How can you listen to anything under 200 watt per chnl?
2
Answers
  • mlistens03
    mlistens03 Posts: 2,767
    They are capable of 400 watts of power pumping into them... That does not mean that they need 400 watts to operate.
    My Missions, which are rated for 150 watts RMS, are powered by my Lafayette receiver. (22 watts per channel.) No issues and it sounds better on that than anything else I've tried them on.
    pitdogg2 Posts: 23,350
    If one has loudspeakers with triple digit sensitivity (i.e., > 100 dB SPL per watt at 1 meter), it might be easy. Depends on the nature of the loudspeaker load, though (to wit, mostly the impedance curve).
    3.5 watts per channel at my house using loudspeakers with ca. 100 dB per watt @ 1 meter sensitivity. No complaints.
    27138816799_f36a6e03d9_h.jpgDSC_9976 (3) by Mark Hardy, on Flickr
    Most consumer & "audiophile" loudspeakers today tend to have low sensitivities. For example 20 dB lower sensitivity would mean that one hundred times as much power is required to drive a loudspeaker to the same SPL output. Realistically, many loudspeakers today are. ca. 85 dB sensitivity; 3.5 watts into 100 dB speakers, in terms of sheer SPL, would equate to about 111 watts into 85 dB speakers.
    Just a quick? If 102db sensitive speakers only need say 3 to 10 watts then why do they ask for 400rms each.. Or is the tube amps diff
    OH Jeesh "face meet palm"
    You have a A LOT of audio learning to do.
    F1nut Posts: 48,961
    What is the correct assumption then? I did try and simplify the numbers some to make my description clear but it is a close approximation. How far off am I?
    There are too many variables involved to assume 0 is equal to a certain wattage. A more accurate method would use an SPL meter at one meter to determine where it is on the AVR volume scale that equals a certain wattage.
    I am glad you think you can hear a 0.5 DB increase but I will call BS. Especially if this is listening to music and not a pure test tone. Plus or minus 3 DB's is generally regarded as the level which MOST people can hear a change with a test tone. I know some peoples hearing is better and I am sure there are some 18 year olds that might be able to hear a 1 DB change (with a test tone). But you are not 18 anymore.
    Everyone can try this for themselves. Close your eyes and start listening to music. Then have someone else turn the volume up and down 1 DB. You won't notice any change. Experiment how far they have to go till you can reliably hear a difference and report back.
    I don't think, I know because I have done it time and time again. Furthermore, you seem to be confusing the ability to hear age related higher frequencies with the ability to hear changes in volume levels, which is most definitely not age related.
    The power ratio between an 80 and a 100 watt amp is 1.25x. Coincidentally a 1.26 increase in power gets you 1 DB more sound. So I guess your ears are so sensitive you can not only hear the difference but you also consider it a louder amp?
    The reality could easily be that the 80wpc amp is louder than the 100wpc amp due to the amount of gain.
    heiney9 Posts: 24,869
    edited October 2018
    Count me in as being able to hear .5 db increases. My Mcintosh C100's volume control is calibrated in .5 db steps and a .5db change up or down is quite noticeable even to these 62 year old ears. 3db would be 6 steps on the volume control and that is a huge change in the sound. I'm betting there's not a single member here that can't easily hear either of those changes.
    Impossible for the .5dB attenuation steps on the volume control to actually relate to a "real" increase/decrease of .5dB. That .5dB has to be measured from a single point in the room and depending on how the amp interacts with said pre-amp and the efficiency of the set of speakers, there is no way to pre-determine a .5dB attenuation with a linear "knob". It's simply a numerical reference, nothing more. It has zero to do with an actual increase/decrease of .5dB.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Aleph 30 | EE Avant Pre | EE Mini Max Plus DAC | MIT Shotgun S3 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
    F1nut Posts: 48,961
    I would argue that the .5dB step is a lot closer to a .5dB increase/decrease in volume than it is to a 3dB increase/decrease.
    edited October 2018
    Example, put your ear to the speaker and move the vol one step, you will clearly hear an increase.
