Help with system.
Sure Tony, will have look at receiver!
It's ok Clipdat.....thanks for the message! -
I'm not 100% sure on how the Yamaha works, but if it's detecting that you're playing back something in stereo from your Blu Ray player, could it be applying a different EQ or Audessey profile? For example if the sound mode is set to Stereo vs. PCM vs. DTS etc.
Ohh possibly...I will have check and try to see once ..thanks a lot Clipdat..!
Hey...yttara...tried all the settings ...but sub is little low wen I pay music ...may be it will take time to burn out.
Happy December season everyone π
Good to see you man, how's your setup sounding? -
Did I ever get the sub volume issue resolved @Nandikol?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Somewhere there is a setting that come default @ LFE need to change it to LFE + MainWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
Hey clipdat, thanks a lot man...ya it's sounding amazing...took out those RTia 7 from rare surround and placed taga harmony B4 Bookshelf speakers.
Hi rooftop and mrloren, sub had a issue...in a 10 days time the sound was zero.. post which Svs changed the amp and driver with new ones..now it's working perfectly fine...thanks for all your help π
Just tot of asking one question_ seller advised me to set taga harmony B4.V2 to set it up as large when I setup them as rare surround.. THX always suggest to be as 80 Hrtz and small... What you all suggest .thanks
SmallPolitical Correctness'.........defined
President of Club Polk -
Sure definitely F1nut...thanks for the advice.
Wish you all a very Happy Marry Christmas ππ―πππ°
Merry Christmas to you too.
It looks like you have some SERIOUS thunder in your room now!
NICE! Most people just listen to music and watch movies. I EXPERIENCE them.
βAnger is an acid that can do more harm to the vessel in which it is stored than to anything on which it is poured.β
βIf at first you don't succeed, then skydiving definitely isn't for you.β - Steven Wright -
Thanks Tony ..yes thunder is accross roomπ
https://youtu.be/IrC5K-gXSos
