Post a picture... any picture
1…274275277279280…1153
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
    pitdogg2 Posts: 27,901
    mrbiron wrote: »
    Based on the caption, and me reading too far into it, this only happens when you Chuck a frozen turkey into a fryer "ahead of Thanksgiving". This suggests that you may be ok with the same approach on the actual day...
    No many times folks do not mark a spot on the side to fill oil to. First step is to use water with turkey in pot. Fill till it just covers all the bird with plenty of room at the top to keep from boiling over. Then remove bird mark spot on pot to where water is at without bird, that is max oil you can put into pot.
    Then dry pot and bird bring oil up to temp slowly lower bird into pot.
    Most amateurs forget about weight displacement of oil and just put a jug in and well you see the rest in the video.
    Toolfan66 Posts: 18,420
  • joecoulson
    joecoulson Posts: 4,979
    stretchl wrote: »
    . ...I love the second image.
    Me too! That’s awesome man.
    mhardy6647 Posts: 35,561
  • OleBoot
    OleBoot Posts: 3,138
    edited November 2018
    Four cylinder, two valves per cylinder. (Think British)
  • OleBoot
    Viking64 wrote: »
    A)What a bloody row.
    B)How do you roll up a valve to smoke it?
    txcoastal1 Posts: 13,520
    43184092041_879d11df81_h.jpgffhb18_38 by Holger Barske, on Flickr
    Definitely an exotic using EL12's😉
  • joecoulson
  • BlueBirdMusic
    Harry / Marietta GA
    audioluvr Posts: 6,073
    My neighbors place. Living the dream!
    Viking64 Posts: 7,808
    audioluvr wrote: »
    I don't want that sink.
    Ha! Which one?
    audioluvr wrote: »
    Ha! Which one?
    Well, I guess I could use the aerator out of the one with the faucet, so I guess I don't want the other one. :p
    1934 BMW R7. One of one
  • motorhead43026
    Cumberland Falls, KY.
    And the boots you lick will stomp you too.
  • joecoulson
    Nice! ^^^
    Purdy!
  • OleBoot
    Botox lips. I blame Mick Jagger.
  • charley95
    audioluvr wrote: »
    He have a neighbor named Eddie?
    OleBoot wrote: »
    I blame the rest on Kenny Rogers. :p
    or Steven Tyler.
    Tony M Posts: 12,003
    For real... :# ...WHY!!!
    Tony M wrote: »
    Allergic to bee stings? :p
    Ugh. Way to go Jimmy. See what you started?
    audioluvr wrote: »
    I'll tell you what. I'll grab a pin and see if I can let some of that ugly out. :o:p
