Sound Bar Auto Lag
Kingkwas
My buddy, against my advice, bought a sound bar and is now complaining abt a delayed audio vs. video response
Any advice?
Any advice?
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
R: Def Tech
DVD: Oppo UDP 203
Is he connecting via Bluetooth?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Point your finger at him, laugh maniacally, and say, "I told you not to buy that!"Any advice? -
HDMI and OpticalAVR: Marantz SR 5011
R: Def Tech
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D -
I know on my TV there is a lip sync function- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I've had issue with certain devices like Fire TV stick giving me issues with a delay in audio. try connecting whatever the device of issue is directly to the bar or vise versa to see if it helps
I'll bet they have figured it out as it's almost a year old problem.
