Power Cables
audioluvraudioluvr Posts: 1,481
edited January 8 in 2 Channel Audio
So my next venture in this crazy world of audio is power cables. Currently running the flagship B&K M200 Sonata monoblocks. In my living room I have two outlets, one behind each speaker and they are on different circuits (different phases also) so each amp has it's own fairly dedicated circuit (one is shared with the pre and CD player). Where should I go from here? Power conditioners needed? Will any of it matter? I've been told differing information about whether their would be any improvement.
Thoughts?
Old pic...
Home System:
SDA 1C's - Full mod with the help by Dave...
1000 Va Dreadnought- w/ WireWorld Mini-Eclipse cables
WireWorld Mini-Eclipse 7 speaker cables
WireWorld Silver Eclipse IC's
Cambridge Audio Azur 851N - DAC/Streamer
Parasound Halo C-2 Pre/pro
B&K M200 Sonata Monoblocks
BLE-Design 16mm Power Cables
Denon DVD 2900
Barn system:
SDA SRS 2.3's Full mod done by myself
Carver C-1 pre
Carver M1.5t
BluDenso - Bluetooth receiver/DAC
  • ZLTFULZLTFUL Posts: 5,142
    Amps should be left off of power conditioners...a lot of them are current limiting. And unless you know for a fact they aren't, the amps themselves should have some power filtering themselves and it could create a negative cumulative effect.
    For power cables, look for something with quality construction and 99%+ OFC (Oxygen Free Copper) or even better, OCC (Ohno Continuous Cast *Copper).
    If you are worried about cost/benefit ratios, look into Pangea. I personally love their AC9 cables but they are far from flexible. The newest versions are better than the originals in that regard but still can be a handful. If you have some distance to go, the flexibility will be less of an issue.
    Their AC14SE cable would be the "next best" option. Smaller gauge of course but still a nice cable (I run AC9s to my amps and AC14SEs to all of my sources/pre).
    Next up from there in quality would be Wireworld, Cullen Cable, Douglas Connection and PS Audio cables. The sky is the limit really but to me, the best bang for the buck is those manufacturers.
    As for whether or not it will make a difference, ignore the static and let your ears decide. A lot of sellers these days offer trial periods or are even willing to let you try before you buy with a deposit.
  • audioluvraudioluvr Posts: 1,481
    edited January 8
    Thanks! There seems to be a ton of stuff out there but not sure what's truly good or sugar coated dog po op. My cable runs are maybe 2 meters at the most to each outlet. My amps have a 1KVA torroidal tranny each so they are capable of sucking up the juice if needed.
    Home System:
    Denon DVD 2900
    Barn system:
    Carver C-1 pre
    Carver M1.5t
  • ClipdatClipdat Posts: 7,300
    "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
  • DSkipDSkip Posts: 16,299
    I'd recommend getting a decent rack situated first. Pangea has a four shelf unit for $100 via Amazon that you should consider if for nothing more than to better stabilize the gear.
  • BlueFoxBlueFox Posts: 12,304
    Personally, after a few years of power and IC cable upgrades, I feel that cables are the foundation of a stereo. Get the foundation good and solid and then you can spend your time upgrading gear. With a weak foundation then you are constantly upgrading gear and cables.
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    BlueFox wrote: »
    Hey hey! We actually agree on something lol. For me the passive components of a rig serve as the foundation: cables, rack, and room. Get those to have as little impact on the sound as you can and you begin to actually hear each component for what it is and not just hear the artifacts and colorations that those three areas can introduce.
    For what it’s worth, I have been known to tune a system with a different plinth under an amp or speakers. No joke.
    I bet we agree on a lot. :)
    The rack is also important, as you said. Mine weighs 500 pounds empty so it is pretty solid.
    Lumin X1
    Sony XA-5400ES SACD
  • MrBuhlMrBuhl Posts: 2,427
    I have to put in a little plug (see what I did there) for PS Audio power cables. The first truly audibly different cable I have had the pleasure of trying.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • WillowWillow Posts: 9,752
    ZLTFUL wrote: »
    What do you guys do if you plug right in the wall? In terms of power outages, surges, brown outs?
    2Ch- B&W 703, SVS PB10 NSD, Marantz NR1607, Parasound 1500a, Pro-Ject Debut Carbon (Yellow) with Acrylic platter, Pro-Ject phono pre, MIT AVT 2 speaker cables, MIT AVT 1 and AVT 2 ICs, XLO Jumpers, Signal Dig Coax, Signal Cable Magic Power Cables x3, Samsung 55JS7000, Harmony 1100, Sony BDP-S6200, Marantz DV-4200 (as Transport), Cambridge Audio DAC Magic100, Monster 3600MKII, Android Mi Box3 and Apple TV. - Pool /Gazebo Yamaha RX-A1010, Polk Patio 25x4, Rotel RDV 1045 (as CDP) MIT AVT3 ICs - Work - Spotify Premium or Neutron App to my FiiO Kunlun into my Grado SR125e
  • motorhead43026motorhead43026 Posts: 3,334
    Whole home surge protection, cheap and easy
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; Cables ZU Mission IC's, SC and power cords, all into a PS Audio Dectet Power center.
