Receiver Upgrade
Need opinions on this one- I currently have a DENON AVRX2100W (couple years old) and am looking to upgrade. I'm VERY interested in the brand new AVRX4500H, which lists at $1599, but I also see the AVRX4400H (lasts years model?) which lists at $899. Is the 4500 worth the extra $700?! Also, is either receiver going to be a NOTICEABLE improvement sonically over my 2100?
  • mrloren
    mrloren Posts: 2,474
    I'd say save the $700 and get the 4400H. I have that same AVR and love it. Music rocks as good as my SR5010 did and movies are great.
    Yes you will notice a difference over your 2100. The 44XX has a lot more power and better sound boards.
    billbillw Posts: 7,838
    Personally, I'd keep saving for when that receiver dies. Then get one. Otherwise, not worth upgrading unless there is a feature you HAVE to have in the newer version.
    I've had a lot of receivers through the years. If primarily watching movies/TV, then the difference is not huge. There may be a 'noticeable' difference, but there may be other areas where $800 could have a bigger improvement (ie: if your subwoofer is not already a top performer)
  • Mikey081057
    Mikey081057 Posts: 7,127
    Save for separates.... Get some nice amps and when the separate pre becomes out dated you just replace the pre... Way better SQ than an AVR.
    Garage | Polk Monitor 5B's
  • excellent point. Maybe back to square one...
  • mantis
    mantis Posts: 17,568
    Are you trying to go 4k?
    Dan
  • already there. Sony Bravia 55". What are youre thoughts?
  • rooftop59
    rooftop59 Posts: 8,120
    I would get this: https://www.accessories4less.com/make-a-store/item/marsr5012/marantz-sr5012-7.2-ch-x-100-watts-networking-a/v-receiver-w/heos/1.html
    And then spend the rest of your budget on a really good two channel amp that will long outlast the receiver. Or, if your speakers are really easy to drive, spend the extra on a sub upgrade.
    Game Room 5.1.4:
    Bedroom 2.1
  • mrloren
    You need a good foundation to start on. The Marantz is a very nice AVR. Only problem with the SR50XX is the Audyssey XT, it does not come with XT32. basic XT takes a little to dial in. I went from an SR5010 to a 4400H much nicer over all AVR. If you go Marantz go SR60XX which comes with XT32.
    A good sub is a must, HSU and SVS make some of the best bang for the buck subs on the market.
    Adding a power amp is a nice upgrade when you can. Signatures are an easy speaker to drive, I added an amp and it was a hello moment when I powered it on.
    What speakers are you using?
    What is your end goal? This hobby can get a little costly.
  • ken brydson
    ken brydson Posts: 9,031
    mrloren wrote: »
    Ya think?
  • delkal
    delkal Posts: 764
    Keep your surround sound rig as is and start saving up for a dedicated stereo.
    Then you will know about an expensive hobby................
  • dromunds
    dromunds Posts: 10,145
    Heck, my buddy just spent over five grand on a bicycle
  • halo
    halo Posts: 5,618
    ANY hobby CAN be expensive. Additionally, expensive is subjective/relative to the individual.
    Cheers!
    dromunds wrote: »
    Do you have an address ? Have some bolt cutters not doing anything at the moment. 5G's on a bike ? You know the kind of espresso maker I can buy for that coin. :)
