Vintage Monitor and SDA Speaker Deals
1153154156158159261
  • krazypolk
    Is this a rare item? I've never seen one before.
  • FestYboy
    FestYboy Posts: 3,861
    krazypolk wrote: »
    No, at least not around here. Craigslist is littered with them, and so is eBay.
  • mlistens03
    mlistens03 Posts: 2,767
    krazypolk wrote: »
    Also ran across this item, anyone have any insight?
    Heard of these before, I think you could use them with Monitor speakers. Sub you would wire in series (? maybe it was parallel, I'm not sure...) with your speakers.
  • FestYboy
    krazypolk wrote: »
    Curb alert, although I doubt that these are still available. https://fortmyers.craigslist.org/lee/ele/d/curb-alert-free-vintage/6699482779.htmlijp7jupzn78d.jpg
    Wow... I hope they didn't get trashed, that's literally a steal.
  • krazypolk
    FestYboy wrote: »
    krazypolk wrote: »
    I guess that explains the 30 dollar price tag. So much for trying to make a quick flip.
  • sbb2112
    sbb2112 Posts: 134
    sbb2112 wrote: »
    Sweet. Didn’t see these but they were in my neighborhood. Nice find
    Last one there lost....
    Was really just starting to look for some 1.2s and part with a set. Haven’t decided which to keep yet
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • krazypolk
    sbb2112 wrote: »
    sbb2112 wrote: »
    Would you care to elaborate?
  • kmeek
    kmeek Posts: 225
    @krazypolk, I'll take your Monitor 10's for 90 and beat them up a little and sell them for $5..... :D
    Check these out:
    Check out this Polkaudio speakers-Laveen- for $5 on OfferUp
    https://offerup.co/b0cEXEgMxQ
  • krazypolk
    kmeek wrote: »
    Check these out:
    Wow! Not surprisingly they're already sold.
  • kmeek
    kmeek Posts: 225
    edited September 2018
    Wow! They must of just flagged them sold minutes ago!! When I just checked they weren't flagged yet...... :o
  • krazypolk
    Google search brought these up. 7B and pretty sure they're peerless tweeters for 80 dollars.https://seattle.craigslist.org/see/ele/d/polk-audio-7b/6704471390.html4ktii5v0ksfh.jpg
  • krazypolk
    krazypolk Posts: 745
    Seattle seems to have some half way decent deals.https://seattle.craigslist.org/skc/ele/d/vintage-polk-sda-1c-speakers/6703372153.html23gajwn4tg8h.jpg
    160 dollars seems doable.
  • 250GTLusso
    I would proceed with caution on those SDA-1Cs in Seattle.
    After close examination of the serial numbers, it would appear that the Right Channel falls within the “interim” serial number range, while the Left Channel does not. This may create an issue if trying to use the AI-1 and a non-common ground amp, as the Right Channel will require some internal modifications.
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • sbb2112
    sbb2112 Posts: 134
    krazypolk wrote: »
    sbb2112 wrote: »
    sbb2112 wrote: »
    Want to work towards monoblocks. My SRS are blade/blade and not made for that but are great and modded to the hilt. My SRS 2's could fund part of a set of 1.2's and they are modded up too and sound great too but same blade/blade.
    Main System
    Oppo 203 Bluray
    Rythmik F15HP sub
    Mac Mini Server
    Office System
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
  • krazypolk
    sbb2112 wrote: »
    krazypolk wrote: »
    sbb2112 wrote: »
    sbb2112 wrote: »
    Thank you for sharing.
  • verb
    verb Posts: 10,176
    verb wrote: »
    Enabler! :smile: I did call the guy and asked for more pics to get an idea of what generation these babies are.
    Tony you and I are aligned - I offered him $1000 pending my inspection and he accepted. Tentatively I'll be heading out there on Sunday. They are on hold for me until then.
    Serial numbers are 3418, 3930 but I have found after searching a bit that the numbers are useless cause there is no database (public at least) that will tell which generation they are. I may pull a MW off while I'm there just to confirm, but if they are truly are minty I'll get em!
    He is the original owner, has not played them in quite some time, but cosmetically they are in excellent condition. We'll see!
    Now I just have to break the news to the Mrs that we're taking a road trip! :smile:
    Update - Working from home, ahem, the car tomorrow (easy for me as I do a lot of conference calls, video conferencing), so I'm doing a road trip! The Mrs gave me the ok, however I did not fully disclose the size of these speakers. "Just gonna pick up a pair of vintage speakers". One step at a time! :smile:
  • monepolk
    monepolk Posts: 1,154
    Hey I was able to sneak my 1.2s past my wife. Of course she wasn't home at the time. ;)
  • JayMX
    JayMX Posts: 461
    If anyone is looking for a CS350LS...
    https://classifieds.ksl.com/listing/53735942
    No affiliation, but if anyone wants it bad and wants to pay for shipping, I will try to acquire and facilitate...
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • FestYboy
    If you want the towers, I could go for another 350LS, not paying 150 for just the CC though, that would be crazy talk.
  • FestYboy
    Someone in Texas needs to jump on this:
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/163276846795
    Obviously, no affiliation...
    Tony M Posts: 11,925
    Dang that's a deal! ^^^^^^^^^^^ :o
  • CGTIII
    CGTIII Posts: 1,266
    SDA 1Cs claimed perfect asking $400. Real wood refinished in black. No affiliation.
    https://atlanta.craigslist.org/nat/ele/d/polk-audio-sda-1c/6711549741.html
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
  • krazypolk
    CGTIII wrote: »
    The seller mentioned that he repainted them. He obviously didn't do a very good job. Too bad, nice speakers otherwise.
  • verb
    verb Posts: 10,176
    Good deal, despite the fact it looks like he repainted the end caps with a brush! And a not so steady hand! :smile:
  • jonicont
    jonicont Posts: 283
    CGTIII wrote: »
    Now down to $300
    https://charlotte.craigslist.org/ele/d/polk-audio-sda-1c/6711568532.html
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • krazypolk
    jonicont wrote: »
    CGTIII wrote: »
    Now down to $300
    Well at least the price is moving in the right direction.
    175.00 ;)
