treitz3
Good afternoon ladies and gentlemen. This thread is dedicated to....well, read the title. Pretty self explanatory.
Today, I measured the distance of the subs/speakers to the listening position down to 1/8 of an inch including the toe in and will be messing around with dialing in the Rythmik F-25's.
What have you done for your rig today?
Looked at it longingly knowing that it'll have to wait till after Christmas...
I swapped out a digital coax on the EAD transport with my new Silnote Morpheus II
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Oh, after all there years...I never knew. *slaps head*
DOH!
I ignored mine today
Our son's home and we went to one of the local junk antique stores to prowl the aisles for treasures and/or last minute holiday gifts -- oh, and food items. The place also features a Cabot Creamery company store.... and essentially infinite free samples of Cabot products.
A good day
I bought a pair of Zu interconnects and they came on Friday. I am supposed to burn them in for 500 hours! The way things are going for me that would be a few years of listening sessions. Not wanting to wait that long I got out my old integrated amp and a tuner. Once I got the radio playing I could turn the volume off on the amp and will just let it run for a few weeks.
This morning I thought about my Monoprice 50 watt integrated that I recently upgraded with Russian tubes Why not burn in the tubes at the same time? Hooked this up into the mix by connecting the monoprice to the tuner then using its preamp out to the other integrated amp. Seems like everything is working well. I can turn the monoprice up higher than I would want to listen to with speakers so the tubes are getting broken in with a decent current. And when you turn the other amp off its peaceful and quiet -
Not quite sure you are burning in the cables though....and this might present an issue with the tubes not being under a load....
I took out one end of my speakon connector cable to see if I'll be able to replace it with a thicker and better quality Mit speaker cable. I'll probably need to hog out the hole a bit or use a little silicone grease or both.
Sorry Tom, but my system is a HT/Music system. But I'm listening to PP@M right now and it sounds great!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Turned it on to enjoy later tonight.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Merry Christmas, Cathy! You still qualify, as your rig still does 2C.
BTW, your abbreviations formed from the initial letters of other words and pronounced as a word have a 747 GOMH at an incredibly fast clip. BCOWYBS and have a great holiday!!!
"Sounds Great" is all I needed to hear!
Nothing.....yet
I have no idea what "BTW, your abbreviations formed from the initial letters of other words and pronounced as a word have a 747 GOMH at an incredibly fast clip. BCOWYBS and have a great holiday!!!" means.
Which probably means you didn't know that PP&M stood for Peter, Paul and Mary. Sorry.
Thank you Tom, may you have a great Holiday as well!
Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I went to @treitz3 house and swapped the positive and negative in his left speaker- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
GOMH - "Go over my head"
BCOWYBS - "But go on wit'cho Bad self!"
Shut up Trey.
Shut up Russ.
Not Trey.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I am pretty sure the interconnect and tubes are under load even though no sound is coming out of the speakers. They should be giving the signal to the integrated amp. Its just that the integrated amp isn't amplifying the signal so when the volume is turned down (on the integrated amp) I get no sound. It is kind of a unique setup. If I have both amps off then no sound. If either amp is on half way I can use the other to adjust the volume. I have the tubed pre on at over 12:00. Normally that would be too loud but with the volume on the amp off i don't hear anything. When i check on things and turn up the integrated I hear music. So the pre and interconnect is constantly sending a signal
Or at least thats what I am hoping is happening. If you have more than one line level inputs running (like a CD player) I assume the amp is still getting getting the signals from all of the inputs. The amp is just amplifying one. (at least I hope so).
But you have a good question. Do preamps and line level inputs draw more power as an amplifier is turned up? -
Dude that's DEEEEEEP
What is the Matrix?
I turned it on and listened to it🤣🤣🤣Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
No, they don't. The source current remains the same. That is unless there's an output gain pot in the mix, then the current is variable. -
I tweaked speaker positionMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Prepped it for the installation of my new(to me) Pass Labs X0.2 and Xono preamp/phono stage. When they arrived today, I gleefully opened the boxes to discover they were nowhere near the condition described. So I contacted the seller and am trying to work a solution.
They sit outside my rack tonight, uninstalled and no music will fill my house tonight, unless it comes from my wife's crappy cellphone speakers.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I understand cosmetic concerns, but still, why not listen to them?Lumin X1 file player, Westminster Labs interconnect cable
Because I am not going to rewire my stack of stuff until I am certain it is going to stay put. The seller has stated he may want to have the gear returned, and if that is the case I would rather just do that than spend hours to wire things up, several days for the Pass to settle down and then take it all apart again.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Thinking about my rigs while in Vegas on vacation!
Drive that C8 prototype down here to L.A. and say hi. I can keep a secret.
Just admired it 😬
I licked my Joule, in hopes that the previous owner did not.
lsi 9's -
Sounds like those yoga lessons are paying off...I licked my Joule, in hopes that the previous owner did not.
Changed the batteries....
