Test center speaker?
HowellDon
HowellDon Posts: 4
edited December 2004 in Troubleshooting
I have an RM6600 system with an RM2600 center speaker. My receiver is a Onkyo TX-SR702. The speakers seem to work fine in stereo mode but not in Dolby digital. The volume is weak and tinny. I suspect the center speaker since I have tested the satellites and the PSW350 sub and they sound reasonable. Any suggestions.
Post edited by HowellDon on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Pull one of the rear sat's, drop it in as center, how's it sound?
    Got everything calibrated and configured?
    Cheers,
    Russ
  • hoosier21
    hoosier21 Posts: 4,408
    try hooking up the center speaker to the left or right speaker wire, same results = bad center speaker
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • HowellDon
    HowellDon Posts: 4
    OK, Now you have me confused. The center speaker is actually a multichannel box with three speakers. The Sat's are not interchangable with the center are they? At least when I move my Sat plugs to the center output the sound is terrible from which ever Sat I use in the center output. But they perform correctly when used in the front or back positions.
  • ntculenuff
    ntculenuff Posts: 1,146
    center out put going out possibly.. try hooking up the center speaker to a different speaker output as suggested above to see if the center speaker still sounds funny if it does bad speaker if it doesnt could be bad center speaker out
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • HowellDon
    HowellDon Posts: 4
    I have switched various speakers around to various outputs but the tests have been inconclusive. I replaced the original Onkyo TX-DS 787 receiver with the new SR 702 thinking it was an output problem but the Dolby problem was still there. Now I have two expensive receivers.
    I checked the continuity on the three speakers in the center housing and one of the (2)Bass-mid range speakers has an open circuit and one is ok. I figure the Tweeter was all that was working causing the weak tinny sound. So I am sure the center speaker is part of the problem.
    Any suggestions on which Polk Center speaker will match my RM2300 Satellites? I Think the RM2700 system with the RM2650 center will but I can't find it individually? Or where can I get parts for the RM2600 like the one 3.25" Bass mid Drive?
    Actually, it appears the warrenty is good for another year so I will check on that first.
  • Willow
    Willow Posts: 10,888
    is your centre wired properly pos to pos and neg to neg
  • HowellDon
    HowellDon Posts: 4
    Yes!
    There is an open circuit in the center speaker with one of the 3.25" speakers and they are in a series so the 1.75" tweeter is all that is working.
