Rumble
If you want to eliminate the rumble and still use your Bottlehead pre try this: https://www.kabusa.com/frameset.htm?/rf1.htm
It's the only standalone rumble filter I've tried that did not affect sound quality. -
Thanks for the suggestion!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
@mhardy6647 @SCompRacer @ALL212 @Dawgfish - It seems that rumble filters are actually a bad thing (according to this post):
https://hifisystemcomponents.com/forum/why-rumble-filters-are-bad_topic2842.htmlHT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
The KAB filter definitely does not affect sound quality and I have no problems with lack of bass I can assure you! I also tried some cheaper filters that you can plug inline with your interconnects (think they were Harris but can't remember exactly) that had a cutoff of 20 Hz and they did affect the bass quality somewhat. The bass detail became slightly muddied. It wasn't bad however and these were not bad considering the $30-40 dollars or so I spent on them. To me running a rumble filter is a no brainer if you are experiencing rumble. I had to replace the driver in my REL sub and I'm pretty sure the reason I had to was from the excess rumble stressing the driver. If you have rumble, the rumble filter gives you good piece of mind for your amp, speakers, and sub(s).
Btw I experimented with sorbothane in various forms suspending a wood board (3" thick hickory cutting board) and it actually made rumble worse. I had the best luck with wood blocks being placed under the wood board as footers. I think the wood allows the vibrations from the stylus, arm, motor, bearings to be dissipated into the audio rack. For whatever reason I had the best luck with that, YMMV however. -
Some reading.
AK thread...
http://www.audiokarma.org/forums/index.php?threads/ported-speakers-and-subsonic-filters-why.394426/
Hoffman forums...
https://www.forums.stevehoffman.tv/threads/woofer-pumping-anything-to-worry-about.443388/
Try posting at Bottlehead forum. Not much comes up with "rumble" search. Nothing pops with "woofer pumping."
A rumble filter may be your only solution.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »Some reading.
AK thread...
Hoffman forums...
Thanks Rich!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
the other pre “solves “ the issue but only if the filter is on points to something other than the pre causing this since with that pre you see the same cone excursions.
Could be tubes but probably not both channels at the same time. If you don’t have extras to test with I’ll check stock for a pair of loaners.Aaron
Enabler Extraordinaire -
I agree that the likelihood is low but it's also easy to test.
The other thing that comes to mind is a "kit related issue" -- I've had (full disclosure) plenty of anomalies caused by my own poor soldering. Again, I think it is probably either acoustic feedback or some induced mechanical noise (from a bearing or whatnot) but it's worth checking all potential etiologies, no?
I am not a fan of subsonic filters per se -- but, then again, this isn't a problem that I've had myself, avec or sans a filter (some of the 1970s soiled state stuff here does have built in infrasonic filters, e.g.). It's kind of a brute force, "turn sideways to the problem" solution, but it can certainly work. -
How many hours on that TT? Try oiling the upper motor bearing/bushing if it's dry.
Does your doctor wife have a stethoscope? Listen to your tables heart beat.... I have a mechanical 'scope that I've used when building tables.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
May I ask why a bad tube could cause woofer pumping? Just curious.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
I am thinking of infrasonic oscillation, although something in the circuit is more likely than the tube to be the culprit in such a case.
SCompRacer wrote: »How many hours on that TT? Try oiling the upper motor bearing/bushing if it's dry.
I used synthetic motor oil (tiny amount ) in the sleeve that houses the sub platter. I read that was ok but would like to hear it from some of you fellas -
joecoulson wrote: »
Oil type is really dependant on bearing clearances. The tighter the clearance the thinner the oil. Older Rega's were loose and used a dollop of 80/90 weight gear lube. My custom stainless bearing in my Lenco turntable has really tight clearance and uses thin Turbine oil.
The turntable manufacturer should spec what to use. I'm sure you're OK using synthetic motor oil. Lots of folks do.
