RIP Burt Reynolds
^^^ But that hood looked cool.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
One of my favorites was Sharkey's Machine.
Indeed it was. Car was so cool back then. Then 1980 rolled around and they took the guts out of that car with a wimpy turbo.
Umm whaaaa???? Ain't nuthin' wimpy about the turbo 3.8 there Tony, that engine is a beast.
I believe you're referring to the 1989 T/A. The 1980 was offered a 301 V8 turbo. Even if you wanted to crank up the boost, that engine had a puny crankshaft compared to the 400.
Indeed, that 301 turbo was a dog, barely kept up with the standard 305's in stock cameros . The TA's with the 455's was where it was at.HT SYSTEM-
lsi 9's -
Super duty 455 with the scoop that worked.
KennethSwauger wrote: »One of my favorites was Sharkey's Machine.
I'm going to watch this again tonight. Came out on Blu Ray a couple years ago. Definitely doesn't hurt that Rachel Ward is in it! And cool audio gear too. Perfect ending in this scene...
https://www.youtube.com/watch?v=D-24-SkG2Jw -
I agree..It made gobs of torque down low, but just wouldn't "run".
Granted it's forced induction, but the "flow" part of the equation needed more R&D. I think the secondaries alone flowed more than that small intake tube on the manifold.
I had forgotten that Gator McKlusky appeared in "White Lightning" (1973) three years before "Gator" (1976), Burt's directorial film debut.
He was also a semi-regular on Gunsmoke
KennethSwauger wrote: »He was also a semi-regular on Gunsmoke
Was he the character that had a limp or was that Dennis Weaver?
4.9 litre 301 cid turbo! A friend had one. The 301 was not a great engine imho. I had one in a '77 Grand Prix and it was very anemic.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
The 3.8L SFI Turbo Buick V6 is a beast (I owned a 1987 Turbo Regal with the T-package - blackout package ((amongst other options)). The 4.9L Turbo Pontiac V8 was a t-u-r-dHT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
The 455's ended in '74 or '75 IIRC. None available by '77. EPA regulations & catalytic converters killed the muscle car until the Buick Turbo Regals with the fuel injected, intercooled, 3.8 V6's started to stomp the guts out of the V8's of the day. The '87 GNX was the fastest production car made in America (1/4 mile).HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
Dennis Weaver -
The only other GM turbo enines I was aware of we're the Olds 3.5L (265ci) Rocket Fire, the 164ci Corvair flat 6 and the 4.3L from the Typhoon/Cyclone (besides the 3.8 of course) all of which had some serious GO available. The Corvair engine had to be dramatically detuned in order for the trans to survive. Now I've learned something.
Dennis Weaver
Quint Asper
Loved that show
https://youtu.be/9X67RmNdwpQ Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
You forgot one... the 215cid Oldsmobile Jetfire from 1962.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »The only other GM turbo enines I was aware of we're the Olds 3.5L (265ci) Rocket Fire, the 164ci Corvair flat 6 and the 4.3L from the Typhoon/Cyclone (besides the 3.8 of course) all of which had some serious GO available. The Corvair engine had to be dramatically detuned in order for the trans to survive. Now I've learned something.
No, not forgotten, misspoken... The Rocket Fire at 3.5L that I mentioned is the 215ci Jetfire that you speak of. I'm a derp. 215ci is 3.5L and it's the father of the Land Rover v8, aluminum block and all (minus the turbo). -
Wrong motor... the one you speak of was a Buick design, and was pretty much given away to British Leyland. Range Rover inherited the design a couple years later. The Jetfire was all Oldsmobile, and was retired in 1963 due mostly to customers not grasping how to care for their cars and other tech issues the division didn’t feel like trying to solve.
According to wiki, the blocks are the same, but I was unaware that Buick and Olds developed them separately. New little tidbit to store away.
Nice little rabbit trail this thread took... I feel somewhat responsible.
I have dozens of books on automotive history... don’t need wiki for nothing. Another littlle tidbit about that engine family is that Olds wanted to use it for the Toronado, back when it was a car the size of the original 442, and they were going to use the Corvair transaxle to make it work. The transaxle could not handle the torque, and the engine could not handle much of anything else, so the descision was made to use the big-block family, as Olds did not have a small block up for the task, and GM started to trim fat by forcing the divisions to share bodies, even on their “Halo” cars. Toronado and Riviera shared their shells in 1966, though the Riviera stayed RWD, and the Eldorado jumped on the FWD bandwagon in 1967...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Dennis Weaver
Mick Jagger was wandering around the Playboy mansion and he walked into a room to find Hef and Dennis Weaver in a compromising position. Mick says: "Hey! Hugh! Get off of McCloud!" -
That one isn’t even worthy of an eye roll...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Guess what I am going to do today?
Promise to stop posting those stupid Pug pictures?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
AMC theaters will be showing Smokey and the Bandit from September 12-20 at or below $5 per person. https://www.google.com/amp/s/deadline.com/2018/09/smokey-and-the-bandit-returns-to-amc-theatres-as-a-burt-reynolds-homage-1202459939/amp
I will,be there for sure...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I'm watching it right now.AMC theaters will be showing Smokey and the Bandit from September 12-20 at or below $5 per person.
I didn't know he was in a movie named "Heat". Odd that 4 years later they made another movie named "Heat", which is one of my favorite films...with Pacino and DeNiro...the whole film had an amazing cast.
Looks like I have some catching up to do.
