no sound when I connected preamp and amp
pglbookpglbook Posts: 1,479
edited December 2018 in Electronics
I started another thread earlier today about connecting my Parasound HCA 1500A power amp and Parasound P/LD 1500 pre amp. I connected the amp and preamp about 2 hours ago and now the problem is no sound. I check the connections and all appear fine. The amp and preamp power up fine but no sound comes out of the speakers (speakers are fine and work with another recever I had connected; same for CD player). I had the power amp and preamp idle for some time. Could that have caused an issue? How do I tell if the issue is with the amp or with the preamp? Thanks.
  • marvda1marvda1 Posts: 3,298
    does the amp and/or preamp have a switch to go between balanced and unbalanced?
    make sure it is set to unbalanced (rca).
    Amplifiers: MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800, Usher R1.5
    Transport/Dac: Cayin Venus cd-100i, Musical Paradise mp-d2 mkI
    Speakers: Rosso Fiorentino Volterra
    Speaker Cables: Analysis Plus Black Mesh Oval 9, Cerious Technologies Graphene Extreme
    Interconnects: Analysis Plus Copper Oval-In Micro, MG Audio Design Planus Cu2,
    Power Cables by: Cullen Cables, 6sons Audio, Swiss Cables
  • pglbookpglbook Posts: 1,479
    marvda1 wrote: »
    Thanks. I just checked and there is no switch on either amp or preamp to go betwwen balanced and unbalanced.
  • EmlynEmlyn Posts: 2,191
    Couple things I can think of to check assuming the HCA-1500A runs through its power up correctly and the power light on the front turns green without any warning reds in the current overload lights.
    The amp has two sets of RCA jacks on the back. The top is for inputs. The bottom is for loop out.
    Also, there are what amount to volume controls for each channel on the back. Turn them all the way clockwise to the THX setting.
    It's unlikely the amp has an issue from just sitting. I've had one for many years and it starts up just fine whenever I decide to put it into action.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Sonic Frontiers Power 2 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
    Thanks, emlyn. Good suggestions but I did connect the rca cables to the upper (non loop out) rca input jack on the back of the amp and both thx levels were turned all the way to the right in the full position. The amp also runs through its power up progression fine. Could it be the preamp? or a fuse?
    My guess is it's likely the preamp causing the problem.
  • FestYboyFestYboy Posts: 3,256
    Plug your phone into the amp via 3.5 to RCA...
    Be sure to turn the volume on the phone all the way down first!!!
  • F1nutF1nut Posts: 41,019
    Is the mute turned on?
    Thanks. I do not see any mute functions on either amp or preamp. Do they have one?
    What input button do you have engaged? Is your source connected to that input?
    I have the amp connected to the preamp as such: amp’s upper rca input jack connected to the preamp’s fixed polarity (unbalanced) rca output jack. and i have a CD player connected to the preamp’s CD rca jack. and I had CD button of preamp engaged while trying to play a CD. But no sound. I also tried switching CD player to the Direct rca jack on back of preamp with the Direct button engaged on front of preamp. But same thing, no sound.
    Ok, did you engage the CD button on the front of the pre amp?
    yes but no luck, no sound. I also tried switching CD player to the Direct rca jack on back of preamp with Direct button engaged on front of pre. But same thing, no sound.
    Try moving the rca cables to the Aux input after turning off all power. Then power up and engage the Aux button.
    Thanks. You mean hook up the CD player to Aux? I don’t think I have tried that but will do so tomorrow (just on my way out). Thanks for all of the suggestions. I hope I can get these working soon.
    Yes. Don't forget to push play on the CDP. ;)
  • Gerres26Gerres26 Posts: 385
    Do you have the speaker wires connected to the amp?
    Gerres26 wrote: »
    Speaker wires are connected to amp. I also switched CD player to AUX jack this morning but still no sound.
  • tonybtonyb Posts: 30,569
    Have a volume control on the cdp ? Hook it straight up to the amp by the analog outputs. That way you'll see for sure if it's the pre giving you problems.
    HT SYSTEM-2 channel
    Dynaudio Audience 72
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    Analysis plus crystal oval ic's
    B&k 1430
    Tad 803 speakers
Howdy, Stranger!
