Time for those SDA Upgrades? Plenty of boards available Kids
Be a good time to start, especially if your snagging one of the Dreadnoughts and cases in the group buy....
There is a group buy (might still be open) for the transformer here...
C'mon boys and girls daddy needs a shiny new amp! (GFA 565se)
Pink Floyd, Just makes me want to turn it up too 12 and share it with the world!!. JMO
Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
"Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
"50% Why... That's almost half."
"I know, I'm sick and need help."
---- Gimpod Custom 4th & 5th Gen SDA Circuit Boards
"The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
Home System:
SDA 1C's - Full mod with the help by Dave...
1000 Va Dreadnought- w/ WireWorld Mini-Eclipse cables
WireWorld Mini-Eclipse 7 speaker cables
WireWorld Silver Eclipse IC's
Cambridge Audio Azur 851N - DAC/Streamer
Parasound Halo C-2 Pre/pro
B&K M200 Sonata Monoblocks
BLE-Design 16mm Power Cables
Denon DVD 2900
Barn system:
SDA SRS 2.3's Full mod done by myself
Carver C-1 pre
Carver M1.5t
BluDenso - Bluetooth receiver/DAC
Howdy; New member tonight. I recently bought a pair of SRS2's. They are the 1986 model. I've been reading so much my head is going to explode, trying to avoid a newbie question flame fest. I have not yet found the answer I seek, soooo..
Can these boards be used in the 1986 model? And if so, would any component values be different than the 1987 info I've been reading?
Thank you, Brad
The 86 SRS-2s are 3rd generation, and are not compatible with the new boards.
My pleasure Tony @gimpod
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
"And keep her under 70, would you, huh? Betty likes a slow ride"
Den:
The answer is yes
Yes.....
See the links in the first post of this thread.
Denon DVD 2900
Barn system:
Carver C-1 pre
Carver M1.5t
Den:
Thank you, Brad
Den:
