Test center speaker?
HowellDon
I have an RM6600 system with an RM2600 center speaker. My receiver is a Onkyo TX-SR702. The speakers seem to work fine in stereo mode but not in Dolby digital. The volume is weak and tinny. I suspect the center speaker since I have tested the satellites and the PSW350 sub and they sound reasonable. Any suggestions.
Post edited by HowellDon on
Pull one of the rear sat's, drop it in as center, how's it sound?
Got everything calibrated and configured?
Cheers,
try hooking up the center speaker to the left or right speaker wire, same results = bad center speakerDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
OK, Now you have me confused. The center speaker is actually a multichannel box with three speakers. The Sat's are not interchangable with the center are they? At least when I move my Sat plugs to the center output the sound is terrible from which ever Sat I use in the center output. But they perform correctly when used in the front or back positions.
center out put going out possibly.. try hooking up the center speaker to a different speaker output as suggested above to see if the center speaker still sounds funny if it does bad speaker if it doesnt could be bad center speaker outSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
I have switched various speakers around to various outputs but the tests have been inconclusive. I replaced the original Onkyo TX-DS 787 receiver with the new SR 702 thinking it was an output problem but the Dolby problem was still there. Now I have two expensive receivers.
I checked the continuity on the three speakers in the center housing and one of the (2)Bass-mid range speakers has an open circuit and one is ok. I figure the Tweeter was all that was working causing the weak tinny sound. So I am sure the center speaker is part of the problem.
Any suggestions on which Polk Center speaker will match my RM2300 Satellites? I Think the RM2700 system with the RM2650 center will but I can't find it individually? Or where can I get parts for the RM2600 like the one 3.25" Bass mid Drive?
Actually, it appears the warrenty is good for another year so I will check on that first. -
is your centre wired properly pos to pos and neg to neg
Yes!
There is an open circuit in the center speaker with one of the 3.25" speakers and they are in a series so the 1.75" tweeter is all that is working.
