My first real speakers
cyrial
Hello everyone,
I've just picked up a pair of monitors from Craigslist for the sweet irresistible price of 25 dollars. Can you help me identify them? It seems the tweeters are SL2500, based on the label on the back.
I'd also appreciate any advice you could give in regards to refurbishing and repairing them. One of them only operates from the tweeter, though there is some vibration in the other two speakers. Probably due to a bad capacitor.
Thanks!
Thanks!
I think those are Monitor 5’s.
The magnet in the speaker that doesn’t play has probably slipped (google, and you’ll find that it’s a very common issue), so the first thing I would do I say pull the other driver and put glue (don’t remember which kind is recommended by most here) around the magnets so it doesn’t slip. Then, go and gently push on both sides of the cone with your thumb, and see if it moves easily. If it doesn’t immediately move, then don’t force it, and hopefully someone else will chime in on how to fix it.
Also, the big driver on the bottom is a passive radiator, in case you didn’t already know. The only active drivers in these speakers are the tweeter and midwoofer, the bottom only is pushed by the air of the midwoofer. -
Almost forgot to mention, welcome to Club Polk!!
Monitor 5 Series 2.
The mid-driver's magnet has slipped. Tough to repair. You should be able to find a replacement on eBay.Political Correctness'.........defined
President of Club Polk -
I can do the same if @lawdogg is unable, and for the same deal.
I haven't made this public knowledge only due to the fact that I only obtained my weekends last Sunday. But I officially have some free time to help the community now. -
Your first pic is the passive radiator.Don't take experimental gene therapies from known eugenicists.
Thanks for the welcome everyone! The non-operational driver cone is wobbly and loose. So this is due to a slipped magnet? Can anyone help me understand more? I'd like to attempt the repair myself, if that's feasible.
Very nice gesture sir!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Should the cone be firmly connected to the voice coil? I suspect there is something more wrong here. The dust cap is effectively destroyed, so I just pulled off the crumbling bits.
Sorry for the double post, somehow I don't have editing permissions on my last post.
As you can see, the voice coil has totally burned away from the spider and the cone. The dust cap just crumbled away when I touched it. Is this repairable, or should I just search for a replacement driver?
A replacement will be your best bet IMHO...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Woah, never seen anything like that for a Polk driver.
Find a used replacement on eBay or something, and maybe try to fix that one as a spare?
Did you use a multimeter to test the resistance? -
I've got 0.3 ohms across the terminals. How on earth would I even go about repairing this? The cone might be usable but the spider seems fubar. Are replacement parts available?
If it’s reads 0.3 ohms, you’re toast. The driver is garbage, although don’t toss it in case a magnet slips on another speaker, and during repair it is dropped and it cracks or something. Or maybe I’m preparing you for something that’ll never happen.
Once you get these working, you will quickly find yourself sucked into the rabbit hole, destined for the rest of your life to be hunting for deals on Craigslist and at garage sales, and endlessly tweaking and testing and tweaking again.
I fear I'm already down the rabbit hole, and this is merely the latest branch of the tunnel
With that much damage to a driver I would check everything electronic very carefully. Including replacing the caps and resistors, almost looks like that burned driver was hit with Direct Current.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Driver is toast. MW6502s are plentiful on fleabay. Just make sure the seller wraps it properly to prevent damage during shippingHome Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks for the model number @westmassguy
Bummer! Yes used drivers are plentiful. In fact, I have a re-centered and epoxied 6502 right here that you're welcome to if you can cover shipping. Even the dust cap has never been pushed in.
my 3.1TLs
I will fix your shifted magnets for free.
It's my lucky day! Do you do this for fun, lawdogg? I'm not sure how to send messages on this forum, but I certainly am interested. Thank you
Club Polk.... it’s how we roll. Good on you Lawdogg.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Yep just for fun and to help people out who need it! I'll send you a message about the shipping.
my 3.1TLs
Very nice of you Lawdogg, you get the club Polk smiley sticker today .
Seriously, way to go man.HT SYSTEM-
lsi 9's -
I think there's a button and a trophy for that.Very nice of you Lawdogg, you get the club Polk smiley sticker today .
Indeed! Hear, hear!Seriously, way to go man.
mhardy6647 wrote: »I think there's a button and a trophy for that.
Nothing will ever top the cookie I got from Jesse.
my 3.1TLs
That made me burst out laughing
Well his driver's en route so hopefully we get some good news from him on Monday!
my 3.1TLs
Woohoo! I'll be sure to let you all know just how good it sounds. These speakers are awesome, without so much bass that I disturb the neighbors. Gonna be great for doing homework...
@lawdogg It's here, in beautiful condition, and successfully installed. I couldn't be happier! I was wrong about not having enough bass to disturb the neighbors... But more importantly, the rich warmth and deep tones sing sweet serenades to my ears. Thanks again!
It's a good thing that you stumbled upon lawdogg, because up to now your first real speakers were beginning to look like real duds.
Lawdogg to the rescue.
https://www.youtube.com/watch?v=WUNixcfkPsU