    Stand back from the speakers 10 feet, have someone move the vol one step, bet you don't hear it. So even though the vol read out says .5dB it has no relevance since too many other variables are in play. Variables like source material, speaker efficiency, room characteristics, cable interaction, amp/pre-amp/source interaction, etc, etc.
    All those dB readouts do is take a non-linear function and approximate it to a linear readout for consistency.
    Point being that the read-out still states .5dB, yet in both scenario's you get a different result.
    edited October 2018
    Perhaps, but without a reference, it means nothing really. It's a way of assigning a linear number to a non-linear function. There will be a certain set of circumstances it will be correct, unless you define that point, it's just an approximation. And you see, now people think they can hear a .5dB change in sound because of it. When in reality that's almost impossible to do unless you are very close to the speakers. I know I don't listen with my ears up to the speakers.
    Volume controls are the number one source of distortion and other non-linearity's.
    mhardy6647 Posts: 32,042
    Those old Altecs would emit fairly large puffs of smoke if fed 400 watts... but then again 25 watts continuous could probably be used to loosen plaster.
    edited October 2018
    heiney9 wrote: »
    Thus do some of us use inductive volume controls (autoformer (or transformer) as opposed to resistive attenuators.
    http://www.intactaudio.com/atten.html
    edited October 2018
    On topic -- no doubt some folks can hear 1 dB or less differences.
    I can in the context of a deliberate, controlled change, but AFAIK I cannot hear, e.g., a 1 dB (or less) difference in RIAA EQ curves between two phono preamps.
    Folks who can hear 0.5 dB differences, I think, have to spend way more than I do on hifis. :)
    By the way, while I absolutely do not disagree with the importance of the reference point for dB measurements, an increment of a decibel (deci Bel = 0.1 Bel, named after Alexander Graham Bell, the telephone guy) is meaningful in the contexts of, e.g., AC voltages, independent of references. The issues of nonlinearity and inaccuracy are a different matter. We use logarithmic units (Bels... or decibels) as a practical convenience to compress the phenomenal dynamic range covered by our own auditory processing systems.
    120 dB = 12 orders of magnitude dynamic range from the threshold of sound to the limit of pain/auditory system saturation.
    Nature is pretty amazing stuff (which is why I am a biologist, of course!).
  • gmcman
    gmcman Posts: 1,710
    If I'm not mistaken, .5 db is roughly 16% louder, 1db is roughly 33% louder.. that's somewhat of a large percentage even though its expressed in a small decimal.
    VR3 Posts: 27,361
    Stopped looking at wattage ratings years ago and stuck to current ratings for general guidance
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    What? Pugs can't raise their paws that high? :smile:
  • kharp1
    kharp1 Posts: 3,453
    OK look, if you guys are going to throw a bunch of facts and numbers out there to try and confuse the situation then I'm just going to leave!
    kharp1 wrote: »
    No you're not...
  • delkal
    delkal Posts: 764
    edited October 2018
    The range of our hearing is unbelievably amazing and hard to comprehend. It is even harder to the comprehend the log DB scale and how much power it takes for an amp to imitate that sound. So getting back on track and to put things in perspective.
    Assume you have a 90 db efficiency speaker..............
    To listen at 80 DBs you will need 0.1 watt amp power
    To listen at 90 DBs you will need 1 watt amp power (this is the definition of efficiency)
    To listen at 100 DBs you will need 10 watt amp power
    To listen at 110 DBs you will need 100 watt amp power
    To listen at 120 DBs you will need 1000 watt amp power
    To keep things civil here I will concede some people can hear a 1-3dB change if the test is done right. But if you are listening to music and your friend says "Turn it up just a little" you will undoubtedly turn it up more than 3DBs (If you turn it up just 1 DB they will likely give you a funny look).