I use Hoppes synthetic firearm/fishing reel oil.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Here is an older interesting thread at diyaudio about the ultimate rumble filter.
https://www.diyaudio.com/forums/analogue-source/218801-ultimate-rumble-filter-effective-pass-filter.html
The 'Derumbleizer' mentioned in the thread. But now we have op amps and a high/low filter.
http://derumbleizer.com/
Price page...
http://derumbleizer.com/price2.htmSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I cannot believe the hoops turntable users go through. LOL. Enjoy.
Three 20 amp circuits. -
Victor, just recalled, did we ever look at re-checking coupling cap values for the Reduction? Didn't you change pre amps? I was really busy at the time and think I forgot.
I guess vinyl guys are gluttons for punishment? lol Solve the problem and no worries.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I am so glad I don't have any of this ****!
Don't even know if Vanilla Censors it. If only the subsonic world would naturally....
Can't say for sure but Aaron said it looked to be in very good shape when he went through it for me. In fact, this is the table you saw at Aaron's. I do have the appropriate Technics oil so I can apply some oil to the bearing.SCompRacer wrote: »How many hours on that TT? Try oiling the upper motor bearing/bushing if it's dry.
lol. She's a Ph. D. not an MD or a DO. So, no stethoscopes here.SCompRacer wrote: »Does your doctor wife have a stethoscope? Listen to your tables heart beat.... I have a mechanical 'scope that I've used when building tables.
SCompRacer wrote: »Victor, just recalled, did we ever look at re-checking coupling cap values for the Reduction? Didn't you change pre amps? I was really busy at the time and think I forgot.
I started with the Parasound P5 and you built the kit to that specification. Then I got the Cary CPA-1 and you changed the cap to match the value on the Cary. I still have the Cary so that shouldn't be the issue. I was contemplating a move to an integrated but there was no interest in my McCormack amp or the Cary preamp so I'm staying put with those pieces.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
SCompRacer wrote: »joecoulson wrote: »
Yeah -- you've gotta use the right goop for the job, as specified by the manufacture.
Folks invest great amounts of effort exploring, testing and debating the 'best' platter bearing (etc.) lubricants for, e.g., Thorens TD-124 turntables.
Overruled.
I'm a PhD, and we've got one
Heck, I'll bet the Tappet Brothers had 'em -- and those guys went to MIT.
Overruled.
My ex-wife was a nursing student for a brief time. She left her stethoscope but I don’t think that I kept it.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
I think mine was from my mother, now that you mention it
She was a nurse.
So, using just the Art DJ Pre II without the subsonic filter engaged produces cone excursion. With the subsonic filter engaged the cone excursion, if any, is associated directly with the music reproduction. So, I opine, the tubes are not causing the issue.
I'm still looking for the Technics turntable bearing oil I bought a year ago. I sent it to Aaron when he went through the SL-Q2 with a fine-toothed comb and I know he sent it back to me but I have to find it as it isn't with my other turntable "gear."HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
I concur with your assessment -- and if you posted that before and I missed it, I am sorry!
She's still a doc, right?lol. She's a Ph. D. not an MD or a DO. So, no stethoscopes here.
Aaron would have taken care of it. I saw him with a grease gun lubing everything.
SCompRacer wrote: »
Yes, she’s got her doctorate degree in biological sciences from Northwestern. So, technically, she is a doctor of philosophy in biological sciences. She is not a medical doctor or a doctor of osteopathy. She doesn’t see patients. She does research in a lab. Similar to doc hardy @mhardy6647HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
My point was you don't say "hey, phd," you say "hey, doc" like you just said doc Hardy...
OK I'll stop...
SCompRacer wrote: »
My point was you don't say "hey, phd," you say "hey, doc."
That’s an interesting point you bring up. Yes, she is Dr. Mendoza. But, most people don’t call her “doctor” unless they’re undergrad students and they’re being respectful. Her colleagues typically address her by her first name. Some of her former professors said, “hello doctor.” after she received her Ph. D. That was a very nice way of respecting the title and degree she recently earned and a nice way of welcoming her into their ranks.
Does that make sense or am I bad at explaining the difference? I mean, anyone who wants to call her doctor can do so and be 100% correct.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