    All TV's sound enhanced by Polk Magnfi Mini's.
    Other; S60'S, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All speakers have had crossover rebuilds, resulting in a small fortune invested in Sonicaps, and tweeter upgrades.
    Political memes posted as fact and accepted as fact, are sign language of the ignorant, for the ignorant
    tonyb said " but even socialists can do a good thing here and there
    Social media makes dumb people dumber and smart people dumb then dumber.
  • EndersShadowEndersShadow Posts: 16,937
    ^This
    Figured, when we have electrical work done in the basement I will be adding this.
  • pitdogg2pitdogg2 Posts: 14,952
    Willow wrote: »
    ZLTFUL wrote: »
    I unplug it. Most amps have the ability to withstand such problems.
    Yup...whole home surge protection. Of course, you could go extreme and install a whole home isolation transformer...but that's a LOT of scratch as I have discovered. :o
    ZLTFUL wrote: »
    Just have Russ "acquire" one for you :smile:
    edited January 9
    DSkip wrote: »
    Thanks Skip. I currently have my components in a solid oak cabinet. Would this be okay if I put spikes under it? I really like the looks of it.
    Home System:
    Denon DVD 2900
    Barn system:
    Carver C-1 pre
    Carver M1.5t
  • DaveHoDaveHo Posts: 2,497
    My B&K runs pretty hot, I imagine the monos are similar. I hope you have some kind of ventilation fan that's not visible, otherwise you're cooking those amps.
    edited January 9
    The cooling ribs stick out the back and when I play music I usually have the window behind it cracked open in the winter (wide open in the summer) and my ceiling fan on.
    Home System:
    Denon DVD 2900
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    audioluvr wrote: »
    Are there vents in the top of those? if there is you are just feeding that heat into the top amp as well. Excuse me if I'm wrong but if they are convection cooled anything on top will inhibit that.
    edited January 9
    This is how my top looks. On the bottom they are in the same location. I have 1"x1"x15" spacers between the two just inboard of the top vent so the heat goes out and up the sides. I do try to keep a close eye on it and they don't seem to be getting what I'd call hot but if you guys think I should replace it...
    Home System:
    Denon DVD 2900
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    maybe look into the solution @steveinaz used on top his Parasound amp (computer fans in a sturdy housing).
    I've used AC Infinity units on top my B&K 200.5, Denon X4100 (which are in a rack with all sides but back enclosed) and they are nice, but cant take more than 30lbs on top, betting your monos are more than that.
    Steve's solution can handle a lot more weight....
    Personally I'd give them more room on the side and tops to breathe. Side vent and top vent need room for the convection cooling to take place. it is really hard to tell from the pictures 1. If that is a bottom vent on the side in the pictures you provided or just a shadow 2. How much room in the cabinet you have under and on the side to allow air to move or if it is solid wood sided.
    Once again they're yours and if you keep a close eye on the heat build up and feel comfortable then rock on brother.
    Only you know for sure. It's always easier to cast stones than to catch them with your teeth :#:#
  • verbverb Posts: 8,274
    After having the speaker cable epiphany, and the same for IC's, I've been dipping my toes in the power cord area. The Pangea's for me is a nice step, not too expensive, but boy they are beefy!
    I'm running AC14 SE Mk2's to all my components. Want to get the AC 9's to feed the amp and power conditioner.
    Basement: Polk SDA SRS, Cary SLP-05 Pre, Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Silnote Morpheus Ref2 Digital Cable, Marantz SA-14 SACD, McIntosh MC300 Amp, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC, EAR Acute CD Player, EAR 834L Pre, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
    Spare Room: , Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated, Cambridge CXN v2 Streamer, Furman 15PFi Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi sub
    Much better choices than the 9's. Ridiculous to work with, to stiff.
    Yep. Have to leave lots of space behind the components, for a proper bend radius.
  • lightman1lightman1 Posts: 10,515
    ZLTFUL wrote: »
    Thank you Dan.... ;)
  • motorstereomotorstereo Posts: 1,343
    Yes those 9's sure are ridiculous to work with and I could not imagine snaking them through a rack full of gear. I use the first generation 9's on my mc1201's and what a pita it was wrangling those 7 gauge wires into place. The arcs have to be huge as there's no give to them. But the end result was well worth the effort and hopefully I'll never have to move them again
    Forget Pangea. I started with them on my previous amps, but once I added the entry level Shunyata Venom cable I haven't looked back.
    At that time, they only offered the Venom 14, but now you can get a version for amps.
    https://shunyata.com/products/power-cables/venom-14/
    https://shunyata.com/products/power-cables/venom-hc/
    Lumin X1
    Sony XA-5400ES SACD
    Yep @BlueFox I've read good things about em. Drew @Clipdat had a good review that he posted recently, IIRC.
    Hey you can always flip me your Pangea hand me downs! :smile:
Howdy, Stranger!
