What is this on my computer?
muncybob
Out of nowhere this vertical rectangular box has appeared in the upper left corner. Clicking on the X does nothing. The bar will fill with a color and then appear to be a meter showing a countdown back to zero. This thing comes and goes....?
Yep, my name really is Bob.
That is volume for your computer- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Chances are you are accidently turning down your volume somehow. I know my mouse had volume controls on it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Every time I try to increase the volume it auto fades to zero.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Sounds like you have a stuck button- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yup. You should have an up, down and mute button usually above the keyboard near the power switch.Home Theater/2 Channel:
dhsspeakerservice.com/ -
It has magically disappeared. Don't know how or why, just glad it's gone!Yep, my name really is Bob.
The Frosted Lucky Charms of Windows apps, it appears.
Turn the keyboard upside down, bang it really hard on a hard surface, watch a lot of junk fall out and dust and dirt and pray to god you did not hit it too hard....
Keyboards are cheap.... -
LOL.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Do the keyboard thing frequently(no banging, just shaking).
That damn thing showed up again this morningYep, my name really is Bob.