    My point is a 3 DB difference a very subtle barely relevant change while listening but just doing that doubles the power you need. So if you feel your 100 watt amp is not "loud" enough going to a 200 watt amp will just add 3DBs (Just a little) to your max volume.
    A 200 watt amp is not twice as loud as a 100 watt one. In fact it is barely audible. And who ever listens to their system turned up all of the way?
    Still stereo companies love to hype their power ratings.
  • FTGV
    FTGV Posts: 3,648
    heiney9 wrote: »
    You can get that sort of precision from digitally controlled and stepped attenuators.
    heiney9 wrote: »
    Variable pots can be wretched little devices but in a system context speaker drivers and gain devices (ie.tubes,transistors) contribute substantially more in the way of distortion.
  • F1nut wrote: »
    Are you one of the admins on Audiokarma? I got permanently banned from there can you get me back lol
  • kharp1
    kharp1 Posts: 3,453
    kharp1 wrote: »
    No you're not...
    You're right...I'm going to go pout in the corner like a little beotch!
    Viking64 Posts: 6,217
    FestYboy wrote: »
    ...wonder why
    I keep reading their username as "7thgrader". I also wonder why. :p
    edited October 2018
    stumbled across this ol' sticky @ AK (looking for something else):
    http://audiokarma.org/forums/index.php?threads/amplifier-sensitivity-decibels-and-you.58829/
    gmcman wrote: »
    and 10 dB = twice as loud; 20 dB = four times as loud... but even those comparisons are difficult to "hear" in a real world setting.
    The figures of merit in terms of amplifiers, I would say, are these (which we've all talked around in previous posts).
    10 dB more output takes 10 times as much power (one order of magnitude)
    20 dB more output takes 100 times as much power (two orders of magnitude)
    etc.
    Just think of the decibel as what it is, a tenth of an exponential quantity of 'intensity' called the Bel :) Drop the zero and it's like high school math.
    10^1 = 10 (10 dB)
    10^2 = 100 (20 dB)
    10^3 = 1000 (30 dB)
    1/10 = -10 dB
    1/100 = -20 dB
    1/1000 = -30 dB
    etc.
    tonyb Posts: 32,840
    kharp1 wrote: »
    We have special skills, and if you leave, we will find you....and steal all your audio gear. :)
    heh, we could start talking about phase angles and power factors...
    tonyb Posts: 32,840
    Doc, relax, have some more coffee pal. Too early to start using my brain. It has set hours of operation ya know. :)
  • jeremymarcinko
    jeremymarcinko Posts: 3,776
    edited October 2018
    Isn’t a loudspeaker’s efficiency measured at a given frequency 1khz @1w and 1 meter?
    Wouldn’t much more power be used to produce another more demanding frequency at the same level and further away?
    Post edited by jeremymarcinko on
    tonyb Posts: 32,840
    Isn’t a loudspeaker’s efficiency measured at a given frequency 1khz @1w and 1 meter.
    Yes to both. Simply put, it's just a unit of measure much like ounces of liquid in a measuring cup.
    edited October 2018
    It varies, and the test standards are, IME, seldom specified.
    To be meainingful, it should be based on a broadband signal (e.g., pink noise) -- but then the acoustic environment can have a big impact, too.
    I usually just use a Radio Shack SPL meter & a tape measure ;) ... or believe the published spec. When we're dealing with (vintage) JBL & Altec, the specs are generally pretty reliable -- and the conditions are usually spelled out pretty clearly (e.g., power handling).
    In an anechoic space, SPL decreases by 3 dB per doubling of distance.
    A stereo pair of loudspeakers increases SPL by 3 dB relative to a single loudspeaker.
    Here's a good (reproducible) set of specs for a good (one of the best ones ever) woofer, e.g.,
    Look at the sensitivity spec:
    and the definition thereof:
    Freefield at 4 feet (a teeny-weeny bit more than 1 meter ;)) with pink noise (bandwidth limited -- heck, it is a woofer).
