Simple sda 2b tl upgrade question
I am going to be purchasing parts for the tl upgrade soon for a pair of sda 2bs. I just wanted to make sure they will accept the upgrade. I'm 95% sure they are the 2bs because they have 1 tweeter, 2 woofers, 1 passive., wood caps, wrap around grill and a single crossover.
The only thing that makes me wonder if they would accept the upgrade is that they are the transitional version(blade/blade). Does this effect anything? What exactly allows for the TL upgrade? Is it the crossover, drivers or something else?
«13
  • headrott
    headrott Posts: 5,496
    edited November 2018
    The 2B's with a blade/blade interconnect cable have to use a single crossover board (which I believe all 2B's did, but am not 100 percent on that). Mine are also blade/blade, but accepted the TL upgrade with no problem. Make sure you buy and install the RD0-198's after doing the TL upgrade on the crossover boards.
  • Thanks headrott that gives me some assurance.
    I know others have described it with other sda speakers but would you mind describing your experience before and after the upgrade and what caps(ie solen sonicap ect..) did you use?
  • headrott
    I used Sonicaps and Mills resistors on my 2B (TL's). I am not sure Mills resistors are still made (or at least if they are made by the same company). I could definitely recommend Clarity Cap ESA's (or whatever modern version of the capacitors that are making) and Duelund Cast resistors. I prefer them over Sonicap and Mills as they are more detailed, but are not harsh at all, IMO. I used Clarity Cap ESA's and Duelund Cast resistors in my 2.3TL's.
    Just being able to use the RD0-198 tweeters will give you a warmer high end, and more detail than the RD0-194 tweeter. Either of the RD0 tweeters will be absolutely better than the SL-2000 tweeter, which is harsh and rough on the ears.
    Upgrading to the TL will allow you to use the RD0-198 tweeters (which as stated are more detailed and smoother than the RD0-194's (asa stated either of the RD0's are much much better than the SL-2000's).
    Do the TL upgrade with Clarity Caps and Duelund Cast resistors if you plan on using the 2B's as your main speakers. You won't regret it (after letting them burn in).
  • TennMan
    TennMan Posts: 1,267
    I can recommend forum member westmassguy if you need someone to do the crossover upgrade for you. He does excellent work at a reasonable price. He will be able to answer all your questions about upgrading your blade/blade 2Bs.
  • Faustin
    Faustin Posts: 1,151
    I second TennMan's advice/suggestion.
  • Thanks for the advice though I want to do the work myself. I like feeling of ownership that I get when I've done the work.
  • headrott
    Take your own advice @windstriker and do the work yourself (if you have enough electronic experience and proper equipment to get the job done well). You feel fulfilled doing the job yourself using the @gimpod crossover boards (purchased from @westmassguy) along with the caps and resistors. Let us know how it turns out!
  • agfrost
    agfrost Posts: 2,470
    Advice above is good. I also TL'd a pair of blade-blade 2Bs successfully and would strongly recommend getting a pair of gimpod boards for ease of assembly. Click around on his site to see suggested parts ordering and board layout for your 2Bs: http://gimpod.com/
    Jay
  • Not a lot of electronic experience but i done some here and there(monitor, turntable, ect). I've already removed the polyswitch. Never recaped though, I'm going to warm up with a recap of some old advents. I will think hard about getting the new gimpod board. Will keep y'all posted :)
  • headrott
    The gimpod boards are an absolute no-brainer. Buy them and do the recap with those; You will not regret it. Using sonicaps, clarity caps, etc. is up to you. I recommend Clarity Caps ESA (or whatever the new version of them is) and Duelund Cast resistors, but that is my opinion.
  • Before I modded my 2Bs they also had a blade/blade i/c. After all the mods they sound nothing like stock and besides the cost of x-overs> Larry;'s rings? new terminal cups> adding Nuetrik/Speakon connectors. The other stuff was very cheap. They also contained single x-over boards. Oh I went the standard way w/ the RDO- 194s.
  • windstriker
    windstriker Posts: 138
    Hi again, Sorry to reopen a old thread but I thought I would give a update. So after my last post life got in the way and the upgrades were sadly postponed. I just finished a round of upgrades.
    Already had done last year:
    - Upgrade tweeter to rdo 194
    - removed polyswitch
    Included in this upgrade:
    -Cosmetic fixes(still a work in progress)
    -h nuts installed.
    -dynamated baskets.
