RT1000 parts
OrangeSkullz
Have a pair of rt1000's that I'm more than satisfied with for the last 15 years.
Question is, I recently moved and the base of one of the towers was broken. Is there any place I can get a replacement base to get it back to normal. I still have all 4 feet to put back into the base if I can find a replacement part.
Thanks for any info provided!
No response basically explains what ive read numerous times on here.
This pretty much sets in concrete, I WILL NEVER BUY ANOTHER PIECE OF EQUIPMENT FROM THEM. -
OrangeSkullz wrote: »No response basically explains what ive read numerous times on here.
The company probably won't be responding to you here, just us knuckleheads who can't really help you. Try calling them directly on Monday. If they have a solution, they're usually very helpful.
Also, imagine complaining about any other product/customer support after 15 years... Temper your expectations. -
Its VERY doubtful that they have your part. The speakers are almost vintage at this point. EBay is your best bet, and the part will probably pop up but it might take a couple months...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
If you're into woodworking, you should be able to fabricate one.
Yeah it won't be the same, in appearance, but you should be able to get it close. Or make a matched set, call em custom The plastic cone on the base is just glued in place, comes off easily to be re-used.
BTW, welcome to the forum!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
