SDA1b (or early c) - opinions?
JayMX
JayMX Posts: 435
edited October 2018 in Vintage Speakers
Picking these up tomorrow for a song. No interconnect, but can build one. Opinions? Suggestions? Thoughts? Where do these fall on the ol Polk desirability scale?
Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (3x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • JayMX
    JayMX Posts: 435
    What are the differences between the 1B’s & early 1C’s other than driver loading?
  • mlistens03
    mlistens03 Posts: 2,767
    Looks like the SDA 1C uses the MW6511 for stereo drivers and 6510 for dimensional, 1B seems to use MW6509 for both. I’d guess one is easier to driver, or something.
    Value wise? No clue.
  • westmassguy
    westmassguy Posts: 6,850
    Completely different generations. The 1B is 3rd, 1C is 4th. 1C is more desirable, and relatively easier to drive. 1B is 4 ohm, 1C 6 ohm nominal.
    Some early 1Cs used leftover circuit boards from the 1Bs.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • mlistens03
    JayMX wrote: »
    🤦🏻‍♂️Missed that, sorry.
  • JayMX
    JayMX Posts: 435
    edited October 2018
    Completely different generations. The 1B is 3rd, 1C is 4th. 1C is more desirable,....
    So they may be C’s even if they are blade/blade... if are loaded with 6510’s & 11’s they should be usable with isolation transformer/mono blocks? Correct?
  • Dennis Gardner
    Dennis Gardner Posts: 4,860
    edited October 2018
    Those serial numbers indicate that they can't be used with monoblocks.
    https://us.v-cdn.net/5021930/uploads/attachments/6/4/8/2/8/9806.jpg
  • Malbec
    Malbec Posts: 548
    These don't appear to be compatible with the isolation transformer.
    NOTE: Some early units of SDA-1C and all units of SDA-2B require plug adapters and some internal modifications to the crossover to be used with the Non-Common Ground Amplifier Interface. The affected SDA-1C units can be identified by serial number as follows:
    Right Channel #6001 through 6310 and #6501 through 6678 Left Channel #5975 through 6370 and #6532 through 6656
    If the serial numbers of your speakers fall within these limits, please contact Polk Audio for modification details.
  • JayMX
    JayMX Posts: 435
    perfect. This helps me with determining what to offer the guy selling. The cabinets look rough, hoping to get them for less than a Benjamin! We will see what this afternoon holds. Thanks all.
  • JayMX
    JayMX Posts: 435
    @la2vegas - if I actually sang, he would prob kick me out. He mentioned a hundo, ima see if I can talk him down a bit. Wish me luck!
  • JayMX
    JayMX Posts: 435
    edited October 2018
    Definitely B’s loaded with 6509’s. Pretty thrashed. Two bad tweets, three locked up mids. Cracked cabinet. Rough vinyl veneer. And free cobwebs! All for $80!! I will bring them back from the brink of death though. This I swear. 🤘🏻
    xschop Posts: 4,705
    Halloween specials right there. Can't wait to see the resto-mod.
  • verb
    verb Posts: 10,176
    Nice find @JayMX ! Nothing that can’t be fixed! Just needs some love. Be sure to document your journey!
  • honestaquarian
    The very first SDA’s I ever owned were a pair of 1b’s that looked just like these. They forced me to buy a new Receiver as the impedance dips pretty low on these. I had a Realistic receiver (remember THOSE???) when I got these and it would play just fine until I turned up the volume. Then you would hear a loud *clack* come from the receiver and the sound would cut out (meaning the protection circuit would disconnect the amp from the signal path) Once I turned the volume down the sound would come back. I replaced it with an NAD receiver and was very happy (at least until a friend who liked to brag about his Luxman receiver accepted my challenge to bring it over and I discovered it sounded way better than my NAD! :s )
  • Schurkey
    Schurkey Posts: 2,100
    edited October 2018
    Malbec wrote: »
    The early 1Cs are ABSOLUTELY compatible with an isolation transformer IF you are willing to add ~eight inches of wire and change the socket that the interconnect cable attaches to.
