep a close eye on the heat build up and feel comfortable then rock on brother.
    Only you know for sure. It's always easier to cast stones than to catch them with your teeth :#:#
  • verb
    verb Posts: 10,176
    After having the speaker cable epiphany, and the same for IC's, I've been dipping my toes in the power cord area. The Pangea's for me is a nice step, not too expensive, but boy they are beefy!
    I'm running AC14 SE Mk2's to all my components. Want to get the AC 9's to feed the amp and power conditioner.
  • Much better choices than the 9's. Ridiculous to work with, to stiff.
  • verb
    verb Posts: 10,176
    Yep. Have to leave lots of space behind the components, for a proper bend radius.
  • lightman1
    lightman1 Posts: 10,797
    ZLTFUL wrote: »
    Thank you Dan.... ;)
  • motorstereo
    motorstereo Posts: 2,358
    Yes those 9's sure are ridiculous to work with and I could not imagine snaking them through a rack full of gear. I use the first generation 9's on my mc1201's and what a pita it was wrangling those 7 gauge wires into place. The arcs have to be huge as there's no give to them. But the end result was well worth the effort and hopefully I'll never have to move them again
  • BlueFox
    Forget Pangea. I started with them on my previous amps, but once I added the entry level Shunyata Venom cable I haven't looked back.
    At that time, they only offered the Venom 14, but now you can get a version for amps.
    https://shunyata.com/products/power-cables/venom-14/
    https://shunyata.com/products/power-cables/venom-hc/
  • verb
    verb Posts: 10,176
    Yep @BlueFox I've read good things about em. Drew @Clipdat had a good review that he posted recently, IIRC.
    Hey you can always flip me your Pangea hand me downs! :smile:
  • Jimbo18
    Jimbo18 Posts: 2,350
    verb wrote: »
    That's what I keep telling my wife.
  • BlueFox
    I would, but I gave my extra cables away a couple of years ago.
  • joecoulson
    joecoulson Posts: 4,943
    I know there’s not a lot of love for AQ but I love my Thunder /Niagara combo. Audible difference as much as any component when added
    Not cheap however
  • motorhead43026
    motorhead43026 Posts: 4,017
    edited January 2019
    PS Audio PC's work for me. They were such a huge leap over stock, I never found it necessary to try any other. The quality is outstanding as the cost.
    Clipdat Posts: 13,098
    verb wrote: »
    Thanks Dave. https://forum.polkaudio.com/discussion/182963/shunyata-venom-14-power-cord-ongoing-review/p1