    -used armacell for one of the passive radiators(didnt have a gasket at all for some reason)
    -one of the woofers had a pin sized whole in the surround so I put a new surround on it
    Reaction to this round of upgrade:
    The mids are definitely clearer and while i don't think I'm getting that much more bass but it does sound more refined and detailed. Very Happy so far.
    Next round will be(in a month or two):
    - Rdo 198 tweeter
    - gimpod board
    - new caps and resisters(sonicap/mills)
    This is the upgrade I'm most looking forward to
    Last round a few months later:
    Black hole 5
    Not sure if I will do any upgrades after this.
    if so any suggestions at this point? Other than h-nuts anything i can do to make a tighter seal? I think the push test is around 3 seconds defiantly better than it was. other than that one radiator all of the other original seals are fine.
    I will take pics when I do the crossover
    pitdogg2 Posts: 27,077
    Please explain the put a new surround on it. Where did you get it and how'd ya do it?
    F1nut Posts: 51,804
    To the best of my knowledge there is no appropriate replacement surround available for Polk MWxxxx drivers. You'd be better off finding a used driver in good condition, IMO.
  • windstriker
    edited June 2019
    So far i havnt found a mw6511 on ebay. The surround i found is a exact match for the original and the website specificaly mentions it as a mw6511 surround replacement. It seems to be doing a good job. The only diffrence i can tell is it doesnt have polk stamped on it. O and the replacement dustcap is a little see through.
    Here is the link let me know what yall think.
    https://www.midwestspeakerrepair.com/shop/speaker-repair-kits/refoam-kits-by-brand/polk-audio-1-specialty-refoam-kits/polk-audio-6-5-inch-rubber-surround-kit-r6-1/
    I will take and post a pic of the repaired woofer when i get home.
    How did you get the old one off?
    F1nut Posts: 51,804
    Well, I'll be.....
    Looks like Midwest sees that there is money to be made on vintage Polk speakers. Good for them.
  • ddog
    ddog Posts: 230
  • Gerres26
    Gerres26 Posts: 874
    Thats a pretty big find as there are many of us with spare drivers that have a torn surround just sitting around collecting dust.
  • VSAT88
    VSAT88 Posts: 1,298
    What he said ^^^^^^^ ??
  • windstriker
    For those interested. Here is a pic of the repaired woofer(left one) and yes i need to replace those silver screws. Any ideas on where i can find some black ones?
    Removal of the old one involved a exacto knife and being very carful while cutting it off. Used goof off on the basket to get residue off.
    O one question. Any recomendations on speaker spikes. Preferably under 100 dollars for 8 but willing to consider over 100 dollar recomendations. Thanks
    F1nut Posts: 51,804
    Inexpensive and still decent, Dayton spikes. I like to use Loctite on the threads of the small tip piece.
    txcoastal1 Posts: 13,513
    Those came out great. Use black cap screws to replace the silver screws
    So is the glue like rubber/contact cement placed on both parts? I've done many foam drivers and would be open to this learning curve.
  • windstriker
    Ya I think the provided glue is similar to the foam ones if not the same. If i rember correctly you glue the surround to the woofer cone first wait a few hours then glue the surround to the basket. Honestly the process is very similar to the foam ones. Though when i redid my foamed my advents i didnt take off the dust cap or use shims.
  • verb
    verb Posts: 10,176
    Nice job! :smile:
  • verb
    verb Posts: 10,176
    Interesting. I have some spare PR's where the surround has small local areas of delamination.
  • codycatalist
    codycatalist Posts: 2,662
    Man I have like 3 or 4 MWs with bad surrounds. This is awesome.
  • windstriker
    So I have another update to my speakers I just downgraded them.
    Right after I originally purchased my sda 2bs from the original owner I upgraded the tweeters from the sl2000 to the RDO 194. I never listened to the 2000s long enough to get a feel for them. Well I just had to reinstall the 2000s because I blew one of my RDO 194s. Yikes I didn't realize how much better the RDO 194s are. After listening to a few songs with the sl2000 tweeters my ears are fatigued which I have never experienced with the RDO 194. They definently don't sound as smooth as the RDO 194. Ya i dont think im going to be able to live with the sl2000s for long.
    O well, I was already planing to upgrade to the 198s when i redid the crossover. I just may be doing that upgrade sooner than i expected 😃
  • ADJ
    ADJ Posts: 46
    Do the upgrade. You won't regret it.
