Help with system.
123457Β»
  • Nandikol
    Nandikol Posts: 109
    Sure Tony, will have look at receiver!
    It's ok Clipdat.....thanks for the message!
    Clipdat Posts: 13,101
    I'm not 100% sure on how the Yamaha works, but if it's detecting that you're playing back something in stereo from your Blu Ray player, could it be applying a different EQ or Audessey profile? For example if the sound mode is set to Stereo vs. PCM vs. DTS etc.
  • Nandikol
    Nandikol Posts: 109
    Ohh possibly...I will have check and try to see once ..thanks a lot Clipdat..!
  • Nandikol
    Nandikol Posts: 109
    Hey...yttara...tried all the settings ...but sub is little low wen I pay music ...may be it will take time to burn out.
  • Nandikol
    Nandikol Posts: 109
    Happy December season everyone 😊
    Nandikol wrote: Β»
    Good to see you man, how's your setup sounding?
  • rooftop59
    rooftop59 Posts: 8,120
    Did I ever get the sub volume issue resolved @Nandikol?
    Game Room 5.1.4:
    Bedroom 2.1
  • mrloren
    mrloren Posts: 2,483
    Nandikol wrote: Β»
    Somewhere there is a setting that come default @ LFE need to change it to LFE + Main
  • Nandikol
    Nandikol Posts: 109
    Hey clipdat, thanks a lot man...ya it's sounding amazing...took out those RTia 7 from rare surround and placed taga harmony B4 Bookshelf speakers. ifhsy97mzab5.jpg
  • Nandikol
    Nandikol Posts: 109
    Hi rooftop and mrloren, sub had a issue...in a 10 days time the sound was zero.. post which Svs changed the amp and driver with new ones..now it's working perfectly fine...thanks for all your help 😊
  • Nandikol
    Nandikol Posts: 109
    Just tot of asking one question_ seller advised me to set taga harmony B4.V2 to set it up as large when I setup them as rare surround.. THX always suggest to be as 80 Hrtz and small... What you all suggest .thanks
    F1nut Posts: 52,294
    Small
  • Nandikol
    Nandikol Posts: 109
    Sure definitely F1nut...thanks for the advice.
  • Nandikol
    Nandikol Posts: 109
    Wish you all a very Happy Marry Christmas πŸ””πŸ“―πŸ˜ŠπŸ’πŸ°
    Tony M Posts: 11,962
    Merry Christmas to you too.
    It looks like you have some SERIOUS thunder in your room now! B) NICE!
    β€œAnger is an acid that can do more harm to the vessel in which it is stored than to anything on which it is poured.”
    β€œIf at first you don't succeed, then skydiving definitely isn't for you.” - Steven Wright
  • Nandikol
    Nandikol Posts: 109
    Thanks Tony ..yes thunder is accross room😊
