Rega Planar 2
So as some of you know I struggled with the old Pro-ject and lost. I am fickle in the fact I hate to have any part of my system down for the count so I went out last night and picked this guy up
When I got it home, the first thing I did was swap out the Rega Carbon cartridge for my Nagaoka MP-110. I love this cart and have read how well it pairs with the English TT.
The sound this table puts out makes me wonder why I kept struggling with the PJ for all those years. Imaging and blackness have vastly improved. Not to mention I don’t have the famous Pro-ject rumble anymore. The motor is the new 24v one and it’s so quiet. The deck is the gloss black and looks fantastic
What was strange to me was that there is no ground wire. It threw me at first and I thought it had some cheap phono pre built in. But apart it’s part of the RCA connections. Not family with that but no issues. Dead silent.
The tonearm is really slick too. Much more simple that the latter and tech is as it should be for 15 years newer.
Very happy with this, it’s not a high end deck by any means, but it’s a damn sight better than the PJ. Plus the glass platter looks pretty awesome from the side.
Thanks for reading.
  • verb
    verb Posts: 10,176
    Cool! I got the P1 from @scubalab - still getting to know it better. So far so good! Have fun my man! :smile:
    SCompRacer Posts: 9,120
    edited December 2018
    Nice table! Once upon a time I had a Rega Planar 2 with RB200 arm.
    Regarding TT grounds, they can be a separate wire or they use the Left channel ground or none at all. There were even ground straps from cartridge to headshell using Left channel ground.
    Post edited by SCompRacer on
  • halo
    halo Posts: 5,616
    It's a very nice looking table and it's well regarded against other tables in that price range (and beyond). You could do a lot worse.
    I really love the MP-110 cart as well, glad you're enjoying it!
  • joecoulson
    joecoulson Posts: 4,943
    Thanks gentlemen.
  • joecoulson
    Just ordered this and a new clamp to go with the new deck..
  • gfong
    gfong Posts: 1,079
    Nice table, glad you are enjoying it. The upgrades will be nice! I really like Rega tables, stylish easy to set up and nice sound.
  • steveinaz
    steveinaz Posts: 19,545
    Love the simple elegance of Rega tables. If I ever got back in the vinyl game, the P3 would likely be my pick.
  • Congratulations. That is one beautiful piece of equipment.
  • joecoulson
    And when this arrives
    I’ll update with some beauty shots.
  • joecoulson
    Nice upgrade!
  • halo
    halo Posts: 5,616
    Looks great! How do you like the cork mat?
    I went with the Way Excellent II turntable mat from Herbie’s Audio lab at the suggestion of @SCompRacer and @ALL212 and I really like it.
  • joecoulson
    Not sure it’s stops all static. What’s the link for that mat and do you like it? Pic?
  • motorhead43026
    motorhead43026 Posts: 4,017
    Google...………….Way Excellent II.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • joecoulson
    Didn’t ask you....
    J/k
  • Looks interesting, I checked it out.
  • motorhead43026
    There is a used Rega 2 on Ebay with an optional RB250 tonearm. Would any of you Rega owners know if it makes a discernable difference.
  • joecoulson
    @halo did you have other mats before that one?
  • joecoulson
    DSkip wrote: »
    Anyone looking at Rega should also look at JWM turntables. They're Rega with a custom plinth.
    Beautiful looking tables Skip
  • halo
    halo Posts: 5,616
    joecoulson wrote: »
    I had a leather deer hyde mat before that. It was supposed to reduce static buildup but I didn’t notice any difference between it and the rubber mat that came with the table.
    https://www.amazon.com/Premium-Leather-Deer-Hide-Turntable/dp/B00JDWHDSS/ref=sr_1_21_sspa?ie=UTF8&qid=1544323205&sr=8-21-spons&keywords=turntable+mat&psc=1
  • joecoulson
    And the Way Excellent Mat II helped?
    I know the cork does better than any other felt may I have had.
    If your tone arm doesn't have adjustable VTA (Vertical Tracking Angle) you have to watch the thickness of mats you add to a turntable that didn't come with a mat.
    A thick mat will lift cartridge end of arm. If arm cannot raise arm at pivot end, you can run into issues with SRA or Stylus Rake Angle.
    In other words, SQ or sound quality can suffer if stylus is not at the correct angle in the groove.
    Here is a diagram that exaggerates but shows what I mean.
    To reduce static tics, you could look at a dust bug or grounding type dust bug. My old dust bug doesn't have a grounding strap. You would moisten (do not saturate) the bug with distilled water or that Discwasher cleaner.
    This is one I have and still use sometimes.
  • joecoulson
    Wow what a great principal for dealing with static. Works well?
    Tony M Posts: 11,673
    I like how newer TT's look like works of ART.
    Your Rega looks great! ;)
  • joecoulson
    Thank You Tony. I’m a mess as of late. Just ordered a Vincent phono Pre so she should be purring even better pretty soon.
  • verb
    verb Posts: 10,176
    joecoulson wrote: »
    What Vincent did you get? I’ve been eyeing the PHO 700 or 701.
  • halo
    halo Posts: 5,616
    SCompRacer wrote: »
    Looks like I have to go to eBay for a Watts dust bug. There's another version made by Rek O Kut available at Needle Dr. Which is the one you have in the photo Rich?
    Watts:
    Rek O Kut:
  • joecoulson
    verb wrote: »
    joecoulson wrote: »
    The 701. I’ll be going from a Cambridge Audio Solo to it and I have read specific reviews making that exact change with huge improvements so I’m very excited. $499 at AA.
    Mine is the Watts. It does impose a drag but not significant. If you have a speed control turntable it will compensate.
