Parasound P6 VS PS Audio Stellar Gain Pre/DAC
Anyone have either one of these and if so your thoughts?
«134
    Clipdat Posts: 13,094
    I don't have anything meaningful to say, except for that the Parasound is backordered until 12/31. Just FYI if you were thinking about trying to get it before the end of the year.
  • joecoulson
    joecoulson Posts: 4,943
    edited December 2018
    Yes. I know and it’s what prompted bringing the PS A into the mix
  • steveinaz
    steveinaz Posts: 19,545
    Get what you WANT---NOT was is available. That never ends well.
  • jdjohn
    jdjohn Posts: 3,348
    I have a PS Audio Stellar Gain pre/DAC and like it very much. It replaced a Peachtree Audio novaPre hybrid w/DAC for me. I've never played with a Parasound P6...or any of their gear, actually.
    It looks like the P6 has more bells and whistles for sure. The Stellar Gain is much simpler.
    Of course I can't compare sound qualities between the two, but I can tell you the Stellar Gain has done everything I've asked of it, and it is super quiet. PSA goes into a lot of detail on their website about the Gain Cell technology. I actually bought their S300 class D amp as well.
    For DAC purposes, I run a Logitech Squeeze Box Touch with digital coax out into the Stellar Gain's DAC. It has an IS2 input if that is important to you.
    For analog, I run an external phono preamp into one of the analog input pairs on the Stellar Gain pre. I see that the P6 has a built-in phono stage.
    I've had a few other PSA products, and just seem to like their stuff. Parasound seems to get more love here than PSA, but that's fine. Parasound clearly makes good gear as well.
  • joecoulson
    Thank You for the feedback
  • kharp1
    kharp1 Posts: 3,453
    I have the PSA Direct Stream DAC as well as the memory player, so more apples to oranges, but, I have nothing but good things to say about them. I'm extremely impressed with them and how they handle their business. Will be purchasing the upcoming streamer when it comes out next year, and, may ultimately move to an all PSA system.
    I have no experience with the P6 but did own a 5. Wasn't impressed. The DAC was not good. As a stand alone pre it was decent, but, it didn't make the cut and was quickly sold. True, they have lots of bells and whistles, but, I don't want or need bells and whistles...just need a good piece of gear that sounds good.
  • joecoulson
    Again. Good feedback. I’m slowly thinking the bells and whistles get more attn and I have seen lots of much higher end guys than me going all PSA like yourself. Food for thought. Thank You
    Joe, are you open to other preamp suggestions aside from just Parasound or PS Audio?
  • joecoulson
    Others for sure with similar connectivity
  • Patriotism is the last refuge of a scoundrel…….Samuel Johnson
    – Kevin Alfred Strom
    Impressive backside.
  • kharp1
    kharp1 Posts: 3,453
    Underwood has the Stellar Gain Cell for $1079 delivered right now. P6 runs $1500. Anthem at $4k is a sizable increase in price. Wonder if it offers 3-4x the sound quality.
    tonyb Posts: 33,072
    kharp1 wrote: »
    You know how that usually turns out.
    Man, for the price of that Anthem, you could get a nice Joule, Vac, VTL and still have change for an amp or nice Dac. Even one of those fancy integrateds like the Mac or Carver, and still have change left for a dac, or a streamer, better cables.
  • joecoulson
    Kerry how did you know it was that price? Did you call?
  • kharp1
    kharp1 Posts: 3,453
    I get ads from them. Call him and talk to him, he's pretty good to deal with. I'll try and PM you the ad.
  • joecoulson
    That’s cool because their warehouse is across town from me.
    tonyb wrote: »
    Serious question: How does that usually turn out?
    Because my last several experiences have very much been "you get what you pay for".
  • kharp1
    kharp1 Posts: 3,453
    Clipdat wrote: »
    tonyb wrote: »
    There is a point of diminishing returns. If you have the money and want to spend 4x that's a personal thing, one I won't fault a person for, but, when you're moving from one elevated level to the next the returns are harder to justify.
    No disrespect to Anthem, I had one of their pre amps, just generalizing.
    I do agree that you often get what you pay for, but, again, when you get to a certain level the expectation of quality should be given.
  • joecoulson
    Clipdat wrote: »
    tonyb wrote: »
    Sans the AQ cable..
  • afterburnt
    afterburnt Posts: 7,892
    If a $5000 system sounds twice as good as a $2500 system. Will a $10,000 sound twice as good as a $5000 system etc? My guess is once you get to a certain point improvements are less substanial. Will a $100,000 sound as good as a $200,000 system? I doubt I will ever know but I would bet that 200k system would sound damn near as good as a $1,000,000 system.
    I have a P5 and it gets its main job done just fine. The DAC and the phono stage leave something to be desired. It looks like Parasound has improved on these aspects in the P6. However if I were moving up I would likely look in another direction sans the extra bells and whistles.
  • joecoulson
    DSkip wrote: »
    kharp1 wrote: »
    Clipdat wrote: »
    tonyb wrote: »
    I actually disagree with diminishing returns. I think as you move up you have bottlenecks that can create said diminishing returns. The reason a $3,000 DAC can perform at the level of a $10,000 DAC boils down to the system it is placed in. It's not really an account of the cheaper unit playing UP to the expensive units level, but the expensive unit being forced to play DOWN to the level of the cheaper unit.
    I used to believe in the diminishing returns argument but as I've gone higher and higher my viewpoint has changed.
    Hmm. Wondering if the massive amount of coin colors the view...;)
    pitdogg2 Posts: 27,034
    you could also check out some used Ayre pre-amps they are pretty reasonable used and great pieces.
  • joecoulson
    For sure I’m not rushing into this one. I almost called Underwood today and ordered that one. Gonna see about waiting to do more research
  • joecoulson
    May even go tube pre
  • kharp1
    kharp1 Posts: 3,453
    DSkip wrote: »
    kharp1 wrote: »
    Clipdat wrote: »
    tonyb wrote: »
    Looking for the "you're a moron" button. ;)
  • kharp1
    kharp1 Posts: 3,453
    I figured you'd catch up sooner or later.
  • joecoulson
    Lmao. Was wondering why you were slamming that other thread
  • joecoulson
    Stellar Gain it is. Pick it up Thursday.
    I'm a sucker for a digital volume display! I like it's looks.
    Backside also looks good:
    Inside looks tidy as well:
  • joecoulson
    I'll be using the balanced in's and outs also
    ins for the CA CXN
    outs for the SVS SB16
