My first real speakers
Hello everyone,
I've just picked up a pair of monitors from Craigslist for the sweet irresistible price of 25 dollars. Can you help me identify them? It seems the tweeters are SL2500, based on the label on the back.
I'd also appreciate any advice you could give in regards to refurbishing and repairing them. One of them only operates from the tweeter, though there is some vibration in the other two speakers. Probably due to a bad capacitor.
Thanks!
  • mlistens03
    mlistens03 Posts: 2,767
    I think those are Monitor 5’s.
    The magnet in the speaker that doesn’t play has probably slipped (google, and you’ll find that it’s a very common issue), so the first thing I would do I say pull the other driver and put glue (don’t remember which kind is recommended by most here) around the magnets so it doesn’t slip. Then, go and gently push on both sides of the cone with your thumb, and see if it moves easily. If it doesn’t immediately move, then don’t force it, and hopefully someone else will chime in on how to fix it.
    Also, the big driver on the bottom is a passive radiator, in case you didn’t already know. The only active drivers in these speakers are the tweeter and midwoofer, the bottom only is pushed by the air of the midwoofer.
  • mlistens03
    Almost forgot to mention, welcome to Club Polk!!
    F1nut Posts: 51,930
    Monitor 5 Series 2.
    The mid-driver's magnet has slipped. Tough to repair. You should be able to find a replacement on eBay.
  • FestYboy
    FestYboy Posts: 3,861
    I can do the same if @lawdogg is unable, and for the same deal.
    I haven't made this public knowledge only due to the fact that I only obtained my weekends last Sunday. But I officially have some free time to help the community now.
    xschop Posts: 5,331
    Your first pic is the passive radiator.
  • Thanks for the welcome everyone! The non-operational driver cone is wobbly and loose. So this is due to a slipped magnet? Can anyone help me understand more? I'd like to attempt the repair myself, if that's feasible.
  • verb
    verb Posts: 10,176
    FestYboy wrote: »
    Very nice gesture sir!
  • Should the cone be firmly connected to the voice coil? I suspect there is something more wrong here. The dust cap is effectively destroyed, so I just pulled off the crumbling bits.
  • Sorry for the double post, somehow I don't have editing permissions on my last post.
    As you can see, the voice coil has totally burned away from the spider and the cone. The dust cap just crumbled away when I touched it. Is this repairable, or should I just search for a replacement driver?
    nooshinjohn Posts: 25,973
    A replacement will be your best bet IMHO...
  • mlistens03
    Woah, never seen anything like that for a Polk driver.
    Find a used replacement on eBay or something, and maybe try to fix that one as a spare?
    Did you use a multimeter to test the resistance?
  • I've got 0.3 ohms across the terminals. How on earth would I even go about repairing this? The cone might be usable but the spider seems fubar. Are replacement parts available?
  • mlistens03
    cyrial wrote: »
    If it’s reads 0.3 ohms, you’re toast. The driver is garbage, although don’t toss it in case a magnet slips on another speaker, and during repair it is dropped and it cracks or something. Or maybe I’m preparing you for something that’ll never happen.
    Once you get these working, you will quickly find yourself sucked into the rabbit hole, destined for the rest of your life to be hunting for deals on Craigslist and at garage sales, and endlessly tweaking and testing and tweaking again. :wink:
  • I fear I'm already down the rabbit hole, and this is merely the latest branch of the tunnel
  • With that much damage to a driver I would check everything electronic very carefully. Including replacing the caps and resistors, almost looks like that burned driver was hit with Direct Current.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Driver is toast. MW6502s are plentiful on fleabay. Just make sure the seller wraps it properly to prevent damage during shipping
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Thanks for the model number @westmassguy
  • lawdogg
    lawdogg Posts: 469
    edited September 2018
    Bummer! Yes used drivers are plentiful. In fact, I have a re-centered and epoxied 6502 right here that you're welcome to if you can cover shipping. Even the dust cap has never been pushed in. :smiley:
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • It's my lucky day! Do you do this for fun, lawdogg? I'm not sure how to send messages on this forum, but I certainly am interested. Thank you :)
    lawdogg wrote: »
    Club Polk.... it’s how we roll. Good on you Lawdogg.
  • lawdogg
    lawdogg Posts: 469
    cyrial wrote: »
    Yep just for fun and to help people out who need it! I'll send you a message about the shipping.
    <3 my 3.1TLs
    Very nice of you Lawdogg, you get the club Polk smiley sticker today . :)
    Seriously, way to go man.
    mhardy6647 Posts: 35,191
    tonyb wrote: »
    I think there's a button and a trophy for that.
    Indeed! Hear, hear! :)
  • lawdogg
    lawdogg Posts: 469
    Nothing will ever top the cookie I got from Jesse. :blush:
    <3 my 3.1TLs
    F1nut Posts: 51,930
    That made me burst out laughing :D
  • lawdogg
    lawdogg Posts: 469
    Well his driver's en route so hopefully we get some good news from him on Monday!
    <3 my 3.1TLs
  • Woohoo! I'll be sure to let you all know just how good it sounds. These speakers are awesome, without so much bass that I disturb the neighbors. Gonna be great for doing homework...
  • Home Theater/2 Channel:
  • @lawdogg It's here, in beautiful condition, and successfully installed. I couldn't be happier! I was wrong about not having enough bass to disturb the neighbors... But more importantly, the rich warmth and deep tones sing sweet serenades to my ears. Thanks again!
  • It's a good thing that you stumbled upon lawdogg, because up to now your first real speakers were beginning to look like real duds.
    Lawdogg to the rescue.