    In fact, if you're making your own interconnect cable to go with your Dreadnought, you just tie the ground side of the transformer to the negative binding post and you don't need the eight inches of wire inside the cabinet.
    Seems the "hot tip" is to remove the OEM socket for the interconnect cable, and replace it with a Speakon-style connector, so again you'd need a little wire added inside the cabinet.
    Many ways to skin this cat--IF these are early 1Cs. If they're 1Bs, you're pretty well screwed in terms of an isolation transformer.
    http://forum.polkaudio.com/discussion/131691/2b-and-early-1c-ai-1-modifications#latest
    Given the very-low serial numbers, I expect these are 1Bs, but a look at the midwoofer model numbers will confirm.
    I've had 1Bs since about 1986, bought them as "store demo" when the 1B was being replaced with the 1C. They're terrific-sounding speakers, even moreso when the crossovers are gone through, and you pull all the Dacron back up where it belongs, add the updated tweeters, etc.
    F1nut Posts: 49,805
    Ummmm......."Definitely B’s loaded with 6509’s."
  • Schurkey
    Mia Culpa.
  • JayMX
    JayMX Posts: 435
    So I’ve finally got these to a point where they’re somewhat decent to look at. And they work for the most part. I went through all eight of the MW6509's, six of which were locked up. I aligned and glued all of them. When I finally reassembled I found that I didn’t do a good job on one of them. How hard is it to break the bond on loctite red and powergrab?
  • JayMX
    JayMX Posts: 435
    I fixed up the cabinets and veneered them. Think they turned out ok...
    one PRis leaky. Glued it with shoe goo. Anybody got any spares? 😂
  • FestYboy
    FestYboy Posts: 3,861
    The power grab will be the worst of it. Just break loose the pole plate and align from there with your PVC rig.
    audioluvr Posts: 5,438
    Nice job! They look great!
  • Schurkey
    JayMX wrote: »
    No shiit! They're beautiful!
    JayMX wrote: »
    You won't have any fun breaking them apart again. I don't expect the powergrab to be a big deal, but the anaerobic Loctite will be...interesting. Theoretically, you'd need heat to soften the adhesive, but doing that puts the rest of the driver in danger. I would heat only the pole piece and see what happens.
    Leave the magnet attached to the basket. Then clean up the pole piece and the facing part of the magnet. Center the pole piece in the voice coil, instead of trying to center the pole piece AND the magnet.
  • monepolk
    monepolk Posts: 1,141
    Great job! They look fantastic.
    txcoastal1 Posts: 13,132
    Like breathing life into Frankenstein
    Great work
  • JayMX
    JayMX Posts: 435
    I forgot I had this photo. This little one was building the webs...
    AAAa cute! Momma must be near by though... :#:#
  • verb
    verb Posts: 10,176
    Fabulous job! Especially considering the condition when you started! Looking good! :smile:
  • gmcman
    gmcman Posts: 1,759
    Excellent work! They look great.
    Coincidentally, my evening started...sorta similarly.
    I have 8 extra 6510's I plan to glue up, started with these 6. One driver in perfect condition, when I finished I snagged it with my nitrile glove and pulled it off the table. I juggled it for a split second and it hit the floor....magnet shifted and completely frozen now.
    I'm pretty sure my 10yo heard a new word from the other room... :*
    I'm also going to start re-aligning a few original drivers from my 2B's and some spares..now I have an extra to practice on.
  • Faustin
    Faustin Posts: 1,149
    Very nice work. Not very many people would have taken on that project.
  • Mike Reeter
    Mike Reeter Posts: 4,314
    Nice work on those cabinets Jay, quite a transformation!
    xschop Posts: 4,705
    Those went from fugly to eye candy. Nice skills.
