Rega Planar 2
joecoulson
So as some of you know I struggled with the old Pro-ject and lost. I am fickle in the fact I hate to have any part of my system down for the count so I went out last night and picked this guy up
When I got it home, the first thing I did was swap out the Rega Carbon cartridge for my Nagaoka MP-110. I love this cart and have read how well it pairs with the English TT.
The sound this table puts out makes me wonder why I kept struggling with the PJ for all those years. Imaging and blackness have vastly improved. Not to mention I don’t have the famous Pro-ject rumble anymore. The motor is the new 24v one and it’s so quiet. The deck is the gloss black and looks fantastic
What was strange to me was that there is no ground wire. It threw me at first and I thought it had some cheap phono pre built in. But apart it’s part of the RCA connections. Not family with that but no issues. Dead silent.
The tonearm is really slick too. Much more simple that the latter and tech is as it should be for 15 years newer.
Very happy with this, it’s not a high end deck by any means, but it’s a damn sight better than the PJ. Plus the glass platter looks pretty awesome from the side.
Thanks for reading.
Thanks for reading.
Cool! I got the P1 from @scubalab - still getting to know it better. So far so good! Have fun my man!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Nice table! Once upon a time I had a Rega Planar 2 with RB200 arm.
Regarding TT grounds, they can be a separate wire or they use the Left channel ground or none at all. There were even ground straps from cartridge to headshell using Left channel ground.
Post edited by SCompRacer onSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
It's a very nice looking table and it's well regarded against other tables in that price range (and beyond). You could do a lot worse.
I really love the MP-110 cart as well, glad you're enjoying it!Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Thanks gentlemen.
Just ordered this and a new clamp to go with the new deck..
Nice table, glad you are enjoying it. The upgrades will be nice! I really like Rega tables, stylish easy to set up and nice sound.
Love the simple elegance of Rega tables. If I ever got back in the vinyl game, the P3 would likely be my pick.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Congratulations. That is one beautiful piece of equipment.
And when this arrives
I’ll update with some beauty shots. -
Nice upgrade!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Looks great! How do you like the cork mat?
I went with the Way Excellent II turntable mat from Herbie’s Audio lab at the suggestion of @SCompRacer and @ALL212 and I really like it.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Not sure it’s stops all static. What’s the link for that mat and do you like it? Pic?
Google...………….Way Excellent II.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
Didn’t ask you....
J/k -
Looks interesting, I checked it out.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
There is a used Rega 2 on Ebay with an optional RB250 tonearm. Would any of you Rega owners know if it makes a discernable difference.
@halo did you have other mats before that one?
Anyone looking at Rega should also look at JWM turntables. They're Rega with a custom plinth.
Beautiful looking tables Skip -
joecoulson wrote: »@halo did you have other mats before that one?
I had a leather deer hyde mat before that. It was supposed to reduce static buildup but I didn’t notice any difference between it and the rubber mat that came with the table.
https://www.amazon.com/Premium-Leather-Deer-Hide-Turntable/dp/B00JDWHDSS/ref=sr_1_21_sspa?ie=UTF8&qid=1544323205&sr=8-21-spons&keywords=turntable+mat&psc=1Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
And the Way Excellent Mat II helped?
I know the cork does better than any other felt may I have had. -
If your tone arm doesn't have adjustable VTA (Vertical Tracking Angle) you have to watch the thickness of mats you add to a turntable that didn't come with a mat.
A thick mat will lift cartridge end of arm. If arm cannot raise arm at pivot end, you can run into issues with SRA or Stylus Rake Angle.
In other words, SQ or sound quality can suffer if stylus is not at the correct angle in the groove.
Here is a diagram that exaggerates but shows what I mean.
To reduce static tics, you could look at a dust bug or grounding type dust bug. My old dust bug doesn't have a grounding strap. You would moisten (do not saturate) the bug with distilled water or that Discwasher cleaner.
This is one I have and still use sometimes.
Wow what a great principal for dealing with static. Works well?
I like how newer TT's look like works of ART.
Your Rega looks great!
Thank You Tony. I’m a mess as of late. Just ordered a Vincent phono Pre so she should be purring even better pretty soon.
joecoulson wrote: »Thank You Tony. I’m a mess as of late. Just ordered a Vincent phono Pre so she should be purring even better pretty soon.
What Vincent did you get? I’ve been eyeing the PHO 700 or 701.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
SCompRacer wrote: »To reduce static tics, you could look at a dust bug or grounding type dust bug. My old dust bug doesn't have a grounding strap. You would moisten (do not saturate) the bug with distilled water or that Discwasher cleaner.
Looks like I have to go to eBay for a Watts dust bug. There's another version made by Rek O Kut available at Needle Dr. Which is the one you have in the photo Rich?
Watts:
Rek O Kut:
The 701. I’ll be going from a Cambridge Audio Solo to it and I have read specific reviews making that exact change with huge improvements so I’m very excited. $499 at AA. -
Mine is the Watts. It does impose a drag but not significant. If you have a speed control turntable it will compensate.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
