Post a picture... any picture
12472482502522531153
    Clipdat Posts: 13,101
    You don't see these Dayens Ampino Monoblocks come up for sale too often:
    Seen here: http://www.hifi-intouch.co.uk/products/3329/21/transistor-power-amplifiers/dayens-ampino-mono-power-amplifiers.aspx
    I like the description, sums up their performance nicely:
    "HiFi In Touch are now dealers and stockist of the stunning range of amplifiers from DAYENS. These amplifiers are very special and can compete with far more costly alternatives.
    Very smooth and valve like sounding, powerful, transparent, dynamic and most importantly very musical.
    Not heard of DAYENS and are sceptical that these amplifiers are as good as we claim they are? Ask about our no obligation home demonstration."
  • Kevog
    Kevog Posts: 7
    LG OLED 65C6 - Denon AVR-x3400 - Emotiva A-5175 - OPPO 203 - Polk RTI A5 towers, CSi A6 center, FXi A6 surrounds - SVS PC12 Plus
  • charley95
    charley95 Posts: 908
    My ugly mug in Exuma,Bahamas back in May. I sure do miss that place!
  • Willow
    Willow Posts: 11,340
    charley95 wrote: »
    Way to ruin a perfectly good nature shot ;)
    pitdogg2 Posts: 27,775
    charley95 wrote: »
    I'm digging the shoes Charley.
    If ya zoom in, I think that's Russ and Ryan in the water back there. lol
  • lightman1
    lightman1 Posts: 10,800
    tonyb wrote: »
    Good times, Tony! You shoulda been there.
  • lightman1
    charley95 wrote: »
    I bet I could out ugly you.....
    Viking64 Posts: 7,770
    lightman1 wrote: »
    Oh, really?
  • Kevog
    Kevog Posts: 7
    Mini dinosaur!
    Clipdat wrote: »
    Mini dinosaur!
    Roxiesaurus!
  • joecoulson
    joecoulson Posts: 4,971
    edited August 2018
    I prefer the Panasonic model with tube:
  • mlistens03
    mlistens03 Posts: 2,767
    Tubes in a car doesn't seem like a good idea to me... although I'm not sure why i don't think it's brilliant. Either way, both look stellar!
    mhardy6647 Posts: 35,522
    edited August 2018
    Car radios had tubes in 'em into the 1960s. A whole line of low-voltage "space charge" tubes was developed very late in the tube era, specifically because cost-effective high-frequency transistors lagged audio-frequency transistors in availablity to the consumer electronics industry by ca. a decade.
    Until the late 1950s/early 1960s, car radios used fairly normal tubes, requiring relatively high plate voltages -- the power supplies for those radios were clunky affairs using an electromechanical gizmo called a vibrator (get your minds outta the gutter! ;) ) to generate dirty AC (EDIT: actually, pulsed DC) that could then be used with a fairly normal "linear" (as we'd say nowadays) transformer/filter type HV power supply to generate the voltages needed by all-tube car radios well into the 1950s.
    12504947603_a359d96172_h.jpgScan_Pic0034 by Mark Hardy, on Flickr
    The space charge tubes required only the 12-ish volt DC available in a car to operate. These tubes bridged the gap between all tube and all solid state auto electronics.
    Today, these odd little tubes are easy to find and cheap, which has led to a certain amount of interest in using them for... well.. whatever nefarious purposes folks can dream up.
    http://www.junkbox.com/electronics/lowvoltagetubes.shtml
    Pete Millett designed and a DIY'able hybrid headphone amp/linestage using space charge tubes. I've built a couple of these (his original design, as published in audioXpress) over the years; tonnes of fun they are, too.
    http://www.pmillett.com/hybrid_head.htm
    25542311708_9a34ed6a2f.jpgrealhifiglows by Mark Hardy, on Flickr
    PS I remember that Panasonic car hifi -- never saw/heard one, though. There is a company specializing in auto tube audio, FWIW: http://milbert.com/
    The sum total of my knowledge of 'em is that they exist. :|
  • [Deleted User]
    Back in the days of yore when I worked at a store that installed car audio gear there was a vacuum tube car amp available. I can't remember the company's name at present.
    Pretty sure that the car rekkid playas that celebrities as disparate as Lawrence Welk and Muhammad Ali were rockin' back in the day used tubes, too! :)
    Just in case any of all y'all young whippersnappers thought that your generation invented distracted driving! ;)
  • mlistens03
    Wow, I didn't know that! Very interesting. I guess I should've thought about what they would've done before SS amplifiers were invented.
    Thanks for sharing!
    Real quick question, did they ever use shock absorbers for housing the tubes, so they didn't get damaged by being bounced around every which way?
    Would they need them? I thought tubes were designed to be used in missiles, etc.
  • mlistens03
    Clipdat wrote: »
    WHAT!?! I didn't know that!
    I guess I always thought of them as fragile things. The kind of thing that would crack with only minor impact.
    mlistens03 wrote: »
    Thanks for sharing!
    They used tubes in missles * and hydrogen bombs. They're actually pretty tough.
    In fact, no, there weren't generally any special considerations made for radio tubes in cars -- though shielding them from static generated by the engine ignition system was pretty important :)
    _________________
    * In fairness, the tubes used in really harsh environments were typically ruggedized versions of the ones we all know and love. In fact, some of them are highly sought after (i.e., expen$ive) today for hifi use. Imagine that?! :)
    source: http://www.itishifi.com/search?q=RCA+red
    actually, the true "guided missle tubes" were typically made by folks like Bendix :)
    http://www.timeelect.com/vacuum-tubes-tc-myths-and-snake-oil-marketing.html
    Keeping on subject, here is a photograph of actor William Bendix. (Probably wearing TUBE socks, too.)
    Interesting, seems to imply that a different "hardened" glass was used in the Bendix tubes.
  • mlistens03
    500G max impact shock!?! Holy hubcaps Batman!
    I don't think that'll break if you drop it. :wink:
    And to think, I thought that setting it down on the table too hard would crack it!
    edited August 2018
    I ran a pair of Westinghouse branded 5962s in the "Simple 2A3" amp for quite a while. Not sure that they sounded better than (ahem) lesser 6SN7s, but they sho'nuff do look cooler. :)
    13337579533_1651ee9dd5_b.jpgWesties closeup by Mark Hardy, on Flickr
    I've since gone (back) to higher-mu voltage amplifier tubes (6SL7 -- for which the amp was designed!), and, unfortunately, I don't have a pair of "Special Red" 5961s to use in it! :(
    EDIT: meh, I'd have to add a separate filament transformer to handle 5961s in the amp :p -- I forgot :(
    Post edited by mhardy6647 on
  • mrbigbluelight
    As seen at AA
    As could be expected from folks in the audio hobby, some inquisitive chap in the "Comments" section asked this:
    "Can it be heard over the {Miata} engine and wind noise? * :p
  • lightman1
    As seen at AA
